    [Plugin] Recall last tool v1.2
    60 Posts 28 Posters 63.5k Views 28 Watching
    • EdsonE Offline
      Edson
      @matt666 said:
      Sorry Edson, and all mac users. But I can't do anything with this bug. 😞 Function 'send_action' doesn't accept integers (so tool IDs) on Mac.
      would the last update make it usable in macs?
      http://www.mahfuz.arq.br
        Matt666
        I take it!
        ... Dear Edson... I'm so sorry! 😞 You (and all Mac users!)have some problems with many of my scripts... Included this one...
        I can't be usable in mac. Mac has a bug with main function used in this script: Sketchup.send_action(ToolID). And I can't do anything.
        Sorry again Edson... 😳
        Frenglish at its best !
        My scripts
        • EdsonE Offline
          Edson
          matt,
          no problem. several other plugins you created work without problems. let's hope this bug gets solved in the future.
          • plot-parisP Offline
            plot-paris
            great plugin, Matthieu. 👍
            just a thought: does it make sense to have a similar tool go through several previously used tools when pressing the shortcut key repeatedly?
              Matt666
              Hi plot_paris!
              That's a good idea... I will give a try! I think we may go through 10 previously used tools, and may undo history (retrun to the last tool used) by activating selection tool.
              My scripts
              • Chris FullmerC Offline
                Hey, I was just thinking about a plugin that would cycle through tools on repeated pressing of a button.
                So assign it to the spacebar. Hit the spacebar once and its select. Twice it move, 3 is rotate. But I quickly decided against the silly plugin when I started thinking about having to hit the spacebar 26 times to get to "place camera" or something 😆
                But in this context, I think it is quite a good idea,
                  plot-paris
                  another idea, although probably not managable with ruby, is a much more graphical approach:
                  when you hold down the space bar, a ring with tool buttons appears around your cursor in a circular fashion. you can now left click any button to get the tool. or you can simply turn the scroll wheel to file through them, either clockwise or counterclockwise. by default the selection tool is highlighted - so if you just press the space bar once, you get the select tool.
                  you can easily customise this tool-circle by holding down the space bar and then dragging unwanted tools out of the circle and vice versa.
                  well, maybe Google comes up with soemthing similar in the next release 😄
                  • juan974J Offline
                    juan974
                    Merci MATT ...
                    juan974 (Réunion island)
                    website : http://sketchucation.com/click.php?url=http://www.tarn.us
                      bitsnbites
                      Thank you very much, Matt666.
                      That´s the Plugin i was lookin for.
                      thx a lot
                        Matt666
                        I will try to find a solution.
                        My scripts
                          Matt666
                          Sorry, I don't know how to create a personal observer for controlling mouse events...
                          My scripts
                            Pherim
                            Neat, I didn't know this yet. Great timesaver when switching to select tool to return to the previously used tool.
                              mirale999
                              Merci Matt! Great plugin~
                              By the way, I come up with an idea, I think maybe it's useful!
                              I use the shortcut“shift+Y” to recall the last tool. When I use this plugin, a situation like this will happen:
                              first I use the "Edge follow me" tool to build a face,
                              then I move it to another place, and use move and scale to modify the curves,
                              then I want to do "Edge follow me" again
                              so the idea comes:------this tool have a function: ignore the move, scale, rotate, line, arc, rectangle, circle...(because they are so useful and they have shortcuts), but recall edge follow me, blend, extrapolate colors...(you must find it in a submenu).
                              On my bad English... hope you get my meaning... ☀
                              paranoia is a higher form of awareness...
                                Matt666
                                Hi mirale999!
                                So you want RLT ignores some native tools you would be able to choose? Do you agree with this "way of explanation" (I dont know how to tell it in english 😳 )?
                                I don't know if it's possible... But I can try.
                                My scripts
                                  jdtsmith
                                  Just an FYI for any Mac users. Pecan's version above with the "exceptions" list works fine for me in SU 8.0. I use it with BetterTouchTool and a Magic Trackpad:
                                  • Three Finger TipTap Left: Orbit (O)
                                  • 3 Finger Tip Tap Right: Recall Last Tool (which I have as F2)
                                  • Pinch Out: Zoom Extents (I have as Shift-Z)
                                  This plugin, with Lion's native three finger dragging make using SU with the trackpad much more enjoyable. Here's how I use it:
                                  • Two finger "scroll": zooms in and out
                                  • 3 Finger move: same as click and drag for selection
                                  • Tip Tap Left (drop two fingers and tap another to the left): switch to orbit tool
                                  • Tip Tap Right: switch back to whichever tool I'm in the middle of using
                                  • Get Lost? Pinch to Zoom Out
                                  Thanks to the plugin's authors!
                                    alex_picas
                                    Hi Matt. Recall command of autocad is good too. Can you do other 'last tool recall' version like autocad with using only a space bar? Thanks Matt.
                                    • O Offline
                                      Omaha
                                      In this case, I want to say that for sure, Thank you. You saved the day.
                                        Pherim
                                        Makes SU Make 2017 (Windows) crash.
                                        • CadFatherC Offline
                                          CadFather
                                          mmm... works fine with me - is it wrapped in a module?
                                          require 'sketchup.rb'
                                          module MATT_Recall
                                          class Matt_Observer < Sketchup;;ToolsObserver
                                          	@@Matt_Model_Toolid = nil
                                          	@@Matt_Model_Toolid2 = nil
                                          	def onActiveToolChanged (tools_object, toolname, toolid)
                                          		@@Matt_Model_Toolid = @@Matt_Model_Toolid2 if @@Matt_Model_Toolid2
                                          		@@Matt_Model_Toolid2 = toolid if not([10508].index toolid)
                                          	def self.recall_last
                                          			return Sketchup.send_action(@@Matt_Model_Toolid)
                                          		else
                                          			puts "No tool used before."
                                          			return Sketchup.send_action("selectSelectionTool;")
                                          end  #class
                                          Sketchup.active_model.tools.add_observer(Matt_Observer.new)
                                          unless file_loaded?(__FILE__)
                                             UI.menu('Edit').add_item("RECALL LAST TOOL"){ Matt_Observer.recall_last }
                                          	file_loaded(__FILE__)
                                          end#module
                                            CadFather
                                            just in case anyone else asks, the following is totally fine on my pc:
                                            module MATT_Recall
                                            	def onActiveToolChanged (tools, tool_name, tool_id)
                                                puts "Tool Used; #{tool_name}"
                                            		@@Matt_Model_Toolid2 = tool_id if not([10508].index tool_id)
                                            		else
                                            end  #class
                                            end#module
                                            • 2 / 3
