    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 655.8k Views 92 Watching
    • panixiaP
      panixia
      thomthom, i can't stop to play with this, i'm trying every single tool and stuff and they are all very amazing and intuitive to use.
      πŸ’­ i noticed only a strange beahaviour i can't quite understand:
      if i select a loop with QFT and then enter VT, the selection/gizmo tool is active and the VCB is showing the "Soft Selection Radius" so that one can adjust it, then for example i move the selection+soft selection and the VCB shows the "Distance" so that one can easily adjust the movement itself.
      Ok, let's pretend now i want to move the ring in another direction, this time with a different soft selection radius, i click on the selection tool in VT floating toolbar and the VCB shows again "Soft Selection Radius" so one think he can adjust the radius again.. BUT i input the new radius and press enter and the tool just act like the previous "move" (or rotate or wathever the previous operation was) is still active and just continue to move it in the same direction such as "Distance" is still actually active in the VCB, instead of modify the selection radius as desired.
      i have to exit the tool, re-select the ring again and then re-open VT and re-enter the radius to make it work again and change the amount of vertice soft-selected.
      am i missing someting in the correct soft-radius adjusting or is it a little bug?
        Hit ESC after the Move to return to soft selection.
        • panixiaP
          panixia
          you are right, it works fine if you hit esc and is also faster than click on the toolbar! thank you!
            No hassle. It's a great tool
            • panixiaP
              panixia
              @rich o brien said:
              It's a great tool
              yes it is! and very funny too.. πŸ‘
                A great - I see my beautiful assistant Rich answered. πŸ˜‰
                Yea, the ESC thing to get back to selection radius isn't ideal. It's on my list of things to look into for improvement for next round.
                  Why thank you πŸ˜‰
                  Any chance we can see pre picked verts dropped when hitting ESC and using the move tool?
                    hmm...
                    http://www.pathlabtalk.com/forum/images/smilies/paranoid.gif
                      Version 1.1.2
                      • Fixes a small undo bug.
                        Use the Deselect command.
                          http://joyerickson.files.wordpress.com/2012/06/bug-spray.jpg
                          • panixiaP
                            panixia
                            @thomthom said:
                            Version 1.1.2
                            should i uninstall/delete the previous build or it overwrites when .rbz is loaded?
                              It should overwrite it. To be sure you can type in the Ruby Console: TT_Vertex::PLUGIN_VERSION - it should return 1.1.2 is successful.
                              • panixiaP
                                panixia
                                ya ya it was just solved, thanks anyway. it overwrites fine. πŸ‘
                                  Version 1.1.3 Released
                                  • Fixes a Gizmo VCB adjustment bug.
                                    Sorry where is the link for load the new beta ? 😳
                                      No beta. Just log in to your account on the Vertex Tools website.
                                      • cottyC
                                        cotty
                                        It is possible to change the position of the screen text (top left) in a simple manner? It conflicts with the outputof the On Screen Rooling Reel plugin...
                                        my SketchUp gallery
                                          Did you try moving it? πŸ˜‰
                                          • cottyC
                                            cotty
                                            I thought of a not so simple solution 😎
                                            Thank you! I will use this perfect solution until there is a complicated one...
                                            my SketchUp gallery
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 33
                                            • 34
                                            • 12 / 34
