    [Plugin] WireTool (Catenary) (1.4.1) – updated 06.03.2013
    54 Posts 26 Posters 62.7k Views 26 Watching
    • KrisidiousK Offline
      Krisidious
      sweet thanks.
      By: Kristoff Rand
      • Bob JamesB Offline
        Bob James
        I can really use this! Thank you. 👍
          @aerilius said:
          Type a length to set a fixed arc length:
          !!! I tried on this a couple of years ago! Never worked out how to do a fixed length curve. I need to snoop around in your code. I wanted to make a tool that would anchor the end point to other geometry so when you moved of the the object it was attached it the curve would update.
          • iichiversiiI Offline
            iichiversii
            Now this is a great plugin, thanks 👍
            Bring on the Rain...
            • gullfoG Offline
              gullfo
              very cool! this is one of the more useful shapes in acoustics!
              Glenn
              http://www.runnel.com
                That I wasn't aware of. Guess I need to read up on it again.
                • mitcorbM Offline
                  mitcorb
                  Another good tool concept. By the way, Remus Knowles has another version in the Plugins Index.
                    iichiversii
                    Any idea what his version is called?
                      Aerilius
                      Remus' plugin is the Simple Catenary Curve. It "just" calculates the curve for a given set of 17 points but it put me on the right path to look on Wikipedia after I had a paper full of integrals that didn't want get further simplified.
                      • urgenU Offline
                        urgen
                        HA!...cool idea.thanks Aerilius 👍
                        --pupil forever...------
                        • N Offline
                          nektares
                          I always did this with splines, this is a much better and precise way to do it, Thank you!
                          • sdmitchS Offline
                            sdmitch
                            When I tried the plugin, I kept getting a canatnary drawn from the origin to my first pick point. Adding a @state = 0 to the def initialize method fixed this problem.
                            http://sdmitch.blogspot.com/
                              Aerilius
                              Hi Sam,
                              thanks for the tip. I wonder why this happens, although the initialize method does not have @state=0, this should be set when the activate method calls reset.
                              Is someone else having this problem?
                              • massimoM Offline
                                massimo Moderator
                                Yes the same here. Thanks for the plugin btw. 👍
                                  create_geometry and draw_geometry can be refactored into one method that returns an array of point3d objects - the only difference between these methods are the final statement. DRY
                                    I didn't experience the same thing that Sam reported.
                                    • gullfoG Offline
                                      gullfo
                                      i added the @state=0 and it made a difference in terms of being able to select the first point. very nice tool!
                                      Glenn
                                        So why don't I have this same problem? I didn't modify the script and it works fine for me.
                                        • wind-borneW Offline
                                          wind-borne
                                          Which version are you using?
                                          initial version works fine for me, updated version moves to origin.
                                          "To read between the lines was easier than to follow the text."OSX 10.11.6
                                          %(#BF80BF)[SU 8 pro
                                            That would explain it. I didn't catch that there was an update because the thread title wasn't edited to show that as is SOP here.
                                            • 1 / 3
