    Artisan 2 Wishlist
    44 Posts 17 Posters 7.6k Views 17 Watching
    • W Offline
      Whaat
      @panixia said:
      will ever artisan support quad faces?
      or at least preserve it in case the proxy was properly created with thomthom quadface/vertex tools or fredo curviloft or tig extrusion tools or any other tools wich eventually generates quads? ❓
      it would be very useful for cleaner topology, faster selections, better texture mapping etc. πŸ‘
      I hope to add support for quad faces in a future version.
      • cottyC Offline
        cotty
        πŸ‘
        my SketchUp gallery
        • panixiaP Offline
          panixia
          πŸ‘
            Let me know if you got questions on the quads.
            • panixiaP Offline
              panixia
              • CarrozzaC Offline
                Carrozza
                Hi guys, I was wondering whether the next Artisan could get real-time feedback, like the good old subdivide-and-smooth plugin.
                Actually, I never understood why this useful feature was removed in the first place.
                • W Offline
                  Whaat
                  Hi Carrozza,
                  Actually the feature was never removed πŸ˜•
                  Make sure you have 'Create Proxy From Group' turned on in the 'Settings' dialog. Then, just create a group and apply the SDS tool to it.
                  • CarrozzaC Offline
                    Carrozza
                    Oops, I'd teach myself to RTFM... sorry.
                    Edit: how do I "discard" the proxy and commit the subdivided mesh? Enter doesn't do it.
                    This time I searched before asking but had no luck.
                    • CarrozzaC Offline
                      Carrozza
                      Ehm, I guess enough time passed after my question to make a bump.
                      Is it possible to commit a subdivision discarding the proxy?
                      • cottyC Offline
                        cotty
                        Do you want
                        1. to make a subdivision with a group proxy and delete the proxy afterwards or
                        2. to subdivide without the use of a group proxy?
                        answer 1: you can edit the group and delete the proxy geometry (see picture)
                        answer 2: you can subdivide in the context of the group (no proxy will be created)
                        my SketchUp gallery
                        • Bob JamesB Offline
                          Bob James
                          @jclements said:
                          For the tool that flattens a selection to a plane, have the ability to input a Z-value or click on a surface once, and use the Z-value of that point to serve as the height of the plane.
                          +1
                          • CarrozzaC Offline
                            Carrozza
                            Thank you Cotty, it was the first one.
                            Somehow I supposed that there was a "commit" command that would do this automatically, but manually deleting the proxy group is fine.
                              Panga
                              Don't know if it was asked before, but the ability to lock the contour edges of a selection could be really great !!
                                mwm5053
                                I just saw where Artisan 1.2 has been released.
                                2011 iMac
                                SU 2015 Pro, 2017 Make
                                V2 Twilight
                                macOS Sierra 10.12.5
                                  Panga
                                  Yes ! With the ability to crease boundaries !!! A dream's coming true !! Thanks a lot Whaat !!
                                  • pbacotP Offline
                                    @jclements said:
                                    In the context of terrain meshes and site grading, these are my requests.
                                    1- Allow the tools other than just the Smooth Selection function (such as the sculpt tool) not to move edges and vertices which have the crease attribute.
                                    2- Have an option for the strength value to correspond to an absolute value relative to the origin. This would allow the user to sculpt berms or scuplt a series of contours to specific elevations.
                                    I'm going to ask a question here in terms of a request. Maybe this is already possible.
                                    In the sculpt tool: flatten-- I can work a terrain down pretty well to "flat", and I imagine I'll get better at it-- but it takes some trial and error. I would like to be able to reference a face in the model and have artisan do subsequent sculpt flattening exactly at that plane. I'd like it to work the way Artisan seems to do already, where the edges transition smoothly out of the flattened area...
                                    I think that for terrain and other applications, it helps where Artisan sculpt tools can directly reflect or take advantage of guides in the model such as contours or laid-out slope framework, and form smooth transitions in the mesh to these forms.
                                    • W Offline
                                      Whaat
                                      Currently, in version 1.2, the first face that is clicked on will be the reference face for the flattening. By holding the SHIFT key and flattening, it will constrain all flattening to a horizontal plane. So, I think this request is already fulfilled in version 1.2 unless I am misunderstanding you.
                                      The Vertex move tool can utilize inferencing to guides and other geometry in your model so I suggest making use of it for this purposes. For example, to create a berm at a specific height:
                                      1. Select the area using the Select Brush
                                      2. Create a soft selection with the Vertex Select tool
                                      3. Use the Make Planar tool to flatten to the XY plane
                                      4. Use the Vertex Move tool to move the berm to the proper height (while doing so, you can snap to guides or contours)
                                      • pbacotP Offline
                                        Thanks for the advice, Dale. What a treat!
                                        In regards to the flatten technique, I gathered something like this was happening from my attempts. However within the terrain itself there may.....
                                        Excellent! I see that the way might be to use the select tool to designate the area, then one can start from a "sample" face on the side and move, with the mouse button down, to the area needing work. Can't wait to try these ideas out! Thanks!
                                        • 2 / 3
