    [Plugin] TT_Lib²
    310 Posts 66 Posters 499.0k Views 66 Watching
      Neither had I !
      There is also a mechanism for developers to easily exclude their subfolders so Organizer will not try to load the contents of those folders. This should result in a smoother experience for users, who won't have to contend with manually maintaining the excluded folders list in the SmustardOrganizerExcludeFolders.txt file.
      To do this: in your subfolder, create an empty text file called "exclude.txt" - that's it!
      I too don't like the way that 'other developers' [AKA most of us] are expected to avoid their sledgehammer.
      There are many tools that have subfolders of other files that don't auto-load...
      They never should be auto-loaded anyway !? Surely that must be up to loader-scripts or extension-loaders to decide... Why has RickW made it this way at all ?
      Have you messaged him ??
      Another candidate for the 'Quarantine Badge' 😒
        Yea - as it is now it by-passes the Extension mechanism of Plugins. Unless they exclude themselves. Which is really not something he should expect a developer to do. It shouldn't be an opt-out system. How on earth is a developer expected to know about the behaviour of another plugin like that?
        I've not contacted him, no. I exhausted my computer time today debugging this.
          I'm puzzled why he made the Plugins folderstructure into the hierarchy of the custom menus... o_O
            jokewalker
            Hi All!
            Sorry for posting this without first combing through the preceding pages. My anti-virus (Kaspersky) is going crazy over the tt_api.so file thinking it's malware. Anyone else encountering this? Didn't seem to bother anything up until just recently. Puzzling.....
            Thoughts?! Thanks in advance!
              Yes, there's been a few reports. Tell Kaspersky to leave the file alone. (And please also make a report to Kaspersky about the false negative. Some other users has already reported it, but maybe they bump up the priority if more people complain.)
              • H
                hygicell
                maybe someone knows a way to disable the quarantine for one specific file inside Kapersky?
                I didn't know the way to do that,
                so took the radical decision to dump Kapersky
                installed ZoneAlarm instead.
                • F
                  FatKid73
                  Hi All,
                  I'm fairly new to Sketchup, and am trying to install the Cleanup plugin - I have a current model that's massive and therefore causing problems in rendering plugins such as Lumenrt or Maxwell Render -
                  Could someone please walk me thru the install of the Cleanup plugin for Mac?
                  Any help would be appreciated - Thanks.
                    The subject has been covered repeatedly. I guess you could go through this thread and find it several times. Or you can look at the thread specifically on installing plugins.
                      And here's an link to an article that explains it in detail with links to helping utilities such a "Simple Plugin Installer": http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                      • H
                        hygicell
                        I am one of those who tried, and spent a lot of time in it.
                        TMHO Kaspersky sucks: no after sales service whatsoever.
                        Throw it out !
                        • F
                          FatKid73
                          Got it - Thanks very much -
                          and Thanks to Thomas for the plugin - it's great!
                          • V
                            veerlexyz
                            Error TT_Lib - core.rb.pdfAfter far to much craches I had to reinstall Sketchup and my plugins.
                            I started with Fredo's AdditionalPlmuginFolders to keep it organized.
                            The plugin Selection Toys did not install properly:
                            1 ERROR: The following plugin had errors...
                            PLUGIN: tt_selection_toys.rb
                            FOLDER: D/.../Plugins 2013 01 12...
                            ERROR: no such file load -- TT_Lib/core.rb
                            TT_Select_Toys and TT_Lib2 are in the same folder: D/.../Plugins 2013 01 12...
                            TT_Lib2 includes core.rb (11 kB)
                            What went wrong?
                              driven
                              @veerlexyz said:
                              TT_Lib/core.rb
                              TT_Lib2
                              spot the difference
                              • V
                                veerlexyz
                                Ooooh... I thought Lib2 was an update of Lib. How wrong.
                                Problem solved. Thanks a lot!
                                  No, it's a new version, but v2 isn't compatible with v1. Hence v1 is still possible to download. I know it's confusing, I might just bundle v1 with Selection Toys and be done with it, as ST is the only plugin that uses v2.
                                  • B
                                    billrivas
                                    after I put this folder to plugins folder it´s all solved;
                                    Very Nice plugin!! Thanks man!
                                    • daforumD
                                      daforum
                                      Hi. I've downloaded TT_Lib2 as I want to use QuadFaceTools_0.6.0 in SU7.
                                      Do I need to install the TT_Lib2 folder with all 50 items that are in the TT_Lib2 folder into the Plugins folder?
                                      Many thanks
                                        Many thanks
                                        If you're unsure on how to install the plugin I'd advice you to use this utility:
                                        http://sketchucation.com/forums/viewtopic.php?t=42315
                                        • daforumD
                                          daforum
                                          Hi thomthom.
                                          I had a look at the link and it says the utility is for SketchUp 8M2 or newer
                                          (i'm on SU v7 Mac)
                                            Upgrade to v8
                                            • 15
                                            • 16
                                            • 7 / 16
