    1.5k Posts 477 Posters 4.0m Views 477 Watching
      cipher_nemo
      @dave r said:
      So what would that calculated offset be? Would it round over the entire selected surface or just put a radius on the edges? What would the calculated value be if more than one surface is selected and they are different sizes.
      Really it isn't a big deal to set the offset or radius value manually for the job at hand.
      It would be helpful when you test a plugin or anything else to have some idea of what you should get and reading the provided instructions goes a long way to tell you that.
      Yeah, it's not a big deal now that I know what I'm doing. 😉
      If anyone else tests out Fredo6's plugin and sees it doing something odd on the first run, they may not seek help. In turn they might give up without going in to change the offset. I just wanted to see what sort of job this plugin/script could do without getting further in to adjust things. Perhaps a first-time value that's something like 1/2, 1/4, or 1/8 of the offset selected would solve that new-to-RoundCorner confusion? After I went in there and set an offset the plugin remembers it, which is nice. In other words, once someone sees it work the first time, then they can play around with its adjustments to incorporate it into their work.
        If someone gives up on a plugin or anything else because it doesn't give them the results they want and without reading the instructions, they deserve what they get. 😒
        As to remembering the setting, it does for the current SketchUp setting. If you close SketchUp and reopen it, the default offset will return to the ~39-3/8" (1 meter).
          benzkrichpol
          WOW
          • bagateloB Offline
            bagatelo
            Please consider these improvements....
            • gullfoG Offline
              gullfo
              with the large number of profiles you should just get profile builder full version. works awesome... then hide the joining lines if you need it to blend in.
              Glenn
              http://www.runnel.com
              • bagateloB Offline
                bagatelo
                I had already thought of this possibility before.
                And I am currently trying this.
                Is proving very interesting.
                But as the fantastic plugin "Round Corner"
                perhaps it would be interesting just the possibility that we can create
                and edit our own profiles.
                • fredo6F Offline
                  Bagatelo
                  The interest of RoundCorner is actually fro corners with 3 edges or more.
                  For simple profiling, ProfileBuilder or even the Follow tool can make the job.
                  RoundCorner can actually support custom profiles but they have to be symmetric in order to have a correct jonctions at corners with 3 edges. See this post and attached file for an example.
                  RoundCorner with custom profiles.skp
                  I did not activate the functionality as this needs some work for profile selection. But if there is enough interest I can do it.
                  • bagateloB Offline
                    bagatelo
                    I'm your biggest fan.
                    • bagateloB Offline
                      bagatelo
                      Here we have some tests that I made.
                      CRIADO MUDO.skp
                        Yes please!
                          • BurkhardB Offline
                            Burkhard
                            🎉 waiting 👍
                            http://www.ia-plus.de
                            • H Offline
                              hardwire
                              I have been struggling for a day to install Roundcorner by Fredo.
                              I have installed other plugins with no problem but this has defeated me.
                              Can someone give me a step by step.
                              Fredo's instructions just do not seem to work.
                                I've relocated this post into the relevant thread...
                                It's quite straightforward - reread and follow the instructions, and also get/install the latest 'Lib' folder as directed [linked] in the first post's instructions...
                                OR since you have v8 then why not download/install thomthom's Simple Plugin Installer - available from the Plugins Index...
                                This automatically extracts the files and subfolders from ZIP archives and puts them into the correct places - it also works on RBZ/RBS and RB formats...
                                That way you avoid getting into a tangle with a mis-installed set !
                                Although if you have already manually installed some files in the wrong places you might need to do some 'tidying up' to prevent issues with files auto-loading from Plugins wrongly etc - but then it depends on the level of you screw-up!
                                • H Offline
                                  hardwire
                                  Thanks very much. All now installed and working.http://sketchucation.com/forums/posting.php?mode=quote&f=323&t=20485&p=433684#
                                    Caj
                                    I am trying to install roundcorner plugin for Sketchup 8 on Mac running 10.8.2
                                    When I start SU I get this message and am not able to fine toolbar or plugin:
                                    Cannot load plugin LibFredo6 because the script cannot create DEFPARAM_Dir folder in:
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins
                                    I read in a post that I need to create the folder manually, but when I go to the plugins folder, the menu option is not available to make "New Folder" (shift+command+N does not do anything either)
                                    How can I create this folder, or get this plugin to run??
                                      It sounds to me as if the Plugins folder is set as Read Only. It needs to be set as Read and Write.
                                        Caj
                                        You were correct in thinking the Plugins folder was set to read only, however even after changing that (to all users) the option for New Folder is not highlighted. I then went up the feeding chain to Sketchup, Google Sketchup 8, Application Support, Library, and Macintosh HD and changed those to read & write to see if that would make any difference. It did not.
                                        This seems like an unusual amount of tinkering to get a plugin to work?! Is this common?
                                          No. It isn't common. Your profile isn't very specific as to the OS you are using but I'll guess its Mountain Lion. I'm still using Snow Leopard and don't have any issues like this. You shouldn't have to make the changes agin, I don't think.
                                            Caj
                                            Yes, I am using Mountain Lion and it is fairly new to me. Even had trouble locating Library which they took out of finder for some reason!
                                            I had no luck manually installing new folder, but found ThomThom's Simple Plugin Installer, and was successful using that and re-installing zip file using that. Thanks for your help.
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 74
                                            • 75
                                            • 31 / 75
