    [Plugin] [$] Artisan (1.2.3) - Feb 28, 2014
    296 Posts 95 Posters 140.5k Views 95 Watching
      baldaman
      Dear Mr MASTER WHAAT,
      a little question.
      There is an option for smoothed edges or not for the subsurf in the settings.
      We only have the choice between all smoothed or none smoothed, it would be fantastic to have the choice of the "angle between normals" like in the soften edges native SU dialog!
      And also why not dreaming: to establish a correspondance between proxies "angle between normals" edge softening and creased or not edges of that proxy.
      Sorry for my very bad english.
      PS: ARTISAN ROCKS! PROFILE BUILDER ROCKS!!!(the first and only software my former office was Ok to buy for me...)
      • soloS Offline
        Post wishes here: http://forums.sketchucation.com/viewtopic.php?f=323&t=40197
          AcesHigh
          Hi people... I am having some problems with the RoundCurve plugin by Fredo, and he suggested I should do what I intend with ARTISAN.
          I never used Artisan or Subdivide and Smooth... so I want to know if what I want to do is possible with ARTISAN and HOW to do it.
          Basically, what I have, is a square where I cut 2 of its corners with a bezier curve. Then I pushed/pulled the shape. I selected the top surface and applied Roundcurve, but for some reason, the plugin doesnt works well with bezier curves it seems, so the plugin offsets the curves but the offset "overlaps" itself in the curves, causing weird geometry.
          How can I have the same effect with Artisan?
          here is what happens when I try to use RoundCorner in my shape... first image shows the overlapping when offsetting the surface... second shows similar overlapping when using RoundCorner, and 3rd image shows the result of applying roundcorner when the curves overlap.
          3rd image also shows what I intend to do, so you guys can tell me if that is possible with Artisan and how you do that.
          I am also adding the shape that should be extruded and have its corners rounded with Artisan... so I hope you guys can confirm Artisan can do that and teach me how ๐Ÿ˜ž ๐Ÿ˜ž
          http://img542.imageshack.us/img542/8729/roundcorneroverlap.jpg
          artisantestshape.skp
          • hellnbakH Offline
            hellnbak
            Decided to set myself down and learn Artisan, and am having problems right off the bat. When I subdivide and smooth a cube, it does not come out smooth like the one in the how-to video. I ran 4 iterations just like in the video, and my results look more like a potato than the nice smooth result in the video. The subdivision patterns are different also.
            Here is what it should look like....
            and here's what I got......
            Don't know what I could be doing wrong, you select all the faces, and then subdivide and smooth four times, right? Just like in the video. If I can't get beyond the first basic step, I don't hold out much hope for getting very far with this. Any help will be much appreciated.
            • W Offline
              Whaat
              You might be missing this step:
              After you press the subdivide and smooth button, then type in '4 <enter>'. This is how to properly achieve 4 iterations. (press <enter> again to commit)
              The alternative is to apply the SDS tool 4 times, each with one iteration. If you do this, you will probably not get the desired result.
                Curious because from a cube I well obtain a sphere without any problem ๐Ÿ˜„
                • W Offline
                  Whaat
                  Info about version 1.2 has been added to the first post.
                  Get it here:
                  http://artisan4sketchup.com/category/downloads/
                  • pbacotP Offline
                    Thank you Dale. I have this DL'd already. I should remember, but how can you find out what version is currently installed?
                    • massimoM Offline
                      massimo Moderator
                      Thanks for the update Dale. ๐Ÿ‘
                      You should have a file called "artisan_loader" in the plugins folder which reports the installed version of the plugin.
                      • W Offline
                        Whaat
                        Go to Windows->Preferences->Extensions->Artisan
                        • pbacotP Offline
                          Thanks Dale. Got it! So there's a good use of the extensions Tab after all. Now if they'd just make that window fully expandable and regularize its use...
                          • Mistro11M Offline
                            Mistro11
                            I am now a proud Artisan License Owner! Thanks for this great plugin! ๐Ÿ˜Ž
                            i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                            Structural Integrity is Not Just Physical...It's in the Design and Purpose
                            • pbacotP Offline
                              Sometimes I get no results from the sculpt tool at all. However this can change when I close the model or SU and reopen. What might be the things that make this tool work better, or worse?
                              Also: I'd request some lock on vertical movement in the future, so we don't have to hold the shift key down all the time (this is the way I use almost always use it when it works).
                              Version 1.2
                              Thanks, Peter
                              • guanjinG Offline
                                guanjin
                                Why do I install the free 15-day version of the display icon gray, can not be used.
                                If I buy genuine worry about will not be displayed? ?
                                • W Offline
                                  Whaat
                                  Hi Peter,
                                  Maybe you have a mask active? If you have any edge or face selected, the sculpt tool will only affect those selected entities. I am not sure why else you would experience this.
                                  Dale
                                  • W Offline
                                    Whaat
                                    Unless Artisan was installed previously on your computer, the icons should not be gray until 15 days have expired.
                                    Once you purchase and register, the icons will no longer be grayed.
                                    If you have problems with the plugin after purchase, I can provide you a refund.
                                    Dale
                                      matsuo_lano
                                      I'm getting a bug splat after using subdivide on a single rectangle...
                                      You try to rearrange me 'till I'm sane
                                        Can you share the file?
                                          matsuo_lano
                                          Well, it's a fresh new file I've started, that's the weird thing.
                                          edit
                                          SketchUpUndo1.log says the following:
                                          File New
                                          File New
                                          ======== Starting GL ========
                                          CBaseGLView::OnInitialUpdate
                                          InitializeOpenGL
                                          GetActivePixelFormat
                                          Got PF= 15 from registry
                                          IsValidPixelFormatInfo
                                          requestedpf.accel=1
                                          ARB functions NOT available.
                                          nPfds=66
                                          Pixel format 1 does not do a swap copy.
                                          Pixel format 4 does not do a swap copy.
                                          Pixel format 7 does not do a swap copy.
                                          Pixel format 10 does not do a swap copy.
                                          Pixel format 13 does not do a swap copy.
                                          Pixel format 16 does not do a swap copy.
                                          Pixel format 19 does not do a swap copy.
                                          Pixel format 22 does not do a swap copy.
                                          Pixel format 25 does not do a swap copy.
                                          Pixel format 28 does not do a swap copy.
                                          Pixel format 15 is valid
                                          GLConfigUtils::GetActivePixelFormat ... returning specified format 15
                                          Make a context ... pf=15
                                          Got context @3d9e020 error=0
                                          GL initialization succeeded
                                          ***** First UI thread = 5236
                                          Tool(SketchTool)
                                          Tool(SketchTool)
                                          UseHWAccelerationFirstTime
                                          Not first time ... returning true
                                          Tool(SketchTool)
                                          Tool(SketchTool)
                                          Tool(RectangleTool)
                                          Tool(RectangleTool)
                                          Tool(RectangleTool)
                                          Start(Rectangle)Commit(1)
                                          Tool(RectangleTool)
                                          Tool(SelectionTool)
                                          Start(Reverse Face)Commit(2)
                                          Start(Open)Commit(3)
                                          Start(Change Axes)Commit(4)
                                          Start(Macro)
                                          • pbacotP Offline
                                            @whaat said:
                                            Hi Peter,
                                            Dale
                                            Thank you, Dale, I'll keep that in mind!
                                            BTW is is mathematically impossible to have smooth work in vertical lock mode (like sculpt and flatten)? What do you think about a lock down setting instead of the shift key?
                                            Great tool. Still learning, I guess.
                                            Peter
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 12 / 15
