    Image enlarging software
    extensions
    16 Posts 9 Posters 3.6k Views 9 Watching
      http://rsizr.com/ never use for that but it's an amazing free prog on line! β˜€
      • E
        Ecuadorian
        I second Rich's recommendation.
        I would dare to say that no image needs to be rendered at more than 1920x1080, if it has top-notch antialiasing.
        Unless it's going to be closely examined, like an illustration for assembling furniture or a map.
        -Miguel Lescano
        • PixeroP
          Pixero
          Smilla enlarger is freeware and the best I've tried.
          http://sourceforge.net/projects/imageenlarger/
          http://alternativeto.net/Upload/Screens/80c7f51d-168d-4167-b67a-03cbafc3c1f5_2_full.jpg
            MMM717
            I downloaded SmillaEnlarger directly from the site linked above, and when trying to run it, I get the prompt from my computer I posted below.
            Anyone else have this problem? Something I'm doing wrong? Thoughts? Thanks in advance...
              Looks like you are trying to run it from within a zip file ?
              The 'Extract all Files' in the top bar is a give-away - it wouldn't say that in a normal folder ?? ...
              πŸ˜’
              Running the .exe won't find the .dll file[s] unless you have put them all into the same folder !!
              So... extract all of the zipped files/subfolders into a single folder.
              Then try running the .exe and hopefully the 'missing' .dll file will then be found ?
              πŸ˜•
                @solo said:
                Anyone know of a good image enlarging software?
                Too cheap to buy them pills, eh?
                • soloS
                  You bought the pills? πŸ’š 🀣
                    I started buying everything I get offered via email after I made a deal with the Nigerian Prince.
                    • brookefoxB
                      brookefox
                      ~ no bump ~
                      Thanks for the Smilla link, Jan.
                      ~ Brooke
                        MMM717
                        πŸ˜’
                        πŸ˜•
                        I did extract them, but I tried again and not only does that "extract all files" not go away, I get the following prompt (1st image). Clicking "try again" is useless, and clicking skip gives the image in the second attachment.
                        Is the extractor not doing the job correctly, possibly? Or am I? πŸ˜•
                          @Pilou
                          That's a pretty good result. Can you try it on your avatar?
                            Result with Rsizr on line given above πŸ˜‰
                            Original follow = 650 * 358
                            Enlarge = 5000 * 3062 ( = *7.7 ) linked
                            (maybe a little degradation because I dont take the 100% JPG compression, only 90% ! )
                            What is the results with the other progs ?
                            noeil1.zip
                              Sure I will come back soon! πŸ˜„ Damned my own Original is not yet visible more 😲
                              original avatar on the left 90 81
                              900
                              810 =(*10) (not so bad from a so little thing πŸ’š
                              The real original is maybe this one πŸ˜‰
                              • brookefoxB
                                brookefox
                                I thought you were going to show us. I think that you should, hairy one.
                                I think you are correct. Try a different one, and/or reboot and try again.
                                ~ Brooke
