    Artisan 2 Wishlist
    44 Posts 17 Posters 6.7k Views 17 Watching
      baldaman
      Thank you for your answer Whaat,
      we could think about a code which could soften egdes of selection of faces or a group with a predetermined value.
      With a shortcut it would be fast to resoften edges at the desired angle value each time the subsurf is updated...
      • soloS Offline
        Tesselation!
        I love to sculp with some sort of tesselation, nothing extreme as SU might buckle,but if possible to divide X2 when selected.
        • JClementsJ Offline
          JClements
          Perhaps some type of Patch and Subdivide Hole process for a closed loop of edges which would create a compatible mesh to blend in with the slope of bordering surfaces.
          This would be helpful for the surfacing of a top-most contour line or small areas the need to be "re-meshed".
          • soloS Offline
            Repair holes, I dunno if it's even possible but imagine if there was a way to fix those tiny holes that sometimes appears after subdivision.
              There's been some discussion about this with thomthom under the 'SolidInspector' posts... it MUST be possible - although it is NOT easy! πŸ˜’
              • panixiaP Offline
                panixia
                will ever artisan support quad faces?
                or at least preserve it in case the proxy was properly created with thomthom quadface/vertex tools or fredo curviloft or tig extrusion tools or any other tools wich eventually generates quads? ❓
                it would be very useful for cleaner topology, faster selections, better texture mapping etc. πŸ‘
                  Panga
                  My wish would be to be able to choose the shape of the brush. For the moment, or I missed something, the Brush is only a circle, I would love to see elispe, squarre or custom shapes used as brush pattern !!
                    hmm.... an idea form ... what about being able to define a shape by selected face?
                    • Bob JamesB Offline
                      Bob James
                      @jclements said:
                      Solo,
                      If you saw two Americans somewhere in Europe eating a hamburger and fries in a McDonalds, what does that tell you?
                      They're probably overweight πŸ‘Ώ
                        JClements
                        For the tool that flattens a selection to a plane, have the ability to input a Z-value or click on a surface once, and use the Z-value of that point to serve as the height of the plane.
                        • W Offline
                          Whaat
                          I hope to add support for quad faces in a future version.
                          • cottyC Offline
                            cotty
                            πŸ‘
                            my SketchUp gallery
                            • panixiaP Offline
                              panixia
                              πŸ‘
                                Let me know if you got questions on the quads.
                                • panixiaP Offline
                                  panixia
                                  • CarrozzaC Offline
                                    Carrozza
                                    Hi guys, I was wondering whether the next Artisan could get real-time feedback, like the good old subdivide-and-smooth plugin.
                                    Actually, I never understood why this useful feature was removed in the first place.
                                    • W Offline
                                      Whaat
                                      Hi Carrozza,
                                      Actually the feature was never removed πŸ˜•
                                      Make sure you have 'Create Proxy From Group' turned on in the 'Settings' dialog. Then, just create a group and apply the SDS tool to it.
                                      • CarrozzaC Offline
                                        Carrozza
                                        Oops, I'd teach myself to RTFM... sorry.
                                        Edit: how do I "discard" the proxy and commit the subdivided mesh? Enter doesn't do it.
                                        This time I searched before asking but had no luck.
                                        • CarrozzaC Offline
                                          Carrozza
                                          Ehm, I guess enough time passed after my question to make a bump.
                                          Is it possible to commit a subdivision discarding the proxy?
                                          • cottyC Offline
                                            cotty
                                            Do you want
                                            1. to make a subdivision with a group proxy and delete the proxy afterwards or
                                            2. to subdivide without the use of a group proxy?
                                            answer 1: you can edit the group and delete the proxy geometry (see picture)
                                            answer 2: you can subdivide in the context of the group (no proxy will be created)
                                            my SketchUp gallery
                                            • 2 / 3
