    Testing Vray, need visopts
    renderpluginsextensions
    24 Posts 10 Posters 4.4k Views 10 Watching
    • andybotA Offline
      andybot
      @loco said:
      Nomer has some here too + lot's more V-Ray content Sketchup V-Ray Recources
      I would be careful with older visopts (for example that old set from asgvis) as they generally don't work correctly in the current version.
      • stefanqS Offline
        stefanq
        Hello Pete! Here is a good one (by Fernando) where he's doing something that I find myself doing it often lately, and that is, starting with default settings. The most important trick I've learned from this, is to make use of the skylight (no sunlight mapped in that slot) instead of putting rectangular lights in the windows. In this way, you don't have to deal with artefacts from the lights, subdivisions etc. His final render looks impressive.
        Here is the tutorial, it's only 10 minutes long:
        http://www.youtube.com/watch?v=DCIngKllJnk&list=FLiETg2Y2_Rbm0MbNiljVpqg&index=1&feature=plpp_video
        • stefanqS Offline
          stefanq
          Here is another one:
          "Fernando Rentas explains how to use the sun in combination with HDRI to illuminate an exterior scene and produce sharp shadows from the sun in this video tutorial."
          http://www.youtube.com/watch?v=D3-TxEzW4sQ&feature=BFa&list=SPE2F8B612F375E98E
          • andybotA Offline
            andybot
            @Tom, (oops, I had some hidden lights I left on that messed up the comparison, I edited this post.) For comparison, I use higher hsph subdivs in my irradiance map, and add GI lighting to increase the illumination through the windows. Something odd happening with your AA sampler selection, see the fringing?
            Andy
            Here is a comparison:
            _interior_andybot-medium-Q.zip
            • StinkieS Offline
              Stinkie
              Yeah, I do. Odd, indeed. That's not happened to me yet. Must've erred somewhere. Biased render apps and their gazillion settings! ๐Ÿ˜„
              @andybot said:
              (...) GI lighting to increase the illumination through the windows.
              What do you mean? Portals?
              • stefanqS Offline
                stefanq
                If I had a penny every time I said this: " check clamp output and sub-pixel mapping" , those are white values, bigger then 255. V-ray just doesn't know how to represent them.
                What do you say guys, Pete has resigned ? ๐Ÿ˜ฎ
                • StinkieS Offline
                  Stinkie
                  Weird. I've rendered with both unchecked without problems -or so I think. I should delve into this as soon as I get my new machine.
                  • andybotA Offline
                    andybot
                    โ˜€
                    Exactly right! Thanks Stefan - I didn't think to check that. Here it is with both checked.
                    Tom - I changed the GI from sky texture to none, and increased the multiplier to 4.5. I also decreased the sun intensity to get less harsh shadows where you do see the sun in the interior.
                    • soloS Offline
                      Pete has resigned ?
                      Nope, watching y'all discuss stuff, quietly carring on on my side.
                      Thanks for all the links guys.
                      • dkendigD Offline
                        dkendig
                        I hope you get up to speed in time for beta to start. The next version has a bit more pep in it's step.
                        Devin Kendig
                        Developer
                          kwistenbiebel
                          good news ๐Ÿ˜„
                            It's our puny screens rather - if you want to use higher bitdepth for post editing you cannot use the clamp feature. But you'll get the full range of light data.
                            • andybotA Offline
                              andybot
                              actually, it was just the sub-pixel mapping that was needed. It renders fine with clamping off. Good point about not clamping output - even if you don't save to HDR, you can't use the levels adjustment in the vfb if something is blown-out.
                              • andybotA Offline
                                andybot
                                I'll believe it when I see it! ๐Ÿ’š
                                  I've seen it - and I want it!
                                  eyeballs Devin's computer
                                  • N Offline
                                    nomeradona
                                    i use this visop before.. good for sunlight from the outside then coming to the room
                                    http://www.sketchupvrayresources.blogspot.com/2012/11/visopt-series-2-nomeradonainterior.html
                                    • N Offline
                                      nomeradona
                                      yes looking forward....
