    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 652.1k Views 135 Watching
    • cottyC
      cotty
      Here is a nice trick from Jean for rotation axis inferencing.
      my SketchUp gallery
        Yes but see this epic thread about the insufficiency of the Rotate tool inferency! πŸ˜‰
        • charly2008C
          charly2008
          I just got the "SketchUp 7 Bible" scrolled once again. At the "Move Tool" I looked more closely. I did not know that you can also use the tool to make multiple copies of objects.
          • boofredlayB
            boofredlay
            Oh yes and if you copy the object then type in 10/ you will get copies divided equally between the two distances. πŸ‘
            • GaieusG
              Ah yes, with the Move tool it's called a "Linear array" - but you can also do similar "Radial array" with the Rotate tool
                And it's the same with the rotation Tool πŸ˜‰
                But seems also that is the first thing that we learn when we start SU! πŸ˜‰
                Don't use multiple copy in SU is very mysterious πŸ˜„
                • majidM
                  majid
                  amazin part is that you can type:
                  X5
                  5X
                  5
                  0r 5
                  and they reffer to same result!!!! ( array )
                  • jgbJ
                    jgb
                    I've used that a lot, BUT, I can't seem to radial array within a 360 circle. πŸ˜•
                    As I reach 359.999 it jumps to zero degrees, and "/x" returns nothing.
                    I know I'm missing something here. ❓
                    I usually solve it by first making a circle with the number of segments I want, then radially array the object to a vertex, and multiply (total number wanted less 1), then delete the circle.
                    jgb
                    • boofredlayB
                      boofredlay
                      Start your array and type 360 for the degrees and hit enter rather than clicking to enter the degrees. Then do your multiplier.
                        1. Copy rotate to any random angle
                        2. Adjust angle with VCB to 360
                        3. Use VCB to divide the full rotation by number of elements ( / 7 )
                        Or, if you know the angle between each element, just rotate by the first segment.
                        1. Copy Rotate 45 degrees
                        2. *7
                        • GaieusG
                          One note however. If you use the divide function around a full 360 degrees and first you rotate the component by 360 degrees, you will end up with two, overlapping components in position 0 (or 360). This is not a serious issue as after the rotation and radial array, this firstly copied component will remain highlighted so just make sure that after the radial array, also press the Delete button.
                            True, I used loose geometry in my test.
                            • GaieusG
                              Well, true, thatmerges with no trace left.
                              • jgbJ
                                jgb
                                😍 That worked... Many thanks. πŸ‘ πŸ‘ πŸ‘
                                TT & Gaieus, thanks as well. That duplicate copy over the original used to be a problem, till I started using a circle with the right # of segments to get around it.
                                jgb
                                  Super cool never thought to bend a 2D image with the Fredo Scale! πŸ‘ 😎
                                    Roger
                                    [attachment=0:39d35j95]<!-- ia0 -->cool.jpg<!-- ia0 -->[/attachment:39d35j95]
                                    You bent over backward to discover that function. 🀣 (Does not translate easily to French)
                                    http://www.azcreative.com
                                      I believe that I understand that you want to say πŸ˜„
                                      Contortionist Zlata up the steps of the Cannes Film Festival! 😲
                                      http://www.pourlefan.eu/photos/1568823771.jpeg
                                        Roger
                                        Boggles the imagination!
                                          ArCAD-UK
                                          @pbacot said:
                                          I can make a new layer via the Entities window simply by assigning the selected entity by typing a new layer name.
                                          Not on the PC you can't. πŸ˜•
                                          • pbacotP
                                            I can make a new layer via the Entities window simply by assigning the selected entity and typing a new layer name. Did it by mistake. πŸ˜„ Never knew.
                                            I thought this thread was a sticky, until I went looking for it...
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 34
                                            • 35
                                            • 22 / 35
