    [Example] V-Ray Displacement
    renderpluginsextensions
    54 Posts 27 Posters 179.0k Views 27 Watching
      Yea - I never liked displacement grass anyway. Just end up looking like a spikestrip.
      I assign a colour to the Colour ID of the material and render out a Material ID pass which I use in Photoshop as a mask where I overlay real grass from photos.
        @andybot said:
        which you can see a tutorial I did a while back on that method.
        πŸ‘ πŸ‘
          Moderat
          Yes, seems a lot easier to do it post-rendering. Thanks, I'll be using it for my grass.
          Now I've been trying again to get my (sea)water working. I managed to let vray render my material, but now it's coming out all wrong.
          It looks exactly the same in the preview in material editor as in the youtube tutorial (http://youtu.be/vbHdi5bEdlI), but when rendering it comes out very pure blue and not transparent. I redid the whole process 3 times.. still the same result.
          Anyone an idea? I'm really getting tired of this same kind of problem over and over again πŸ˜„.
          http://www.mediafire.com/?52she3kywadj4yz
          (I copied the water to another file so my SU-file isn't too big to download. )
          Now to bed! 3 am here.
          Thanks in advance,
          Bert
          • majidM Offline
            majid
            dear mate, do you mind to try this one?
            it is just a quick tweak over glass material..... I'vnt changed the refraction IOR ( it is now 1.5 and must be 1.3 for real water) so you may yourself do it... or maybe you prefer a differend wave "size" on bumb section
            waterminipack.zip
            • Whiteowl77W Offline
              Whiteowl77
              Hi Thomas, SU Modelers
              I am working on an exterior Rendering of a residence and currently working on the materials and textures. I have created my own custom stone from a photo I took and manipulated in photoshop. I was able to manipulate the displacement/bump-map images needed for that as well, as I found some good video tutorials on such.
              I am wondering: Are there any repositories/resources for SketchUp/Vray exterior material displacement/bump-map images (alpha channel), or does the artist need to make each one him/herself?
              Can you recommend any settings for painted wood siding -- I downloaded some siding from: http://www.vray-materials.de/register_complete.php?regkey=923c1bebe6cc014330075ecca8a6f87f -- but , as mentioned above, this is formatted for 3DS Max not SU. I am trying to use it regardless to create the displacement image. I cannot get the image to tile or repeat, or any effect to take place. I dont want to use the "out of the box" siding material in SketchUp due to the continuios lines that make up the generic pattern.
              Maybe, I will take the siding image texture material in SU, save it, edit it in Photoshop, and use the B&W/grayscale to make the displacement, and then leave the material fill color/diffuse a solid color, and see if that renders correctly.
              Any thoughts?
              Whats the best way to render/depict exterior siding?
              Andrew
              • broomstickB Offline
                broomstick
                Hi there! Can you tell me exactly which siding material you are trying to use? I'll have a go to convert it into vismat πŸ˜‰
                  penumbra
                  @andybot. Would love to see that tutorial. Link appears to be dead?
                  • andybotA Offline
                    andybot
                    Edit: updated link (I changed my blog domain name recently)
                    • andybotA Offline
                      andybot
                      Thanks for pointing that out, πŸ‘ I've fixed it in my post.
                      the correct link is
                      http://charlottesvillearchitecturalrendering.com/?p=127
                        penumbra
                        Nice site Andy. And clean tutorial. Done any work with Nelson Byrd Wolf? They are doing some landscape architectures in a couple of our projects.
                        Omar
                          krschncrlo
                          hi, i had this problem in displacement, whenever im trying to render curves, it comes out segmented
                          look at the yellow pillow
                            jackwatson
                            Something useful to consider when creating a displacement map, courtesy of http://viscorbel.com/vray-materials-theory/#comment-6946
                            "The deformations work like this – middle grey [128;128;128] of the map does not change anything on the object, darker values push the surface inwards while lighter values pull it out. The further this value is from medium gray, the stronger is the effect. Color of the map is not taken into account and only the lightness value is used."
                            This is good to know when you don't want the geometry created by the displacement to extend beyond the modelling you've laid out... eg bricks protruding though picture frames hanging on the wall
                            • TedVitale_CGT Offline
                              TedVitale_CG
                              @moderat said:
                              I switched the displacement multiplier up to 50, but it doesn't change a thing.
                              I created a grey rectangle outside my model to check if it would work there (so it isn't connected to another material).. still the same?
                              Can someone check my sketchup file? Really stuck here. As far as I know I'm not using any groups for the model, maybe by accidence a while ago (been working on it for quite some time now..).
                              http://www.mediafire.com/?pxmhwih5p0t5li3
                              (if you open it, does it look like a heavy file? Sketchup blocks from time to time for a minute or 2..)
                              Thank you!
                              Bert
                              When sharing files, remember to use the "Pack Scene" tool in V-Rays tools. You can find it by going Plugins>V-Ray>Pack Scene. This will ensure your scene has all required materials and textures. The scene you shared does not have the associated displacement map you are using so I cant accurately test or check anything.
                              Also, download and try out the grass file I've attached.
                              Grass with Displacement
                              Ted Vitale
                              Owner | Creative Director
                              http://www.voxl.vision
                                Oh neat! When was that feature added?
                                That might cause people to think it's a feature of my "V-Ray Tools" plugin... πŸ˜‰
                                  toninhox
                                  Hello i have this problem with my displacement map
                                  https://db.tt/bMHRwE9M
                                  why is that happen? any help? pleeesa XD
                                  Obs. itΒ΄s a night scene πŸ˜„
                                  • Z Offline
                                    zazracnedieta
                                    hi guys.. try this way πŸ˜‰
                                    try this :)
                                      kenancakir
                                      This is my displacement try.. Sketchup 2015 and vray 2.0..
                                        luziusalbin
                                        this is cool, how did you do it? can you share the material/texture?
                                          kenancakir
                                          Thank you.. Here is my tutorial..
                                          • 3 / 3
