    A quest for better understanding of textures
    renderpluginsextensions
    39 Posts 15 Posters 125.3k Views 15 Watching
    • Q Offline
      queeridstudio
      How do I change the grid size to 5 times larger? Been trying to adjust in U and V but still could not get it.
      @eidam655 said:
      hello winGman,
      create a material, open it in material editor:
      [attachment=1:3chobg9h]<!-- ia1 -->texgrid_tut_1.png<!-- ia1 -->[/attachment:3chobg9h]
      assign the TexGrid texture to the Diffuse channel (or some other channel, depending on your desired usage) and try to play around with the UV repeat values to adjust its size:
      [attachment=2:3chobg9h]<!-- ia2 -->texgrid_tut_2.png<!-- ia2 -->[/attachment:3chobg9h]
      after this, my render looks like this:
      [attachment=0:3chobg9h]<!-- ia0 -->texgrid_tut.png<!-- ia0 -->[/attachment:3chobg9h]
      and that should be it πŸ˜„
        TexWater doesn't appear to be fully implemented - it's just producing a colour that cannot be adjusted... 😞
        • broomstickB Offline
          broomstick
          This is a great reference post. The only thing I would like to see is if these maps, once applied on the diffuse channel, are visible in the Sketchup Model, or only at rendering time.
          Nice work!
            Only at render time. SketchUp has no knowledge of how V-Ray materials are designed.
              broomstick
              So how does this make them usable?? Maybe I'm just too used to using vray materials in 3d studio max!
                Make use of the preview feature in VfSU's material editor (it's not great I know) or make small test scenes. I've done similar tests before to visualize these V-Ray textures and used several of them in my project.
                • pyrolunaP Offline
                  pyroluna
                  I did some test with the procedural texture for wood. The variable 'center_v' seems to have the most influence on the texture size.
                  It is a 3d texture, I think that means that the object cuts through the texture somehow. It reminds me of the old days with POV-ray - which has extensive documentation on all of its functions, including its procedural wood texture. (although I'm not sure wether or not they are mathematically the same)
                  wood_procedural.vismat
                    That's a nice sample. Thanks! πŸ‘
                    • eidam655E Offline
                      eidam655
                      wow, thanks for this πŸ˜„
                      another thing i discovered is that with 'use_3d_mapping' checked (ie. it's ON), the result is just like you showed us; however, if you uncheck it, you'll get a texture of the wood end. demonstrating on your material:
                      http://i.imgur.com/VZzrB.jpg
                      however, i couldn't get center_v get to change the scale on my textures. i would say that center_u and _v define the center position of the texture, so i don't think this would affect the size... more testing is needed though.
                      http://i.imgur.com/Gwu0Q.jpg
                      strange thing is that even when in the TexWood preview window something is happening, in the material preview and in the render not so many things change...
                      I'm using SketchUp 2017, V-Ray 3.4
                      • pyrolunaP Offline
                        pyroluna
                        Oh yeah also this; the placement is dependent on the origin of the model or component. I'm not exactly sure how the difference between applying a material to a face or to a component is in play, but the component axes thing is clearly demonstrated in the example below:
                        In this image, the two little blocks on the floor are the same component - one of them made unique and the axes of that one have been put at an angle of 45 degrees in two directions.
                        As for the balls, they are the same component, one of them is rotated.
                        • eidam655E Offline
                          eidam655
                          just for reference, how big are your... items? ('balls' would seem inappropriate ^^)
                          my sphere is 2,646m in diameter.
                          • pyrolunaP Offline
                            pyroluna
                            the big ones are 470mm in diameter, the little blocks are 100mm
                              broomstick
                              may I publish here a little tutorial on how to use the Vray Blend Material?
                              It's useful to have bump maps without a diffuse texture (sort of)
                              • eidam655E Offline
                                eidam655
                                sure, please, go ahead πŸ˜„
                                  Yes. But please post in a new thread, and tag it [Tutorial] so it's easier to find.
                                    broomstick
                                    Gotcha πŸ˜‰
                                    • panixiaP Offline
                                      panixia
                                      yes you can!
                                      • john2J Offline
                                        john2
                                        @eidam655 said:
                                        hello winGman,
                                        [attachment=1:bo417hjm]<!-- ia1 -->texgrid_tut_1.png<!-- ia1 -->[/attachment:bo417hjm]
                                        [attachment=2:bo417hjm]<!-- ia2 -->texgrid_tut_2.png<!-- ia2 -->[/attachment:bo417hjm]
                                        [attachment=0:bo417hjm]<!-- ia0 -->texgrid_tut.png<!-- ia0 -->[/attachment:bo417hjm]
                                        is there anyway we can change multiplier by measuring tilesize. ? this would be useful while making bump maps for tiles divided in a grid. say if i want tilesize 300mm by 300mm how can i do it?
                                        Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                        • panixiaP Offline
                                          panixia
                                          @eidam655 said:
                                          • rock/noise pattern. is not affected by UV repeat values.
                                          • smoke/noise pattern. is not affected by UV repeat values.
                                          • snow/noise pattern with alternating alpha. is not affected by UV repeat values.
                                          • speckle/noise pattern. is not affected by UV repeat values.
                                          • splat/noise pattern. is not affected by UV repeat values.
                                          • presumably stucco/noise pattern. is not affected by UV repeat values. sadly,
                                          • is not affected by UV repeat values. in fact, it's the same case as with Stucco. a
                                          my 50 cents to help your quest. πŸ’­
                                          recently i discovered that for the textures rock - stucco - smoke - snow - speckle - splat - water you should untick "use 3d mapping" to enable UV tiling control. πŸ‘
                                            jackwatson
                                            Has anyone ever come across any clear documentation for all of these effects? The fact that there are so many cool procedural maps available, but the tutorials for how to utilise them are not seems a waste.
                                            I've spent a good few hours playing around with them before but managed to get no practical use out of them because, as you know, with all the variables you can change it would take weeks or months to learn anything through trial an error.
                                            This is probably less of an issue for Max users who tend to have had some kind of professional training, but those who use Sketchup for visualisation are at the shallow end of the visualisation pool are largely self trained I imagine. (Along with using amazing resources such as Sketchucation, of course πŸ˜‰)
                                            • 2 / 2
