    1.5k Posts 471 Posters 3.3m Views 470 Watching
      It does indeed work on the current version of SketchUp. Did you open the groups or components for editing before trying to use it? Did you set the radius to something suitable for the object you're working on? It sounds like the answer to those questions would be, "no."
        @cipher_nemo said:
        Doesn't work for me. 😞 This plugin hasn't been updated in a while. Does it still work for the latest SketchUp version?
        Windows 7 Pro 64-bit
        SketchUp 8.0.15158
        LibFredo6 4.6c library
        RoundCorner 2.3a plugin
        The plugin loads fine, no errors. I can access it, and its separate toolbar pops up. But it doesn't work correctly...
        1.) It doesn't work on Components or Groups. Perhaps this is by design?
        2.) When I do have it work on separate objects, it just makes a total mess of them.
        What am I doing wrong? Thanks.
        Have you read any of the thread's posts ???
        RE-read the instructions.
        Have you got all of the supporting files that the download page tells you to get too ?
        Are there any Ruby Console error messages ??
        It works effortlessly on 'raw' geometry - i.e. things that are NOT inside 'containers'... BUT it will work inside 'containers' [groups/instances] if you are in 'edit mode'...
        You must select sensible 'settings' to get the 'rounding' you want.
        It will 'fail' on very very tiny OR very very enormous geometry, so what 'scale' of objects do you have ?
          cipher_nemo
          Thanks for the fast replies! 😄
          Here's an example, where I started a brand new workarea, made a rectangle, push/pulled it to give it depth, selected the edges and surface of one side, then did the RoundCorner icon...
          I reduced the window size to view only what's needed...
          http://modarmor.com/images/roundcorner_issue1a.png
          http://modarmor.com/images/roundcorner_issue1b.png
            So you have an offset of ~39-3/8 inches and your box isn't that big. As TIG said, go back and reread the instructions. 😒
            It looks like it is doing what you have it set to do.
              OK... you don't tell us how 'big' the face is that you want to round the edges on... but the 'radius' of the rounding looks quite large... so I suspect that it's greater than the face involved...
              Please look at your settings...
              Make 'roundings' that are going to work on the set of edges you are editing 😒
                cipher_nemo
                Ok, I feel like an idiot now, lol. I have to change the offset myself. I was testing it and expected a default value calculated on surface I selected. It works fine when I choose my own offset.
                There's a request for the OP/author then: a default calculated offset would be awesome. 😉 Then those testing it quickly wouldn't be confused like I was.
                  So what would that calculated offset be? Would it round over the entire selected surface or just put a radius on the edges? What would the calculated value be if more than one surface is selected and they are different sizes.
                  Really it isn't a big deal to set the offset or radius value manually for the job at hand.
                  It would be helpful when you test a plugin or anything else to have some idea of what you should get and reading the provided instructions goes a long way to tell you that. If you don't read the instructions to know how to use the plugin you won't know if your expectations of the results are valid or not.
                    cipher_nemo
                    Yeah, it's not a big deal now that I know what I'm doing. 😉
                    If anyone else tests out Fredo6's plugin and sees it doing something odd on the first run, they may not seek help. In turn they might give up without going in to change the offset. I just wanted to see what sort of job this plugin/script could do without getting further in to adjust things. Perhaps a first-time value that's something like 1/2, 1/4, or 1/8 of the offset selected would solve that new-to-RoundCorner confusion? After I went in there and set an offset the plugin remembers it, which is nice. In other words, once someone sees it work the first time, then they can play around with its adjustments to incorporate it into their work.
                      If someone gives up on a plugin or anything else because it doesn't give them the results they want and without reading the instructions, they deserve what they get. 😒
                      As to remembering the setting, it does for the current SketchUp setting. If you close SketchUp and reopen it, the default offset will return to the ~39-3/8" (1 meter).
                        benzkrichpol
                        WOW
                        • bagateloB Offline
                          bagatelo
                          Please consider these improvements....
                          • gullfoG Offline
                            gullfo
                            with the large number of profiles you should just get profile builder full version. works awesome... then hide the joining lines if you need it to blend in.
                            Glenn
                            http://www.runnel.com
                            • bagateloB Offline
                              bagatelo
                              I had already thought of this possibility before.
                              And I am currently trying this.
                              Is proving very interesting.
                              But as the fantastic plugin "Round Corner"
                              perhaps it would be interesting just the possibility that we can create
                              and edit our own profiles.
                              • fredo6F Offline
                                Bagatelo
                                The interest of RoundCorner is actually fro corners with 3 edges or more.
                                For simple profiling, ProfileBuilder or even the Follow tool can make the job.
                                RoundCorner can actually support custom profiles but they have to be symmetric in order to have a correct jonctions at corners with 3 edges. See this post and attached file for an example.
                                RoundCorner with custom profiles.skp
                                I did not activate the functionality as this needs some work for profile selection. But if there is enough interest I can do it.
                                • bagateloB Offline
                                  bagatelo
                                  I'm your biggest fan.
                                  • bagateloB Offline
                                    bagatelo
                                    Here we have some tests that I made.
                                    CRIADO MUDO.skp
                                      Yes please!
                                        • BurkhardB Offline
                                          Burkhard
                                          🎉 waiting 👍
                                          [http://www.ia-plus.de(http://www.ia-plus.de)]
                                          • H Offline
                                            hardwire
                                            I have been struggling for a day to install Roundcorner by Fredo.
                                            I have installed other plugins with no problem but this has defeated me.
                                            Can someone give me a step by step.
                                            Fredo's instructions just do not seem to work.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 73
                                            • 74
                                            • 12 / 74
