    [Plugin] FreeDXF Importer
    148 Posts 41 Posters 209.3k Views 41 Watching
      You are right.
      A DXF file gives objects layers, and those layers have colors.
      If you take the SKP layers the colors export as random colors.
      Even with similar SKPs newly made layers get unconnected colors.
      It's possible to rationalize a DXF by post processing it's text - I have a commercial tool I've written which uses the native DXF exporter, but where the client wanted all DXF layers to be consistently colored; so it has a 'lookup table' and ensures consistency by 'stream-editing' the DXF's text after it's made.
      Another way to have materials==colors is to export a custom made DXF but ignore the SKP's layers and using each material as if it were a DXF-layer... that way objects in the DXF are then grouped by each DXF 'layer' which is really made from the SKP's material-color rather than the proper SKP-layer...
        Jim
        Dec 2011 - I have removed the external dependency on my inputbox.rb - it is no longer required as a separate download. Also, I attached the download to the first post of this topic rather than linking to an external site. Hopefully, these changes will make it easier for folks to try.
          Is DXF extendable? I wonder if AutoDesk writes DXF with extra material info..?
            A DXF can include all the types of data that you get in a DWG file itself.
            However, as objects have layers and layers have colors, that's it.
            You can assign attributes to objects containing additional info, so you can pass [otherwise-unused] data... but how that's useful later on is questionable.
              I'm trying to find a good way to export a Revit model to SketchUp.
              I have tried exporting to FBX and then use Autodesk's converter utility to convert to DAE - but that fails on import every time on any model in SU. Fail in Blender as well.
              DWG and DXF import in SU - but uses layer material, as you describe. However, if I import the same DXF into another Autodesk application like 3DS - the materials are like how they where defined in Revit. And that is why I'm exploring this topic.
                Jim
                FreeDXF imports acad layers as SketchUp Groups, so it may be possible to color the Groups according to their acad layer color number.
                  syfyguy
                  It doesn't seem to work for me. I have Sketchup 8, with the new maintenance pack. It shows up in the plugins menu, then when executed it asks for arc segments, etc. When I click ok, nothing shows up. I'm using DWGeditor 2007 to create dxfs in ASCii 2007 format.
                    Jim
                    Can you post or send the file?
                    • T
                      Tenere
                      😒 %(#4000FF)[I've got a script not loading error on start with free version 8.0.4811.
                      I would assume I had the files in the right places although I can't see the folder layout image in the script posting - just an image name.
                      Bound to be missing the obvious, be grateful if someone could nudge me in the right direction......cheers.
                      Ooh one other question......Can I load the SU pro trial in tandem with my free version without bu#@ering it up or compromising the trial?....would quite like to see what I'm missing.] πŸ‘
                        Capture.PNG Does you Sketchup Plugins folder look like this ?
                        • T
                          Tenere
                          %(#0000FF)[πŸ‘ Hi Tig
                          Thanks for responding. My directory looks correct, are there any dependencies I may be missing?
                          I did read something in an earlier incarnation about the file naming system having to be basic without spaces ('joliet' stuff!!), it looks a bit more like an issue in that direction perhaps, paths & stuff....he says clutching at straws!!
                          Error:]
                          Error Loading File C:/Program Files/Google/Google SketchUp 8/Plugins/freedxf/freedxf.rb
                          no such file to load -- inputboxError Loading File freedxf_ext.rb
                          %(#0000FF)[.......The file is definitely there!
                          Being skint takes up a lot of my time! Just can't justify the Pro version though so your help is much appreciated!]
                            JMdesigns
                            I am having the same problem? but it does not let me inmport
                              The download page's image is wrong !
                              There should also be the file
                              inputbox.rb
                              IF you get the latest zipped version of the tool it should include that file !
                              • T
                                Tenere
                                Bingo....your a star Tig
                                That sorted it, many thanks for your expertise. I'm raising a beer to you right now!....Hic!....well it is Friday!
                                  juergen
                                  Handling metric units would realy be a plus. It is easily possible to scale from metric to imperial but the reverse is no as easy as it requires to scale by a fractional number.
                                  As all my DXFs are in cm I can not use FreeDXF.
                                  Please consider supporting metric drawings.
                                  PS: If somebody knows a way, please reply!
                                    1" is 2.54cm
                                    therefore
                                    1cm is 0.393700787401574803" [1/2.54]
                                    However, Sketchup's in-built accuracy regards 0.3937007" as being 'exactly' 1cm... so you can use that [or even 0.3937] as your scaling factor. After all we are talking about modeling 'buildings' here, not 'swiss-watches'...
                                    • B
                                      blackcat1313
                                      Hi -
                                      I am having trouble getting the plugin to run. I'm on a Mac running OSX 10.6.8 and Sketchup 8.0. I downloaded the latest version v0.57 and put the .rbz file in my plugin folder. There are lots of other plugins there, though no others of type rbz.
                                      When I start Sketchup, there is no FreeDXF Importer item in the Plugins menu. I am probably missing something really simple -- I'm a pretty new Sketchup user. Any help is much appreciated! Thanks!
                                      Bill
                                      • pbacotP
                                        Hi! try this:
                                        Error 404 (Not Found)!!1
                                        (support.google.com)
                                        • B
                                          blackcat1313
                                          @pbacot said:
                                          Hi! try this:
                                          Doh - thanks for that, it's all working now!
                                          Bill
                                          • BraikenridgeB
                                            Braikenridge
                                            I have sketchup 8.0 free and have put this .rbz ruby into the plugins folder but its not appearing when I load sketchup. Incidentally, nowhere does it let you unzip it either? Am I missing something? i'm trying to import a vector file from scan2cad
                                            kind regards
                                            • 3 / 8
