    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 652.1k Views 135 Watching
    • brodieB
      brodie
      @jgb said:
      This is also a question, based on the above.
      Using SCALE, you can just type a percentage value in the VCB. This is handy to set a specific scale factor like 92%. It is also handy to set a scale factor that is between SCALE's preset snap tolerance of .1% so just type 90.15 in the VCB where SCALE snaps only to 90.1% or 90.2% and you need the precision.
      OK, my question, How do I set scale to a dimensional value?
      ie: my object is 12 inches, and I want it to be 13 inches, without doing the percentage math. AND I am holding the CTRL and SHIFT keys down to scale all and from the center. When I release the mouse button to type, my position is lost.
      Make sure your object is a group/component. Double click it so you're inside the group and use the tape measure to measure your 12" segment. The VCB will report back that it's 12". Now just type 13" and hit enter. A dialogue will pop up asking "do you want to resize the active group or component?" Hit yes and you're home free πŸ˜„
      This works wonderfully when you get a 'not to scale' drawing that you need to be to scale.
      -Brodie
      • jgbJ
        jgb
        @tig said:
        I beg to differ. πŸ˜•
        I can successfully Scale an object to exactly 13" using the " suffix.
        Pick a point to scale it by an arbitrary amount - 1.1 say - commit the scaling - THEN type 13" to apply the desired exact dimension...
        What are your unit-settings ? I have tried virtually every combo and they all let me enter 13" successfully ??
        Saw my error....
        I would scale approx, then enter 13". The 13 would vanish. πŸ‘Ž
        I need to Left Click after the approx setting, then while the scale box was still active, enter 13", and it worked. πŸ‘ πŸ‘ "Minor detail" 😳
        Brodie; β˜€ β˜€ πŸ‘ πŸ‘
        Thank you all.
        jgb
        • brodieB
          brodie
          @tig said:
          Pull out to approximate size [using any modifier keys you desire], then immediately type in the required size, before selecting another tool.
          The length has to have a 'units suffix'.
          Type 13 will make it 13x bigger ! but 13" makes it exactly 13 inches, or 330mm which makes it exactly that size in mm, this is done irrespective of the model's current-unit settings...
          Nice tip, I didn't know that one. πŸ‘
          So many SU easter eggs.
          -Brodie
          • cottyC
            cotty
            Here is a nice trick from Jean for rotation axis inferencing.
            my SketchUp gallery
              Yes but see this epic thread about the insufficiency of the Rotate tool inferency! πŸ˜‰
              • charly2008C
                charly2008
                I just got the "SketchUp 7 Bible" scrolled once again. At the "Move Tool" I looked more closely. I did not know that you can also use the tool to make multiple copies of objects.
                • boofredlayB
                  boofredlay
                  Oh yes and if you copy the object then type in 10/ you will get copies divided equally between the two distances. πŸ‘
                  • GaieusG
                    Ah yes, with the Move tool it's called a "Linear array" - but you can also do similar "Radial array" with the Rotate tool
                      And it's the same with the rotation Tool πŸ˜‰
                      But seems also that is the first thing that we learn when we start SU! πŸ˜‰
                      Don't use multiple copy in SU is very mysterious πŸ˜„
                      • majidM
                        majid
                        amazin part is that you can type:
                        X5
                        5X
                        5
                        0r 5
                        and they reffer to same result!!!! ( array )
                        • jgbJ
                          jgb
                          I've used that a lot, BUT, I can't seem to radial array within a 360 circle. πŸ˜•
                          As I reach 359.999 it jumps to zero degrees, and "/x" returns nothing.
                          I know I'm missing something here. ❓
                          I usually solve it by first making a circle with the number of segments I want, then radially array the object to a vertex, and multiply (total number wanted less 1), then delete the circle.
                          jgb
                          • boofredlayB
                            boofredlay
                            Start your array and type 360 for the degrees and hit enter rather than clicking to enter the degrees. Then do your multiplier.
                              1. Copy rotate to any random angle
                              2. Adjust angle with VCB to 360
                              3. Use VCB to divide the full rotation by number of elements ( / 7 )
                              Or, if you know the angle between each element, just rotate by the first segment.
                              1. Copy Rotate 45 degrees
                              2. *7
                              • GaieusG
                                One note however. If you use the divide function around a full 360 degrees and first you rotate the component by 360 degrees, you will end up with two, overlapping components in position 0 (or 360). This is not a serious issue as after the rotation and radial array, this firstly copied component will remain highlighted so just make sure that after the radial array, also press the Delete button.
                                  True, I used loose geometry in my test.
                                  • GaieusG
                                    Well, true, thatmerges with no trace left.
                                    • jgbJ
                                      jgb
                                      😍 That worked... Many thanks. πŸ‘ πŸ‘ πŸ‘
                                      TT & Gaieus, thanks as well. That duplicate copy over the original used to be a problem, till I started using a circle with the right # of segments to get around it.
                                      jgb
                                        Super cool never thought to bend a 2D image with the Fredo Scale! πŸ‘ 😎
                                          Roger
                                          [attachment=0:39d35j95]<!-- ia0 -->cool.jpg<!-- ia0 -->[/attachment:39d35j95]
                                          You bent over backward to discover that function. 🀣 (Does not translate easily to French)
                                          http://www.azcreative.com
                                            I believe that I understand that you want to say πŸ˜„
                                            Contortionist Zlata up the steps of the Cannes Film Festival! 😲
                                            http://www.pourlefan.eu/photos/1568823771.jpeg
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 34
                                            • 35
                                            • 22 / 35
