    [Plugin] FreeDXF Importer
    148 Posts 41 Posters 209.3k Views 41 Watching
      syfyguy
      It doesn't seem to work for me. I have Sketchup 8, with the new maintenance pack. It shows up in the plugins menu, then when executed it asks for arc segments, etc. When I click ok, nothing shows up. I'm using DWGeditor 2007 to create dxfs in ASCii 2007 format.
        Jim
        Can you post or send the file?
        • T
          Tenere
          😒 %(#4000FF)[I've got a script not loading error on start with free version 8.0.4811.
          I would assume I had the files in the right places although I can't see the folder layout image in the script posting - just an image name.
          Bound to be missing the obvious, be grateful if someone could nudge me in the right direction......cheers.
          Ooh one other question......Can I load the SU pro trial in tandem with my free version without bu#@ering it up or compromising the trial?....would quite like to see what I'm missing.] πŸ‘
            Capture.PNG Does you Sketchup Plugins folder look like this ?
            • T
              Tenere
              %(#0000FF)[πŸ‘ Hi Tig
              Thanks for responding. My directory looks correct, are there any dependencies I may be missing?
              I did read something in an earlier incarnation about the file naming system having to be basic without spaces ('joliet' stuff!!), it looks a bit more like an issue in that direction perhaps, paths & stuff....he says clutching at straws!!
              Error:]
              Error Loading File C:/Program Files/Google/Google SketchUp 8/Plugins/freedxf/freedxf.rb
              no such file to load -- inputboxError Loading File freedxf_ext.rb
              %(#0000FF)[.......The file is definitely there!
              Being skint takes up a lot of my time! Just can't justify the Pro version though so your help is much appreciated!]
                JMdesigns
                I am having the same problem? but it does not let me inmport
                  The download page's image is wrong !
                  There should also be the file
                  inputbox.rb
                  IF you get the latest zipped version of the tool it should include that file !
                  • T
                    Tenere
                    Bingo....your a star Tig
                    That sorted it, many thanks for your expertise. I'm raising a beer to you right now!....Hic!....well it is Friday!
                      juergen
                      Handling metric units would realy be a plus. It is easily possible to scale from metric to imperial but the reverse is no as easy as it requires to scale by a fractional number.
                      As all my DXFs are in cm I can not use FreeDXF.
                      Please consider supporting metric drawings.
                      PS: If somebody knows a way, please reply!
                        1" is 2.54cm
                        therefore
                        1cm is 0.393700787401574803" [1/2.54]
                        However, Sketchup's in-built accuracy regards 0.3937007" as being 'exactly' 1cm... so you can use that [or even 0.3937] as your scaling factor. After all we are talking about modeling 'buildings' here, not 'swiss-watches'...
                        • B
                          blackcat1313
                          Hi -
                          I am having trouble getting the plugin to run. I'm on a Mac running OSX 10.6.8 and Sketchup 8.0. I downloaded the latest version v0.57 and put the .rbz file in my plugin folder. There are lots of other plugins there, though no others of type rbz.
                          When I start Sketchup, there is no FreeDXF Importer item in the Plugins menu. I am probably missing something really simple -- I'm a pretty new Sketchup user. Any help is much appreciated! Thanks!
                          Bill
                          • pbacotP
                            Hi! try this:
                            Error 404 (Not Found)!!1
                            (support.google.com)
                            • B
                              blackcat1313
                              @pbacot said:
                              Hi! try this:
                              Doh - thanks for that, it's all working now!
                              Bill
                              • BraikenridgeB
                                Braikenridge
                                I have sketchup 8.0 free and have put this .rbz ruby into the plugins folder but its not appearing when I load sketchup. Incidentally, nowhere does it let you unzip it either? Am I missing something? i'm trying to import a vector file from scan2cad
                                kind regards
                                  To use RBZ packages you need to install them using the Install Extension feature in SketchUp: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/#the-easy-way-8211-rbz-packages
                                    Jim
                                    I bumped the version to 0.7.1. For v0.7.0 I must have uploaded the wrong file. If your version says anything other than v0.7.1 then please update.
                                    Thanks.
                                      srknytgn
                                      import in cm or mm would be nice, thanks.
                                        Jim
                                        I agree, and I am working on it.
                                          πŸ’­ Rather than recode any stuff in the 'data-processing' could you have an opening dialog to just ask the user to choose the input 'units'?
                                          Then after the import is done [inside its own 'container' [definition]], you can simply apply an XYZ scaling transformation to the container's entities, based at the ORIGIN.
                                          A simple lookup list of 'scaling_factors' based on inches to feet/m/cm/mm is all that is needed to make a single 'transform_entities' ?
                                          You could also ask for the 'Keep-CAD-Origin?', or NOT. If not, then the entities can be transformed [translated] by the vector from their bounds.min back to the ORIGIN - i.e. the instance's insertion-point...
                                            Jim
                                            Just updated to v 0.8.0 with a dialog for selecting the import units.
                                            • 3 / 8
