    [Example] V-Ray Displacement
    renderpluginsextensions
    54 Posts 27 Posters 176.9k Views 27 Watching
      penumbra
      Nice site Andy. And clean tutorial. Done any work with Nelson Byrd Wolf? They are doing some landscape architectures in a couple of our projects.
      Omar
        krschncrlo
        hi, i had this problem in displacement, whenever im trying to render curves, it comes out segmented
        look at the yellow pillow
          jackwatson
          Something useful to consider when creating a displacement map, courtesy of http://viscorbel.com/vray-materials-theory/#comment-6946
          "The deformations work like this – middle grey [128;128;128] of the map does not change anything on the object, darker values push the surface inwards while lighter values pull it out. The further this value is from medium gray, the stronger is the effect. Color of the map is not taken into account and only the lightness value is used."
          This is good to know when you don't want the geometry created by the displacement to extend beyond the modelling you've laid out... eg bricks protruding though picture frames hanging on the wall
          • TedVitale_CGT Offline
            TedVitale_CG
            @moderat said:
            I switched the displacement multiplier up to 50, but it doesn't change a thing.
            I created a grey rectangle outside my model to check if it would work there (so it isn't connected to another material).. still the same?
            Can someone check my sketchup file? Really stuck here. As far as I know I'm not using any groups for the model, maybe by accidence a while ago (been working on it for quite some time now..).
            http://www.mediafire.com/?pxmhwih5p0t5li3
            (if you open it, does it look like a heavy file? Sketchup blocks from time to time for a minute or 2..)
            Thank you!
            Bert
            When sharing files, remember to use the "Pack Scene" tool in V-Rays tools. You can find it by going Plugins>V-Ray>Pack Scene. This will ensure your scene has all required materials and textures. The scene you shared does not have the associated displacement map you are using so I cant accurately test or check anything.
            Also, download and try out the grass file I've attached.
            Grass with Displacement
            Ted Vitale
            Owner | Creative Director
            http://www.voxl.vision
              Oh neat! When was that feature added?
              That might cause people to think it's a feature of my "V-Ray Tools" plugin... πŸ˜‰
                toninhox
                Hello i have this problem with my displacement map
                https://db.tt/bMHRwE9M
                why is that happen? any help? pleeesa XD
                Obs. itΒ΄s a night scene πŸ˜„
                • Z Offline
                  zazracnedieta
                  hi guys.. try this way πŸ˜‰
                  try this :)
                    kenancakir
                    This is my displacement try.. Sketchup 2015 and vray 2.0..
                      luziusalbin
                      this is cool, how did you do it? can you share the material/texture?
                        kenancakir
                        Thank you.. Here is my tutorial..
                        • 3 / 3
