    Testing Vray, need visopts
    renderpluginsextensions
    24 Posts 10 Posters 4.8k Views 10 Watching
    • andybotA
      andybot
      @Tom, (oops, I had some hidden lights I left on that messed up the comparison, I edited this post.) For comparison, I use higher hsph subdivs in my irradiance map, and add GI lighting to increase the illumination through the windows. Something odd happening with your AA sampler selection, see the fringing?
      Andy
      Here is a comparison:
      _interior_andybot-medium-Q.zip
      • StinkieS
        Stinkie
        Yeah, I do. Odd, indeed. That's not happened to me yet. Must've erred somewhere. Biased render apps and their gazillion settings! ๐Ÿ˜„
        @andybot said:
        (...) GI lighting to increase the illumination through the windows.
        What do you mean? Portals?
        • stefanqS
          stefanq
          If I had a penny every time I said this: " check clamp output and sub-pixel mapping" , those are white values, bigger then 255. V-ray just doesn't know how to represent them.
          What do you say guys, Pete has resigned ? ๐Ÿ˜ฎ
          • StinkieS
            Stinkie
            Weird. I've rendered with both unchecked without problems -or so I think. I should delve into this as soon as I get my new machine.
            • andybotA
              andybot
              โ˜€
              Exactly right! Thanks Stefan - I didn't think to check that. Here it is with both checked.
              Tom - I changed the GI from sky texture to none, and increased the multiplier to 4.5. I also decreased the sun intensity to get less harsh shadows where you do see the sun in the interior.
              • soloS
                Pete has resigned ?
                Nope, watching y'all discuss stuff, quietly carring on on my side.
                Thanks for all the links guys.
                • dkendigD
                  dkendig
                  I hope you get up to speed in time for beta to start. The next version has a bit more pep in it's step.
                  Devin Kendig
                  Developer
                  • K
                    kwistenbiebel
                    good news ๐Ÿ˜„
                      It's our puny screens rather - if you want to use higher bitdepth for post editing you cannot use the clamp feature. But you'll get the full range of light data.
                      • andybotA
                        andybot
                        actually, it was just the sub-pixel mapping that was needed. It renders fine with clamping off. Good point about not clamping output - even if you don't save to HDR, you can't use the levels adjustment in the vfb if something is blown-out.
                        • andybotA
                          andybot
                          I'll believe it when I see it! ๐Ÿ’š
                            I've seen it - and I want it!
                            eyeballs Devin's computer
                            • N
                              nomeradona
                              i use this visop before.. good for sunlight from the outside then coming to the room
                              http://www.sketchupvrayresources.blogspot.com/2012/11/visopt-series-2-nomeradonainterior.html
                              • N
                                nomeradona
                                yes looking forward....
