    [Plugin] TT_Lib²
    310 Posts 66 Posters 408.0k Views 66 Watching
    • H Offline
      hygicell
      @thomthom said:
      Not all plugins can be enabled/disabled via the Extension list.
      a suggestion for a plugin or for sketchup?
      would make debugging fast and easy
        I think Dana was working on a Plugin Manager... ...I'll poke him and query the status.
          Whoa! After a remote session (thanks to Teamviewer) I found the culprit! It was organizer which doesn't just modify the menus etc, it even loads the files it iterates - causing Vertex Tools' loader.rb to be loaded before tt_vertex.rb - because it made the assumption that nothing other than tt_vertex.rb would be loading it. 😒
          • H Offline
            hygicell
                :facepunch:  :rolling_on_the_floor_laughing:  :heart_eyes:  :sunglasses:  :sunny:  :smile:  :smile:  :wink:  :open_mouth:  :astonished:
            Your message contains too many smilies. The maximum number of smilies allowed is 15.
              Organizer?
                (www.smustard.com)
                  Ah. So that's not so good.
                    It does say in the description of Organizer that sub-folders in the plugins folder needs to be excluded (because it assumes all sub-folders otherwise belongs to Smustard... 😕 )
                    But I had no idea how that plugin worked. I was just somewhat aware it did something with the menus. So now I've been debugging, with my user who's also had to deal with this, for the last three days. I don't like the invasive behaviour of Organizer.
                      Neither had I !
                      There is also a mechanism for developers to easily exclude their subfolders so Organizer will not try to load the contents of those folders. This should result in a smoother experience for users, who won't have to contend with manually maintaining the excluded folders list in the SmustardOrganizerExcludeFolders.txt file.
                      To do this: in your subfolder, create an empty text file called "exclude.txt" - that's it!
                      I too don't like the way that 'other developers' [AKA most of us] are expected to avoid their sledgehammer.
                      There are many tools that have subfolders of other files that don't auto-load...
                      They never should be auto-loaded anyway !? Surely that must be up to loader-scripts or extension-loaders to decide... Why has RickW made it this way at all ?
                      Have you messaged him ??
                      Another candidate for the 'Quarantine Badge' 😒
                        Yea - as it is now it by-passes the Extension mechanism of Plugins. Unless they exclude themselves. Which is really not something he should expect a developer to do. It shouldn't be an opt-out system. How on earth is a developer expected to know about the behaviour of another plugin like that?
                        I've not contacted him, no. I exhausted my computer time today debugging this.
                          I'm puzzled why he made the Plugins folderstructure into the hierarchy of the custom menus... o_O
                            jokewalker
                            Hi All!
                            Sorry for posting this without first combing through the preceding pages. My anti-virus (Kaspersky) is going crazy over the tt_api.so file thinking it's malware. Anyone else encountering this? Didn't seem to bother anything up until just recently. Puzzling.....
                            Thoughts?! Thanks in advance!
                              Yes, there's been a few reports. Tell Kaspersky to leave the file alone. (And please also make a report to Kaspersky about the false negative. Some other users has already reported it, but maybe they bump up the priority if more people complain.)
                              • H Offline
                                hygicell
                                maybe someone knows a way to disable the quarantine for one specific file inside Kapersky?
                                I didn't know the way to do that,
                                so took the radical decision to dump Kapersky
                                installed ZoneAlarm instead.
                                • F Offline
                                  FatKid73
                                  Hi All,
                                  I'm fairly new to Sketchup, and am trying to install the Cleanup plugin - I have a current model that's massive and therefore causing problems in rendering plugins such as Lumenrt or Maxwell Render -
                                  Could someone please walk me thru the install of the Cleanup plugin for Mac?
                                  Any help would be appreciated - Thanks.
                                    The subject has been covered repeatedly. I guess you could go through this thread and find it several times. Or you can look at the thread specifically on installing plugins.
                                      And here's an link to an article that explains it in detail with links to helping utilities such a "Simple Plugin Installer": http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                                      • H Offline
                                        hygicell
                                        I am one of those who tried, and spent a lot of time in it.
                                        TMHO Kaspersky sucks: no after sales service whatsoever.
                                        Throw it out !
                                        • F Offline
                                          FatKid73
                                          Got it - Thanks very much -
                                          and Thanks to Thomas for the plugin - it's great!
                                          • V Offline
                                            veerlexyz
                                            Error TT_Lib - core.rb.pdfAfter far to much craches I had to reinstall Sketchup and my plugins.
                                            I started with Fredo's AdditionalPlmuginFolders to keep it organized.
                                            The plugin Selection Toys did not install properly:
                                            1 ERROR: The following plugin had errors...
                                            PLUGIN: tt_selection_toys.rb
                                            FOLDER: D/.../Plugins 2013 01 12...
                                            ERROR: no such file load -- TT_Lib/core.rb
                                            TT_Select_Toys and TT_Lib2 are in the same folder: D/.../Plugins 2013 01 12...
                                            TT_Lib2 includes core.rb (11 kB)
                                            What went wrong?
                                            • 15
                                            • 16
                                            • 2 / 16
