    [Plugin] WireTool (Catenary) (1.4.1) – updated 06.03.2013
    54 Posts 26 Posters 64.5k Views 26 Watching
    • sdmitchS
      sdmitch
      When I tried the plugin, I kept getting a canatnary drawn from the origin to my first pick point. Adding a @state = 0 to the def initialize method fixed this problem.
      http://sdmitch.blogspot.com/
        Aerilius
        Hi Sam,
        thanks for the tip. I wonder why this happens, although the initialize method does not have @state=0, this should be set when the activate method calls reset.
        Is someone else having this problem?
        • massimoM
          massimo Moderator
          Yes the same here. Thanks for the plugin btw. 👍
            create_geometry and draw_geometry can be refactored into one method that returns an array of point3d objects - the only difference between these methods are the final statement. DRY
              I didn't experience the same thing that Sam reported.
              • gullfoG
                gullfo
                i added the @state=0 and it made a difference in terms of being able to select the first point. very nice tool!
                Glenn
                http://www.runnel.com
                  So why don't I have this same problem? I didn't modify the script and it works fine for me.
                  • wind-borneW
                    wind-borne
                    Which version are you using?
                    initial version works fine for me, updated version moves to origin.
                    "To read between the lines was easier than to follow the text."OSX 10.11.6
                    %(#BF80BF)[SU 8 pro
                      That would explain it. I didn't catch that there was an update because the thread title wasn't edited to show that as is SOP here.
                        So now I've updated the plugin and added the line as mentioned. I get some rather strange behavior now. See the video.
                        [flash=420,315:13s7e1sa]http://www.youtube.com/v/7IJXmgk8lio?version=3&hl=en_US[/flash:13s7e1sa]
                          I have the original version [that works] if anyone wants it... 😕
                            I guess I'd be interested.
                              raineysky
                              I would very much like to have it if it makes rope. I tried it but got results like Dave shows in the video.
                                That apparently fixed it. Thank you.
                                • McGyverM
                                  McGyver
                                  This is very cool! Thank you!
                                  Edited to add- This is REALLY cool! I was just messing around with it and it works great for something I was making. THANKS!
                                  Visit My ShareCG Freebie Gallery
                                    Aerilius
                                    Tools normally don't have weird behavior without reason. Running it with the Ruby console open gives often more definable results.
                                    So I found and fixed an unobvious bug with the translations that stirred up all methods and I changed that the x-width of segments is variable to give always the same segment length.
                                      Michaelv
                                      Great Thanks.
                                      There was another catenary tool (and other geometric curves too) here:
                                      http://forums.sketchucation.com/viewtopic.php?t=41310
                                      I needed to make them like this though.
                                      See below however, the first segment is much longer and they become smaller as they go on the curve:
                                        Aerilius
                                        @Michaelv: Thanks for noticing this! It was not much visible with little sagging (110%) but with big sagging. Sorry that it took some time (it's not easy to do math with curve lengths).
                                        I fixed it now.
                                        I also thought about the problem and find that the corners/endpoints a even less noticeable when I use equal angles between the segments. If you prefer equal segment lengths, you can change the parameter @@segments_distribution_mode to 1 inside the script.
                                          Michaelv
                                          A nice option (but I can do it when I get a minute) would be for the start to start either like you did (wire) or horizontal )like a cable that's more rigid, yet supported by posts.
                                          Toggle with alt/option
                                          I think all it takes is force the angle at point of attachment to be horizontal, and the equation would take care of the rest. But maybe not. 😄
                                          Never mind, I looked at it and the equation as it stands is for tension always parallel to the tangent of the curve, thus deflection equations (with rigidity, etc..) at the boundary would have to be used until that is the case. too complicated for the time being.
                                          Danke Shoen!
                                            moluasa
                                            Might also be cool to work with for line art!
                                            • 2 / 3
