    How to create a Mask in Layout
    layout
    42 Posts 9 Posters 7.6k Views 9 Watching
    • bmikeB Offline
      bmike
      @porch_unplugged said:
      @dave r said:
      That just sounds like a lot of work to me. If it works for you, great. If I had to work that way I think I'd quit and do something else. πŸ˜‰
      It's not too bad, drawing out a clipping mask in layout sounds like a lot more work to me. Doesn't look like I'll be getting Pro and layout any time soon, so it'll have to do. πŸ˜„
      have a look at my layout overview.
      even if you don't go pro - there are lots of ways to setup your sketchup to streamline your workflow.
      • porch_unpluggedP Offline
        porch_unplugged
        @pbacot said:
        Brian: Have you tried a dwg export or vector pdf to CAD? I think there a plugins for the dwg or dxf if you don't have pro.
        thought never crossed my mind, i'll look into it, thanks Peter.
        I'm sure I've watched it already, but just waiting for it load again now (rubbish internet connection) Thanks Mike πŸ‘
        • pbacotP Offline
          Brian: Have you tried a dwg export or vector pdf to CAD? I think there's a plugins for the dwg or dxf if you don't have pro.
            penumbra
            How about this? What do you do when you have elements on an elevation that are not orthogonal with the view plane as in walls that are at an angle and receding away from the viewer?
              What do you mean, "what do you do?" What would you do? Could you post an example?
                You could us Fog in SKP scene-tab or a Style with depth-cues - to show them feinter.
                You could use a SectionPlane in the SKP scene-tab to hide everything towards the back of the model.
                You could make a large white grouped vertical face on a special layer that's only on in that scene-tab, locate it to obscure the back of the model.
                Or a shaped mask face overlaid in LayOut to hide them, or even made edgeless and translucent to show what's behind feinter.
                There are many ways to achieve different effects - you choose or invent one that does what you want... πŸ˜•
                  penumbra
                  Thanks tig. Very helpful.
                  • pbacotP Offline
                    Penumbra,
                    In common elevations, one should be able to see background elements of the building. Here is a masterful use of fog by Sonder, in SU and LO:
                    http://sketchucation.com/forums/download/file.php?id=80022&t=1
                    404 Not Found
                    (sketchucation.com)
                    Peter
                      penumbra
                      Thanks Peter, i find fog difficult to control but once is setup right, looks great.
                      • bmikeB Offline
                        bmike
                        I find it difficult to use as well, likely operator error on my part.
                          Use [and update] scene-tabs, styles etc to 'remember' your settings for fog, layers etc
                            sonder
                            Fog is really easy to use. I set it up always in SU saved to the scene. Once you understand how the two arrows work, it is really intuitive. I like to think of the two as - right arrow = overall fog thickness - thicker as you slide to the left. Left arrow = fog depth from view point to your model - gets thinner as you slide it towards the right arrow.
                            I wish the fog in my brain were so easily controlled.
                            • bmikeB Offline
                              bmike
                              Do you need a separate style anytime you change the arrows? Or is it remembered per scene like the shadows?
                              • pbacotP Offline
                                Per Scene.
                                  sonder
                                  Yes, it saves with the scene when updated after adjustment.
                                  • 2 / 3
