    [Plugin] WireTool (Catenary) (1.4.1) – updated 06.03.2013
    54 Posts 26 Posters 60.4k Views 26 Watching
    • mitcorbM Offline
      mitcorb
      Another good tool concept. By the way, Remus Knowles has another version in the Plugins Index.
      • iichiversiiI Offline
        iichiversii
        Any idea what his version is called?
        Bring on the Rain...
          Aerilius
          Remus' plugin is the Simple Catenary Curve. It "just" calculates the curve for a given set of 17 points but it put me on the right path to look on Wikipedia after I had a paper full of integrals that didn't want get further simplified.
          • urgenU Offline
            urgen
            HA!...cool idea.thanks Aerilius πŸ‘
            --pupil forever...------
            • N Offline
              nektares
              I always did this with splines, this is a much better and precise way to do it, Thank you!
              • sdmitchS Offline
                sdmitch
                When I tried the plugin, I kept getting a canatnary drawn from the origin to my first pick point. Adding a @state = 0 to the def initialize method fixed this problem.
                http://sdmitch.blogspot.com/
                  Aerilius
                  Hi Sam,
                  thanks for the tip. I wonder why this happens, although the initialize method does not have @state=0, this should be set when the activate method calls reset.
                  Is someone else having this problem?
                  • massimoM Offline
                    massimo Moderator
                    Yes the same here. Thanks for the plugin btw. πŸ‘
                      create_geometry and draw_geometry can be refactored into one method that returns an array of point3d objects - the only difference between these methods are the final statement. DRY
                        I didn't experience the same thing that Sam reported.
                        • gullfoG Offline
                          gullfo
                          i added the @state=0 and it made a difference in terms of being able to select the first point. very nice tool!
                          Glenn
                          http://www.runnel.com
                            So why don't I have this same problem? I didn't modify the script and it works fine for me.
                            • wind-borneW Offline
                              wind-borne
                              Which version are you using?
                              initial version works fine for me, updated version moves to origin.
                              "To read between the lines was easier than to follow the text."OSX 10.11.6
                              %(#BF80BF)[SU 8 pro
                                That would explain it. I didn't catch that there was an update because the thread title wasn't edited to show that as is SOP here.
                                  So now I've updated the plugin and added the line as mentioned. I get some rather strange behavior now. See the video.
                                  [flash=420,315:13s7e1sa]http://www.youtube.com/v/7IJXmgk8lio?version=3&hl=en_US[/flash:13s7e1sa]
                                    I have the original version [that works] if anyone wants it... πŸ˜•
                                      I guess I'd be interested.
                                        raineysky
                                        I would very much like to have it if it makes rope. I tried it but got results like Dave shows in the video.
                                          That apparently fixed it. Thank you.
                                          • McGyverM Offline
                                            McGyver
                                            This is very cool! Thank you!
                                            Edited to add- This is REALLY cool! I was just messing around with it and it works great for something I was making. THANKS!
                                            [Visit My ShareCG Freebie Gallery](http://www.ShareCG.com/pf/full_uploads.php?pf_user_name)
                                            • 2 / 3
