    Artisan 2 Wishlist
    44 Posts 17 Posters 7.6k Views 17 Watching
    • soloS Offline
      Tesselation!
      I love to sculp with some sort of tesselation, nothing extreme as SU might buckle,but if possible to divide X2 when selected.
      • JClementsJ Offline
        JClements
        Perhaps some type of Patch and Subdivide Hole process for a closed loop of edges which would create a compatible mesh to blend in with the slope of bordering surfaces.
        This would be helpful for the surfacing of a top-most contour line or small areas the need to be "re-meshed".
        • soloS Offline
          Repair holes, I dunno if it's even possible but imagine if there was a way to fix those tiny holes that sometimes appears after subdivision.
            There's been some discussion about this with thomthom under the 'SolidInspector' posts... it MUST be possible - although it is NOT easy! πŸ˜’
            • panixiaP Offline
              panixia
              will ever artisan support quad faces?
              or at least preserve it in case the proxy was properly created with thomthom quadface/vertex tools or fredo curviloft or tig extrusion tools or any other tools wich eventually generates quads? ❓
              it would be very useful for cleaner topology, faster selections, better texture mapping etc. πŸ‘
                Panga
                My wish would be to be able to choose the shape of the brush. For the moment, or I missed something, the Brush is only a circle, I would love to see elispe, squarre or custom shapes used as brush pattern !!
                  hmm.... an idea form ... what about being able to define a shape by selected face?
                  • Bob JamesB Offline
                    Bob James
                    @jclements said:
                    Solo,
                    If you saw two Americans somewhere in Europe eating a hamburger and fries in a McDonalds, what does that tell you?
                    They're probably overweight πŸ‘Ώ
                      JClements
                      For the tool that flattens a selection to a plane, have the ability to input a Z-value or click on a surface once, and use the Z-value of that point to serve as the height of the plane.
                      • W Offline
                        Whaat
                        I hope to add support for quad faces in a future version.
                        • cottyC Offline
                          cotty
                          πŸ‘
                          my SketchUp gallery
                          • panixiaP Offline
                            panixia
                            πŸ‘
                              Let me know if you got questions on the quads.
                              • panixiaP Offline
                                panixia
                                • CarrozzaC Offline
                                  Carrozza
                                  Hi guys, I was wondering whether the next Artisan could get real-time feedback, like the good old subdivide-and-smooth plugin.
                                  Actually, I never understood why this useful feature was removed in the first place.
                                  • W Offline
                                    Whaat
                                    Hi Carrozza,
                                    Actually the feature was never removed πŸ˜•
                                    Make sure you have 'Create Proxy From Group' turned on in the 'Settings' dialog. Then, just create a group and apply the SDS tool to it.
                                    • CarrozzaC Offline
                                      Carrozza
                                      Oops, I'd teach myself to RTFM... sorry.
                                      Edit: how do I "discard" the proxy and commit the subdivided mesh? Enter doesn't do it.
                                      This time I searched before asking but had no luck.
                                      • CarrozzaC Offline
                                        Carrozza
                                        Ehm, I guess enough time passed after my question to make a bump.
                                        Is it possible to commit a subdivision discarding the proxy?
                                        • cottyC Offline
                                          cotty
                                          Do you want
                                          1. to make a subdivision with a group proxy and delete the proxy afterwards or
                                          2. to subdivide without the use of a group proxy?
                                          answer 1: you can edit the group and delete the proxy geometry (see picture)
                                          answer 2: you can subdivide in the context of the group (no proxy will be created)
                                          my SketchUp gallery
                                            Bob James
                                            +1
                                            • 2 / 3
