    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.4m Views 345 Watching
      Just a note, on Mac, Preferences are found under the SketchUp menu to the left of File.
      • jeff hammondJ
        holy crap!
        that's perfect!
        πŸ‘ πŸ‘
        • utilerU
          utiler
          holy crap!
          that's perfect!
          πŸ‘ πŸ‘
          That is perfect, Fredo!!!!
          @Jeff - thanks for the challenge, I wasted hours on that bloody thing!!!! πŸ˜‰
          Just Curious...
            Thank you Fredo.
            And yes, Jeff, thanks for the challenge. I won't ever do it the hard way again.
              Vital Addition! πŸ‘
              I must try it for see if that gives the same result than a nurbs modeler! πŸ˜‰
              So YES this time seems very good! 😎
              1.3239127 Nurbs (height of brace cut vertically) Pilars are 1 * 1 * 10 , brace 1 * 1 * x : unity meter
              1.323913m SU
              • jeff hammondJ
                i tested a few things against rhino and as far as i can tell, it gives the same exact results.. πŸ‘
                but the crazy thing is, fredo's version is faster β˜€
                the offset/rotate idea is very clever and well implemented.
                bravo!
                • jeff hammondJ
                  i'm just waiting for someone to come up with the next one!
                    And no more problem in the Big Zoom! β˜€ πŸ˜‰
                      Only one decimal point difference! πŸ˜‰
                      1.3239127m Nurbs (height of brace cut vertically) Pilars are 1 * 1 * 10 , brace 1 * 1 * x : unity meter
                      1.323913m SU
                      Seems very similar! β˜€
                      • jeff hammondJ
                        1.323913m SU
                        well, no.. sketchup just ran out of zeros β˜€
                        9127 rounds up to 913 in sketchup..
                          A great mini-challenge with some headaches! πŸ’š
                          Maybe another solution without plug can be found who knows! πŸ˜‰
                          • jeff hammondJ
                            probably. but I don't care anymore. this solves it in my book.
                            πŸ˜†
                              d12dozr
                              Sweet update...Thanks, Fredo! πŸ‘ ...and Jeff for the inspiration πŸ˜„
                              http://goo.gl/f7ooYh
                                Daniel S
                                Great Update Fredo!!! 😍 😍 😍
                                I remember a lot this request...
                                http://forums.sketchucation.com/viewtopic.php?f=180&t=24831
                                I just tried your plugin and I had perfect results in seconds!!
                                Thank you for making a much more powerful Sketchup Fredo!!!
                                Daniel S
                                • fredo6F
                                  NEW FEATURES: with LibFredo6 4.5- 08 May 12
                                  If you upgrade to LibFredo6 4.5, you will get two new features for the Free Rotate tool (and other tools based on rotation such as Box Rotate, Twist, Free Planar Shearing).
                                  These new functions are largely inspired from Jeff Hammond's mini-challenge.
                                  1. Rotate with Offset
                                    In the SU Rotate tool and previous versions of FredoScale Free Rotate, the inferences are only done about the base line of rotation. This makes difficult to perform rotation when the target point to infer is not on the base line.
                                    In the new version of Free Rotate, there is an extra step where you can select a target line at a certain offset to be used for inference. This is shown on the video below.
                                  Note that this step is proposed by default in Free Rotate (just click again if you don't need it) and as an option for other tools (via a long click).
                                  1. Inference on line
                                    The typical situation is to rotate a line until it exactly touches another line. This is a typical limitation of the SU Rotate tool which does not provide inference for this case.
                                    Free Rotate now proposes this inference.
                                    This is an old request from Daniel S, also mentioned by Jeff in his mini-challenge.
                                  Please see this post for downloading the latest version of LibFredo6.
                                  • W
                                    Wong CK
                                    Help!!!! I am a newbie of SU.... I get nothing after installed your plugin... 😒
                                      Have you got the supporting 'Fredo Lib' file/subfolder downloaded/installed as explained on the download page ?
                                      Have you activated the tool under Window > Preferences > Extensions > FredoScale ?
                                      Have you then activated its toolbar from View > Toolbars > Fredo Scale ?
                                      Have you then got the menu item Tools > Fredo6 Collection > FredoScale ... ?
                                        redlerred7
                                        do you also have the Fredo file library, which has a link found in the first post, that you need to use the plugin?
                                        • K
                                          kira
                                          thank you
                                            SnowTiger
                                            This is an Excellent Plugin that I would recommend to anyone and everyone who might ever need to create organic shapes such as boat sails and/or tensile roof structures and the like.
                                            It is extremely easy to use and works very well.
                                            The fact that it is Free is also amazing because it certainly does have value and will save you tons of time regardless what you are trying to create with it.
                                            Thanks again so much for sharing this excellent Plugin as well as for continuing to make improvements/updates.
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 58
                                            • 59
                                            • 35 / 59
