    Image enlarging software
    extensions
    16 Posts 9 Posters 3.2k Views 9 Watching
    • soloS Offline
      Anyone know of a good image enlarging software?
      I do not have Photoshop so a plugin will not work (I'm a Corel guy)
        SmillaEnlarger
        Download SmillaEnlarger for free. SmillaEnlarger is a small graphical tool ( based on Qt ) to resize, especially magnify bitmaps in high quality. ( The used algorithm is an invention of my own )
        SourceForge (sourceforge.net)
          http://rsizr.com/ never use for that but it's an amazing free prog on line! β˜€
          • E Offline
            Ecuadorian
            I second Rich's recommendation.
            I would dare to say that no image needs to be rendered at more than 1920x1080, if it has top-notch antialiasing.
            Unless it's going to be closely examined, like an illustration for assembling furniture or a map.
            -Miguel Lescano
            • PixeroP Offline
              Pixero
              Smilla enlarger is freeware and the best I've tried.
              http://sourceforge.net/projects/imageenlarger/
              http://alternativeto.net/Upload/Screens/80c7f51d-168d-4167-b67a-03cbafc3c1f5_2_full.jpg
                MMM717
                I downloaded SmillaEnlarger directly from the site linked above, and when trying to run it, I get the prompt from my computer I posted below.
                Anyone else have this problem? Something I'm doing wrong? Thoughts? Thanks in advance...
                • TIGT Online
                  Looks like you are trying to run it from within a zip file ?
                  The 'Extract all Files' in the top bar is a give-away - it wouldn't say that in a normal folder ?? ...
                  πŸ˜’
                  Running the .exe won't find the .dll file[s] unless you have put them all into the same folder !!
                  So... extract all of the zipped files/subfolders into a single folder.
                  Then try running the .exe and hopefully the 'missing' .dll file will then be found ?
                  πŸ˜•
                    Too cheap to buy them pills, eh?
                    • soloS Offline
                      You bought the pills? πŸ’š 🀣
                        I started buying everything I get offered via email after I made a deal with the Nigerian Prince.
                        • brookefoxB Offline
                          brookefox
                          ~ no bump ~
                          Thanks for the Smilla link, Jan.
                          ~ Brooke
                            MMM717
                            πŸ˜’
                            πŸ˜•
                            I did extract them, but I tried again and not only does that "extract all files" not go away, I get the following prompt (1st image). Clicking "try again" is useless, and clicking skip gives the image in the second attachment.
                            Is the extractor not doing the job correctly, possibly? Or am I? πŸ˜•
                              @Pilou
                              That's a pretty good result. Can you try it on your avatar?
                                Result with Rsizr on line given above πŸ˜‰
                                Original follow = 650 * 358
                                Enlarge = 5000 * 3062 ( = *7.7 ) linked
                                (maybe a little degradation because I dont take the 100% JPG compression, only 90% ! )
                                What is the results with the other progs ?
                                noeil1.zip
                                  Sure I will come back soon! πŸ˜„ Damned my own Original is not yet visible more 😲
                                  original avatar on the left 90 81
                                  900
                                  810 =(*10) (not so bad from a so little thing πŸ’š
                                  The real original is maybe this one πŸ˜‰
                                    brookefox
                                    I thought you were going to show us. I think that you should, hairy one.
                                    I think you are correct. Try a different one, and/or reboot and try again.
                                    ~ Brooke
