    [Plugin] [$] Artisan (1.2.3) - Feb 28, 2014
    296 Posts 95 Posters 137.4k Views 95 Watching
    • W Offline
      Whaat
      @hellnbak said:
      Don't know what I could be doing wrong, you select all the faces, and then subdivide and smooth four times, right? Just like in the video. If I can't get beyond the first basic step, I don't hold out much hope for getting very far with this. Any help will be much appreciated.
      You might be missing this step:
      After you press the subdivide and smooth button, then type in '4 <enter>'. This is how to properly achieve 4 iterations. (press <enter> again to commit)
      The alternative is to apply the SDS tool 4 times, each with one iteration. If you do this, you will probably not get the desired result.
        Curious because from a cube I well obtain a sphere without any problem πŸ˜„
        • W Offline
          Whaat
          Info about version 1.2 has been added to the first post.
          Get it here:
          http://artisan4sketchup.com/category/downloads/
          • pbacotP Offline
            Thank you Dale. I have this DL'd already. I should remember, but how can you find out what version is currently installed?
            • massimoM Offline
              massimo Moderator
              Thanks for the update Dale. πŸ‘
              You should have a file called "artisan_loader" in the plugins folder which reports the installed version of the plugin.
              • W Offline
                Whaat
                Go to Windows->Preferences->Extensions->Artisan
                • pbacotP Offline
                  Thanks Dale. Got it! So there's a good use of the extensions Tab after all. Now if they'd just make that window fully expandable and regularize its use...
                  • Mistro11M Offline
                    Mistro11
                    I am now a proud Artisan License Owner! Thanks for this great plugin! 😎
                    i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                    Structural Integrity is Not Just Physical...It's in the Design and Purpose
                    • pbacotP Offline
                      Sometimes I get no results from the sculpt tool at all. However this can change when I close the model or SU and reopen. What might be the things that make this tool work better, or worse?
                      Also: I'd request some lock on vertical movement in the future, so we don't have to hold the shift key down all the time (this is the way I use almost always use it when it works).
                      Version 1.2
                      Thanks, Peter
                      • guanjinG Offline
                        guanjin
                        Why do I install the free 15-day version of the display icon gray, can not be used.
                        If I buy genuine worry about will not be displayed? ?
                        • W Offline
                          Whaat
                          Hi Peter,
                          Maybe you have a mask active? If you have any edge or face selected, the sculpt tool will only affect those selected entities. I am not sure why else you would experience this.
                          Dale
                          • W Offline
                            Whaat
                            Unless Artisan was installed previously on your computer, the icons should not be gray until 15 days have expired.
                            Once you purchase and register, the icons will no longer be grayed.
                            If you have problems with the plugin after purchase, I can provide you a refund.
                            Dale
                              matsuo_lano
                              I'm getting a bug splat after using subdivide on a single rectangle...
                              You try to rearrange me 'till I'm sane
                                Can you share the file?
                                  matsuo_lano
                                  Well, it's a fresh new file I've started, that's the weird thing.
                                  edit
                                  SketchUpUndo1.log says the following:
                                  File New
                                  File New
                                  ======== Starting GL ========
                                  CBaseGLView::OnInitialUpdate
                                  InitializeOpenGL
                                  GetActivePixelFormat
                                  Got PF= 15 from registry
                                  IsValidPixelFormatInfo
                                  requestedpf.accel=1
                                  ARB functions NOT available.
                                  nPfds=66
                                  Pixel format 1 does not do a swap copy.
                                  Pixel format 4 does not do a swap copy.
                                  Pixel format 7 does not do a swap copy.
                                  Pixel format 10 does not do a swap copy.
                                  Pixel format 13 does not do a swap copy.
                                  Pixel format 16 does not do a swap copy.
                                  Pixel format 19 does not do a swap copy.
                                  Pixel format 22 does not do a swap copy.
                                  Pixel format 25 does not do a swap copy.
                                  Pixel format 28 does not do a swap copy.
                                  Pixel format 15 is valid
                                  GLConfigUtils::GetActivePixelFormat ... returning specified format 15
                                  Make a context ... pf=15
                                  Got context @3d9e020 error=0
                                  GL initialization succeeded
                                  ***** First UI thread = 5236
                                  Tool(SketchTool)
                                  Tool(SketchTool)
                                  UseHWAccelerationFirstTime
                                  Not first time ... returning true
                                  Tool(SketchTool)
                                  Tool(SketchTool)
                                  Tool(RectangleTool)
                                  Tool(RectangleTool)
                                  Tool(RectangleTool)
                                  Start(Rectangle)Commit(1)
                                  Tool(RectangleTool)
                                  Tool(SelectionTool)
                                  Start(Reverse Face)Commit(2)
                                  Start(Open)Commit(3)
                                  Start(Change Axes)Commit(4)
                                  Start(Macro)
                                  • pbacotP Offline
                                    @whaat said:
                                    Hi Peter,
                                    Dale
                                    Thank you, Dale, I'll keep that in mind!
                                    BTW is is mathematically impossible to have smooth work in vertical lock mode (like sculpt and flatten)? What do you think about a lock down setting instead of the shift key?
                                    Great tool. Still learning, I guess.
                                    Peter
                                    • W Offline
                                      Whaat
                                      @pbacot said:
                                      @whaat said:
                                      Hi Peter,
                                      Dale
                                      Peter
                                      Good suggestions, thanks! I will add them to the wishlist.
                                      • W Offline
                                        Whaat
                                        matsuo:
                                        It might help if you post the file. Also, what other plugins do you have installed?
                                        Try temporarily putting all other plugins in a backup folder so they don't get loaded by SU to see if that fixes things. Then, try to use process of elimination to see if one particular plugin is contributing to the bug-splat.
                                        Thanks.
                                        Dale
                                          matsuo_lano
                                          Well, I'm using a new file, so there's nothing in there that could cause problems
                                          Edit: I've removed all the plugins, and no more bugsplats!
                                          Edit 2: Reinstalled SketchUp + replaced all the outdated plugins = problem solved!
                                          • guanjinG Offline
                                            guanjin
                                            Normal installation, but can not find the tool。
                                            I did something wrong
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 12 / 15
