    [Plugin] FreeDXF Importer
    148 Posts 41 Posters 206.5k Views 41 Watching
      Jim
      FreeDXF imports acad layers as SketchUp Groups, so it may be possible to color the Groups according to their acad layer color number.
        syfyguy
        It doesn't seem to work for me. I have Sketchup 8, with the new maintenance pack. It shows up in the plugins menu, then when executed it asks for arc segments, etc. When I click ok, nothing shows up. I'm using DWGeditor 2007 to create dxfs in ASCii 2007 format.
          Jim
          Can you post or send the file?
          • T
            Tenere
            😒 %(#4000FF)[I've got a script not loading error on start with free version 8.0.4811.
            I would assume I had the files in the right places although I can't see the folder layout image in the script posting - just an image name.
            Bound to be missing the obvious, be grateful if someone could nudge me in the right direction......cheers.
            Ooh one other question......Can I load the SU pro trial in tandem with my free version without bu#@ering it up or compromising the trial?....would quite like to see what I'm missing.] πŸ‘
              Capture.PNG Does you Sketchup Plugins folder look like this ?
              • T
                Tenere
                %(#0000FF)[πŸ‘ Hi Tig
                Thanks for responding. My directory looks correct, are there any dependencies I may be missing?
                I did read something in an earlier incarnation about the file naming system having to be basic without spaces ('joliet' stuff!!), it looks a bit more like an issue in that direction perhaps, paths & stuff....he says clutching at straws!!
                Error:]
                Error Loading File C:/Program Files/Google/Google SketchUp 8/Plugins/freedxf/freedxf.rb
                no such file to load -- inputboxError Loading File freedxf_ext.rb
                %(#0000FF)[.......The file is definitely there!
                Being skint takes up a lot of my time! Just can't justify the Pro version though so your help is much appreciated!]
                  JMdesigns
                  I am having the same problem? but it does not let me inmport
                    The download page's image is wrong !
                    There should also be the file
                    inputbox.rb
                    IF you get the latest zipped version of the tool it should include that file !
                    • T
                      Tenere
                      Bingo....your a star Tig
                      That sorted it, many thanks for your expertise. I'm raising a beer to you right now!....Hic!....well it is Friday!
                        juergen
                        Handling metric units would realy be a plus. It is easily possible to scale from metric to imperial but the reverse is no as easy as it requires to scale by a fractional number.
                        As all my DXFs are in cm I can not use FreeDXF.
                        Please consider supporting metric drawings.
                        PS: If somebody knows a way, please reply!
                          1" is 2.54cm
                          therefore
                          1cm is 0.393700787401574803" [1/2.54]
                          However, Sketchup's in-built accuracy regards 0.3937007" as being 'exactly' 1cm... so you can use that [or even 0.3937] as your scaling factor. After all we are talking about modeling 'buildings' here, not 'swiss-watches'...
                          • B
                            blackcat1313
                            Hi -
                            I am having trouble getting the plugin to run. I'm on a Mac running OSX 10.6.8 and Sketchup 8.0. I downloaded the latest version v0.57 and put the .rbz file in my plugin folder. There are lots of other plugins there, though no others of type rbz.
                            When I start Sketchup, there is no FreeDXF Importer item in the Plugins menu. I am probably missing something really simple -- I'm a pretty new Sketchup user. Any help is much appreciated! Thanks!
                            Bill
                            • pbacotP
                              Hi! try this:
                              Error 404 (Not Found)!!1
                              (support.google.com)
                              • B
                                blackcat1313
                                @pbacot said:
                                Hi! try this:
                                Doh - thanks for that, it's all working now!
                                Bill
                                • BraikenridgeB
                                  Braikenridge
                                  I have sketchup 8.0 free and have put this .rbz ruby into the plugins folder but its not appearing when I load sketchup. Incidentally, nowhere does it let you unzip it either? Am I missing something? i'm trying to import a vector file from scan2cad
                                  kind regards
                                    To use RBZ packages you need to install them using the Install Extension feature in SketchUp: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/#the-easy-way-8211-rbz-packages
                                      Jim
                                      I bumped the version to 0.7.1. For v0.7.0 I must have uploaded the wrong file. If your version says anything other than v0.7.1 then please update.
                                      Thanks.
                                        srknytgn
                                        import in cm or mm would be nice, thanks.
                                          Jim
                                          I agree, and I am working on it.
                                            πŸ’­ Rather than recode any stuff in the 'data-processing' could you have an opening dialog to just ask the user to choose the input 'units'?
                                            Then after the import is done [inside its own 'container' [definition]], you can simply apply an XYZ scaling transformation to the container's entities, based at the ORIGIN.
                                            A simple lookup list of 'scaling_factors' based on inches to feet/m/cm/mm is all that is needed to make a single 'transform_entities' ?
                                            You could also ask for the 'Keep-CAD-Origin?', or NOT. If not, then the entities can be transformed [translated] by the vector from their bounds.min back to the ORIGIN - i.e. the instance's insertion-point...
                                            • 3 / 8
