    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 655.8k Views 92 Watching
      @thomthom said:
      I see my beautiful assistant Rich answered. πŸ˜‰
      Why thank you πŸ˜‰
      Any chance we can see pre picked verts dropped when hitting ESC and using the move tool?
        hmm...
        http://www.pathlabtalk.com/forum/images/smilies/paranoid.gif
          Version 1.1.2
          • Fixes a small undo bug.
            Use the Deselect command.
              http://joyerickson.files.wordpress.com/2012/06/bug-spray.jpg
              • panixiaP
                panixia
                @thomthom said:
                Version 1.1.2
                should i uninstall/delete the previous build or it overwrites when .rbz is loaded?
                  It should overwrite it. To be sure you can type in the Ruby Console: TT_Vertex::PLUGIN_VERSION - it should return 1.1.2 is successful.
                  • panixiaP
                    panixia
                    ya ya it was just solved, thanks anyway. it overwrites fine. πŸ‘
                      Version 1.1.3 Released
                      • Fixes a Gizmo VCB adjustment bug.
                        Sorry where is the link for load the new beta ? 😳
                          No beta. Just log in to your account on the Vertex Tools website.
                          • cottyC
                            cotty
                            It is possible to change the position of the screen text (top left) in a simple manner? It conflicts with the outputof the On Screen Rooling Reel plugin...
                            my SketchUp gallery
                              Did you try moving it? πŸ˜‰
                              • cottyC
                                cotty
                                I thought of a not so simple solution 😎
                                Thank you! I will use this perfect solution until there is a complicated one...
                                my SketchUp gallery
                                  Complicated solution:
                                  1. Hack the RBS encryption and decode the original source.
                                  2. Find the code for the default position.
                                  3. Recompile.
                                  4. Bob is you uncle!
                                  πŸ€“
                                  • mitcorbM
                                    mitcorb
                                    Hi, ThomThom:
                                    I just finished trolling through this entire thread, and I know I am missing something. In my first experiments with the tool, I make a random selection on the model and test the Gizmo. I orbit to the other side and see that I have also made a selection on the back side and deformed this in the same way. I thought there was a technique to select only that visible to the camera?
                                      Enable "Ignore Backfaces" - where the vertices of every face with its backface facing the camera will not be selected.
                                      Note this is not the same as what you see - it's entirely the relationship between the face normal and the camera.
                                      To get true selection of only visible, Make your selection, then right click and choose "Select Only Visible".
                                      http://www.thomthom.net/software/vertex_tools/manual/tools#select_only_visible
                                      • mitcorbM
                                        mitcorb
                                        Thank you very much for this hint and thank you very much for an excellent tool.
                                        • opalO
                                          opal
                                          @mitcorb said:
                                          Hi, ThomThom:
                                          pokes nose in Unless something has changed, right click on the tool bar.. ignore backfaces, or access the controls from the tools menu.. same selection, ignore backfaces
                                          • jo-keJ
                                            jo-ke
                                            Just purchased this very useful tool. Didn't had time to play with it but I'm shure I will like it.
                                            Thank you for your useful work.
                                            http://www.zz7.de
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 33
                                            • 34
                                            • 12 / 34
