    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 415.0k Views 92 Watching
      @rich o brien said:
      Any chance we can see pre picked verts dropped when hitting ESC and using the move tool?
      Use the Deselect command.
      • Rich O BrienR Online
        http://joyerickson.files.wordpress.com/2012/06/bug-spray.jpg
        • panixiaP Offline
          panixia
          @thomthom said:
          Version 1.1.2
          • Fixes a small undo bug.
          should i uninstall/delete the previous build or it overwrites when .rbz is loaded?
            It should overwrite it. To be sure you can type in the Ruby Console: TT_Vertex::PLUGIN_VERSION - it should return 1.1.2 is successful.
            • panixiaP Offline
              panixia
              ya ya it was just solved, thanks anyway. it overwrites fine. πŸ‘
                Version 1.1.3 Released
                • Fixes a Gizmo VCB adjustment bug.
                  Sorry where is the link for load the new beta ? 😳
                    No beta. Just log in to your account on the Vertex Tools website.
                    • cottyC Offline
                      cotty
                      It is possible to change the position of the screen text (top left) in a simple manner? It conflicts with the outputof the On Screen Rooling Reel plugin...
                      my SketchUp gallery
                        Did you try moving it? πŸ˜‰
                        • cottyC Offline
                          cotty
                          I thought of a not so simple solution 😎
                          Thank you! I will use this perfect solution until there is a complicated one...
                          my SketchUp gallery
                            Complicated solution:
                            1. Hack the RBS encryption and decode the original source.
                            2. Find the code for the default position.
                            3. Recompile.
                            4. Bob is you uncle!
                            πŸ€“
                            • mitcorbM Offline
                              mitcorb
                              Hi, ThomThom:
                              I just finished trolling through this entire thread, and I know I am missing something. In my first experiments with the tool, I make a random selection on the model and test the Gizmo. I orbit to the other side and see that I have also made a selection on the back side and deformed this in the same way. I thought there was a technique to select only that visible to the camera?
                                Enable "Ignore Backfaces" - where the vertices of every face with its backface facing the camera will not be selected.
                                Note this is not the same as what you see - it's entirely the relationship between the face normal and the camera.
                                To get true selection of only visible, Make your selection, then right click and choose "Select Only Visible".
                                http://www.thomthom.net/software/vertex_tools/manual/tools#select_only_visible
                                • mitcorbM Offline
                                  mitcorb
                                  Thank you very much for this hint and thank you very much for an excellent tool.
                                  • opalO Offline
                                    opal
                                    @mitcorb said:
                                    Hi, ThomThom:
                                    pokes nose in Unless something has changed, right click on the tool bar.. ignore backfaces, or access the controls from the tools menu.. same selection, ignore backfaces
                                    • jo-keJ Offline
                                      jo-ke
                                      Just purchased this very useful tool. Didn't had time to play with it but I'm shure I will like it.
                                      Thank you for your useful work.
                                      http://www.zz7.de
                                        πŸ‘ 😍 πŸ‘
                                        • Bob JamesB Offline
                                          Bob James
                                          I was using VT the other day to align some vertices one at a time to a straight edge and all of a sudden a small circle appeared in place of the cursor and I could move a vertex and just click on the next one and move it without having to go back to the select-tool/move-tool each time. I've not been able to find out how to get that little circle tool back. πŸ˜•
                                            If you have no verts selected and then activate the Move tool it goes into Hover Select mode and a little circle appears when you are over a vert to indicate it is selected.
                                            A shortcut to drop any selected verts is to right click and choose Select None. Now change to the move tool and this hover method is active.
                                            See you next month Bob πŸ˜‰
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 33
                                            • 34
                                            • 18 / 34
