    [Plugin] [$] Artisan (1.2.3) - Feb 28, 2014
    296 Posts 95 Posters 172.5k Views 95 Watching
    • W
      Whaat
      @pbacot said:
      Thank you Dale. I have this DL'd already. I should remember, but how can you find out what version is currently installed?
      Go to Windows->Preferences->Extensions->Artisan
      • pbacotP
        Thanks Dale. Got it! So there's a good use of the extensions Tab after all. Now if they'd just make that window fully expandable and regularize its use...
        • Mistro11M
          Mistro11
          I am now a proud Artisan License Owner! Thanks for this great plugin! 😎
          Structural Integrity is Not Just Physical...It's in the Design and Purpose
          • pbacotP
            Sometimes I get no results from the sculpt tool at all. However this can change when I close the model or SU and reopen. What might be the things that make this tool work better, or worse?
            Also: I'd request some lock on vertical movement in the future, so we don't have to hold the shift key down all the time (this is the way I use almost always use it when it works).
            Version 1.2
            Thanks, Peter
            • guanjinG
              guanjin
              Why do I install the free 15-day version of the display icon gray, can not be used.
              If I buy genuine worry about will not be displayed? ?
              • W
                Whaat
                Hi Peter,
                Maybe you have a mask active? If you have any edge or face selected, the sculpt tool will only affect those selected entities. I am not sure why else you would experience this.
                Dale
                • W
                  Whaat
                  Unless Artisan was installed previously on your computer, the icons should not be gray until 15 days have expired.
                  Once you purchase and register, the icons will no longer be grayed.
                  If you have problems with the plugin after purchase, I can provide you a refund.
                  Dale
                    matsuo_lano
                    I'm getting a bug splat after using subdivide on a single rectangle...
                    You try to rearrange me 'till I'm sane
                      Can you share the file?
                        matsuo_lano
                        Well, it's a fresh new file I've started, that's the weird thing.
                        edit
                        SketchUpUndo1.log says the following:
                        File New
                        File New
                        ======== Starting GL ========
                        CBaseGLView::OnInitialUpdate
                        InitializeOpenGL
                        GetActivePixelFormat
                        Got PF= 15 from registry
                        IsValidPixelFormatInfo
                        requestedpf.accel=1
                        ARB functions NOT available.
                        nPfds=66
                        Pixel format 1 does not do a swap copy.
                        Pixel format 4 does not do a swap copy.
                        Pixel format 7 does not do a swap copy.
                        Pixel format 10 does not do a swap copy.
                        Pixel format 13 does not do a swap copy.
                        Pixel format 16 does not do a swap copy.
                        Pixel format 19 does not do a swap copy.
                        Pixel format 22 does not do a swap copy.
                        Pixel format 25 does not do a swap copy.
                        Pixel format 28 does not do a swap copy.
                        Pixel format 15 is valid
                        GLConfigUtils::GetActivePixelFormat ... returning specified format 15
                        Make a context ... pf=15
                        Got context @3d9e020 error=0
                        GL initialization succeeded
                        ***** First UI thread = 5236
                        Tool(SketchTool)
                        Tool(SketchTool)
                        UseHWAccelerationFirstTime
                        Not first time ... returning true
                        Tool(SketchTool)
                        Tool(SketchTool)
                        Tool(RectangleTool)
                        Tool(RectangleTool)
                        Tool(RectangleTool)
                        Start(Rectangle)Commit(1)
                        Tool(RectangleTool)
                        Tool(SelectionTool)
                        Start(Reverse Face)Commit(2)
                        Start(Open)Commit(3)
                        Start(Change Axes)Commit(4)
                        Start(Macro)
                        • pbacotP
                          @whaat said:
                          Hi Peter,
                          Dale
                          Thank you, Dale, I'll keep that in mind!
                          BTW is is mathematically impossible to have smooth work in vertical lock mode (like sculpt and flatten)? What do you think about a lock down setting instead of the shift key?
                          Great tool. Still learning, I guess.
                          Peter
                          • W
                            Whaat
                            @pbacot said:
                            @whaat said:
                            Hi Peter,
                            Dale
                            Peter
                            Good suggestions, thanks! I will add them to the wishlist.
                            • W
                              Whaat
                              matsuo:
                              It might help if you post the file. Also, what other plugins do you have installed?
                              Try temporarily putting all other plugins in a backup folder so they don't get loaded by SU to see if that fixes things. Then, try to use process of elimination to see if one particular plugin is contributing to the bug-splat.
                              Thanks.
                              Dale
                                matsuo_lano
                                Well, I'm using a new file, so there's nothing in there that could cause problems
                                Edit: I've removed all the plugins, and no more bugsplats!
                                Edit 2: Reinstalled SketchUp + replaced all the outdated plugins = problem solved!
                                • guanjinG
                                  guanjin
                                  Normal installation, but can not find the tool。
                                  I did something wrong
                                    Have you activated it in Preferences > Extensions ?
                                    Have you then activated its Toolbar ??
                                    • guanjinG
                                      guanjin
                                      The toolbar nor any option
                                        Have you 'activated' its Extension ??
                                        You have not said anything about this...
                                        • guanjinG
                                          guanjin
                                          Expansion which has also activated the 😳
                                            Does that mean you got it to work?
                                            Your phrasing does not explain things at all...
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 12 / 15
