    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 483.5k Views 92 Watching
      A great - I see my beautiful assistant Rich answered. πŸ˜‰
      Yea, the ESC thing to get back to selection radius isn't ideal. It's on my list of things to look into for improvement for next round.
      • Rich O BrienR Online
        Why thank you πŸ˜‰
        Any chance we can see pre picked verts dropped when hitting ESC and using the move tool?
          hmm...
          http://www.pathlabtalk.com/forum/images/smilies/paranoid.gif
            Version 1.1.2
            • Fixes a small undo bug.
              Use the Deselect command.
                http://joyerickson.files.wordpress.com/2012/06/bug-spray.jpg
                • panixiaP Offline
                  panixia
                  @thomthom said:
                  Version 1.1.2
                  should i uninstall/delete the previous build or it overwrites when .rbz is loaded?
                    It should overwrite it. To be sure you can type in the Ruby Console: TT_Vertex::PLUGIN_VERSION - it should return 1.1.2 is successful.
                    • panixiaP Offline
                      panixia
                      ya ya it was just solved, thanks anyway. it overwrites fine. πŸ‘
                        Version 1.1.3 Released
                        • Fixes a Gizmo VCB adjustment bug.
                          Sorry where is the link for load the new beta ? 😳
                            No beta. Just log in to your account on the Vertex Tools website.
                            • cottyC Offline
                              cotty
                              It is possible to change the position of the screen text (top left) in a simple manner? It conflicts with the outputof the On Screen Rooling Reel plugin...
                              my SketchUp gallery
                                Did you try moving it? πŸ˜‰
                                • cottyC Offline
                                  cotty
                                  I thought of a not so simple solution 😎
                                  Thank you! I will use this perfect solution until there is a complicated one...
                                  my SketchUp gallery
                                    Complicated solution:
                                    1. Hack the RBS encryption and decode the original source.
                                    2. Find the code for the default position.
                                    3. Recompile.
                                    4. Bob is you uncle!
                                    πŸ€“
                                    • mitcorbM Offline
                                      mitcorb
                                      Hi, ThomThom:
                                      I just finished trolling through this entire thread, and I know I am missing something. In my first experiments with the tool, I make a random selection on the model and test the Gizmo. I orbit to the other side and see that I have also made a selection on the back side and deformed this in the same way. I thought there was a technique to select only that visible to the camera?
                                        Enable "Ignore Backfaces" - where the vertices of every face with its backface facing the camera will not be selected.
                                        Note this is not the same as what you see - it's entirely the relationship between the face normal and the camera.
                                        To get true selection of only visible, Make your selection, then right click and choose "Select Only Visible".
                                        http://www.thomthom.net/software/vertex_tools/manual/tools#select_only_visible
                                        • mitcorbM Offline
                                          mitcorb
                                          Thank you very much for this hint and thank you very much for an excellent tool.
                                          • opalO Offline
                                            opal
                                            @mitcorb said:
                                            Hi, ThomThom:
                                            pokes nose in Unless something has changed, right click on the tool bar.. ignore backfaces, or access the controls from the tools menu.. same selection, ignore backfaces
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 33
                                            • 34
                                            • 12 / 34
