    Image enlarging software
    extensions
    16 Posts 9 Posters 3.4k Views 9 Watching
    • E Offline
      Ecuadorian
      I second Rich's recommendation.
      I would dare to say that no image needs to be rendered at more than 1920x1080, if it has top-notch antialiasing.
      Unless it's going to be closely examined, like an illustration for assembling furniture or a map.
      -Miguel Lescano
      • PixeroP Offline
        Pixero
        Smilla enlarger is freeware and the best I've tried.
        http://sourceforge.net/projects/imageenlarger/
        http://alternativeto.net/Upload/Screens/80c7f51d-168d-4167-b67a-03cbafc3c1f5_2_full.jpg
          MMM717
          I downloaded SmillaEnlarger directly from the site linked above, and when trying to run it, I get the prompt from my computer I posted below.
          Anyone else have this problem? Something I'm doing wrong? Thoughts? Thanks in advance...
            Looks like you are trying to run it from within a zip file ?
            The 'Extract all Files' in the top bar is a give-away - it wouldn't say that in a normal folder ?? ...
            πŸ˜’
            Running the .exe won't find the .dll file[s] unless you have put them all into the same folder !!
            So... extract all of the zipped files/subfolders into a single folder.
            Then try running the .exe and hopefully the 'missing' .dll file will then be found ?
            πŸ˜•
              @solo said:
              Anyone know of a good image enlarging software?
              Too cheap to buy them pills, eh?
              • soloS Offline
                You bought the pills? πŸ’š 🀣
                  I started buying everything I get offered via email after I made a deal with the Nigerian Prince.
                  • brookefoxB Offline
                    brookefox
                    ~ no bump ~
                    Thanks for the Smilla link, Jan.
                    ~ Brooke
                      MMM717
                      πŸ˜’
                      πŸ˜•
                      I did extract them, but I tried again and not only does that "extract all files" not go away, I get the following prompt (1st image). Clicking "try again" is useless, and clicking skip gives the image in the second attachment.
                      Is the extractor not doing the job correctly, possibly? Or am I? πŸ˜•
                        @Pilou
                        That's a pretty good result. Can you try it on your avatar?
                          Result with Rsizr on line given above πŸ˜‰
                          Original follow = 650 * 358
                          Enlarge = 5000 * 3062 ( = *7.7 ) linked
                          (maybe a little degradation because I dont take the 100% JPG compression, only 90% ! )
                          What is the results with the other progs ?
                          noeil1.zip
                            Sure I will come back soon! πŸ˜„ Damned my own Original is not yet visible more 😲
                            original avatar on the left 90 81
                            900
                            810 =(*10) (not so bad from a so little thing πŸ’š
                            The real original is maybe this one πŸ˜‰
                              brookefox
                              I thought you were going to show us. I think that you should, hairy one.
                              I think you are correct. Try a different one, and/or reboot and try again.
                              ~ Brooke
