    [Plugin] TT_Lib²
    310 Posts 66 Posters 440.9k Views 66 Watching
      Yea - as it is now it by-passes the Extension mechanism of Plugins. Unless they exclude themselves. Which is really not something he should expect a developer to do. It shouldn't be an opt-out system. How on earth is a developer expected to know about the behaviour of another plugin like that?
      I've not contacted him, no. I exhausted my computer time today debugging this.
        I'm puzzled why he made the Plugins folderstructure into the hierarchy of the custom menus... o_O
          jokewalker
          Hi All!
          Sorry for posting this without first combing through the preceding pages. My anti-virus (Kaspersky) is going crazy over the tt_api.so file thinking it's malware. Anyone else encountering this? Didn't seem to bother anything up until just recently. Puzzling.....
          Thoughts?! Thanks in advance!
            Yes, there's been a few reports. Tell Kaspersky to leave the file alone. (And please also make a report to Kaspersky about the false negative. Some other users has already reported it, but maybe they bump up the priority if more people complain.)
            • H Offline
              hygicell
              maybe someone knows a way to disable the quarantine for one specific file inside Kapersky?
              I didn't know the way to do that,
              so took the radical decision to dump Kapersky
              installed ZoneAlarm instead.
              • F Offline
                FatKid73
                Hi All,
                I'm fairly new to Sketchup, and am trying to install the Cleanup plugin - I have a current model that's massive and therefore causing problems in rendering plugins such as Lumenrt or Maxwell Render -
                Could someone please walk me thru the install of the Cleanup plugin for Mac?
                Any help would be appreciated - Thanks.
                  The subject has been covered repeatedly. I guess you could go through this thread and find it several times. Or you can look at the thread specifically on installing plugins.
                    And here's an link to an article that explains it in detail with links to helping utilities such a "Simple Plugin Installer": http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                    • H Offline
                      hygicell
                      I am one of those who tried, and spent a lot of time in it.
                      TMHO Kaspersky sucks: no after sales service whatsoever.
                      Throw it out !
                      • F Offline
                        FatKid73
                        Got it - Thanks very much -
                        and Thanks to Thomas for the plugin - it's great!
                        • V Offline
                          veerlexyz
                          Error TT_Lib - core.rb.pdfAfter far to much craches I had to reinstall Sketchup and my plugins.
                          I started with Fredo's AdditionalPlmuginFolders to keep it organized.
                          The plugin Selection Toys did not install properly:
                          1 ERROR: The following plugin had errors...
                          PLUGIN: tt_selection_toys.rb
                          FOLDER: D/.../Plugins 2013 01 12...
                          ERROR: no such file load -- TT_Lib/core.rb
                          TT_Select_Toys and TT_Lib2 are in the same folder: D/.../Plugins 2013 01 12...
                          TT_Lib2 includes core.rb (11 kB)
                          What went wrong?
                            driven
                            @veerlexyz said:
                            TT_Lib/core.rb
                            TT_Lib2
                            spot the difference
                            • V Offline
                              veerlexyz
                              Ooooh... I thought Lib2 was an update of Lib. How wrong.
                              Problem solved. Thanks a lot!
                                No, it's a new version, but v2 isn't compatible with v1. Hence v1 is still possible to download. I know it's confusing, I might just bundle v1 with Selection Toys and be done with it, as ST is the only plugin that uses v2.
                                  billrivas
                                  after I put this folder to plugins folder it´s all solved;
                                  Very Nice plugin!! Thanks man!
                                  • daforumD Offline
                                    daforum
                                    Hi. I've downloaded TT_Lib2 as I want to use QuadFaceTools_0.6.0 in SU7.
                                    Do I need to install the TT_Lib2 folder with all 50 items that are in the TT_Lib2 folder into the Plugins folder?
                                    Many thanks
                                      Many thanks
                                      If you're unsure on how to install the plugin I'd advice you to use this utility:
                                      http://sketchucation.com/forums/viewtopic.php?t=42315
                                      • daforumD Offline
                                        daforum
                                        Hi thomthom.
                                        I had a look at the link and it says the utility is for SketchUp 8M2 or newer
                                        (i'm on SU v7 Mac)
                                          Upgrade to v8
                                            @daforum said:
                                            Hi thomthom.
                                            (i'm on SU v7 Mac)
                                            Are you using Pro?
                                            If not, then I'd also recommend you upgrade to version 8.
                                            To manually install you'd need to ensure the files are located in such a manner indicated by the footprint description:
                                            A general guide can be found here:
                                            • 15
                                            • 16
                                            • 7 / 16
