    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 296.2k Views 135 Watching
      ArCAD-UK
      Just discovered in Layout 3 that if you select a block of text and right click (PC) there is a "Size to Fit" option which retains the text block width but extends the box height to show all the text. The amount of time I've spent manually adjusting my text boxes when the contents have been edited... 😳
        rv1974
        The 'Lock\unlock aspect ratio' at material edit drove me crazy for years.
        Clicking it wont change visually its state (stupid bug!). To see it changed one should move
        the cursor off the button.
        • I Offline
          iecovert
          %(#400080)[ALL toolbars can be mounted on the top OR the side! Not just the SU tools.
          I've got an increasing number of toolbars mounted up top since that's the way they first show up when a plugin is installed. The decreasing workspace was becoming an issue. The original SU toolbars mount vertically, so I set out to figure out how I could make the new Ruby and plugin toolbars mount vertically too. That seems to make more sense with a widescreen monitor. Spent several hours searching through the forums, help topics, and eventually digging into various Ruby scripts trying to figure it out over the past two weeks. Then last night I was moving a floating toolbar window and grabbed it a little to close to the edge and... it "stretched" out vertically. 🀣 Finally...]
            Aerilius
            (This belongs probably also into the developers forums:)
            window.onerror = function(errorMsg, url, lineNumber){ return true }
            This catches WebDialog script error popups (should they still sometimes occur after thorough testing)!
            Why didn't I find that before?
            Note: It needs to be assigned directly to %(#000000)[window] and not attached like %(#000000)[$(window).bind("error", function(){})].
              Interesting. I do not have that "duh moment" reading this. πŸ˜†
              • jeff hammondJ Offline
                same here… more like an "uhhhhh πŸ˜• moment"
                πŸ˜†
                • kenK Offline
                  ken
                  I guess I could call this "The Well I'll be Darn Thread". I have used Sketchup since V 4. And I know that the text tool will give me info on geometry. Like length, area, but today, surprise, I used the text tool on the apex of an angle and I got the following, the degrees of the angle in the text box. Never saw that before, and I would have an illustration to show you if I could get the text tool to do it again.
                  Ken
                    I was reading a topic and realized that I did not understand a word.
                    Then looked up and also realized I was in the Developers Forum. πŸ˜’
                      0101011101101000011000010111010000101100001000000111100101101111011101010010000001100100011011110010000001101110011011110111010000100000011101010110111001100100011001010111001001110011011101000110000101101110011001000010000001100010011010010110111001100001011100100111100100111111
                        Didn't you mean
                        010110010110111101110101001000000110010001101111001000000110111001101111011101000010000001110101011011100110010001100101011100100111001101110100011000010110111001100100001000000110001001101001011011100110000101110010011110010010000000100001
                        πŸ˜• πŸ˜‰
                        • Rich O BrienR Online
                          01101000 01101111 01110111 00100000 01110010 01110101 01100100 01100101 00100001
                            It wasn't... but
                            0100011001100101011000110110101100100000011010010111001100100000011100100111010101100100011001010010000000100001
                              mrossk
                              I think I got geek all over me πŸ˜‰
                              https://www.mkaplanfinefurniture.com/
                                πŸ’š
                                	100001
                                	11000
                                	1110
                                	100011
                                	1100
                                	10001
                                	100100
                                	11110
                                  Found a cool one today.
                                  Copy a line over and type 6" to set the distance. Then type *10 to array it 10 times.
                                  What I already knew was that you can type *8 or *4 or whatever to adjust the number of arrayed items.
                                  However I just found out that if you type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
                                  -Brodie
                                  Duh!
                                  That is sweet!
                                  The manual doesn't even mention this!
                                  http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94863
                                  • H Offline
                                    Heaps
                                    It even works with circular arrays - just type in the angle in degrees
                                    • brodieB Offline
                                      brodie
                                      However I just found out that if you then type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
                                      -Brodie
                                      • broomstickB Offline
                                        broomstick
                                        -Brodie
                                        This, sir, just made my day!
                                        • Bob JamesB Offline
                                          Bob James
                                          • jgbJ Offline
                                            jgb
                                            Found a cool one today. πŸ˜’
                                            -Brodie
                                            I just wish you found this last week, when I needed it. πŸ˜†
                                            jgb
                                            • 34
                                            • 35
                                            • 7 / 35
