    Mini-challenge
    328 Posts 26 Posters 99.4k Views 26 Watching
      What about a gizmo?
      • fredo6F
        IMPORTANT:
        My initial version of LibProtractor.rb for the Target trick was full of bugs. I still need some rework to handle all cases properly and anyway I should revisit this protractor tool.
        In the meantime, please consider the attached version
        to drop into the LIBFREDO6_Dir_44 folder
          Hi fredo
          About your previus try with the normal Rotation tool, have you made a very big zoom on the result ?
          • fredo6F
            Hi fredo
            Pilou,
            You're right. The rotation is not accurate and we see a small shift when zooming.
            The illusion comes from the fact that, visually from far, we see the edge of the vertical timber.
            So it may not be that the standard SU Rotate tool does the job and we may be back to square one ๐Ÿ‘Š
              Damned the trick of jason / Fredo works for me! But....
              I had always group that works nut! Never find the "Parallel edges" ๐Ÿ˜ฎ
              But....
              The secret : explode it! ๐Ÿ˜Ž
              With group's explosion the rotative block that works like a charm! ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
              Thanks Fredo, my desperation is resolved! ๐Ÿ’š Maybe...
                Sorry for the desillusion! ๐Ÿ˜‰
                I had the same many times during this crazzy Jeff challenge! ๐Ÿ’š
                  Tig's method is some tricky but maybe not very simple ๐Ÿ˜‰
                  Here without plugin and very easy ๐Ÿ˜‰
                  Seems 1.000000m everywhere ๐Ÿ˜„
                  Circle 100 segments (enter 200)
                  Just 2 rotations
                  One general
                  one with big zoom : That all ๐Ÿ˜„
                  Edit
                  Alas with very very very subatomic zoom
                  seems top blend becomes no accurate ๐Ÿ˜ž
                  And the second rotate was not theoricly adapted ๐Ÿ˜ž
                  Jeffcircle.skp
                  • jeff hammondJ
                    so, after further examining Moujiik's method, i think he has something there ๐Ÿ‘ โ€ฆi have a way (doing the same underlying thing as Moujiik showed) which might make it easier to communicate..
                    the thing is, i believe it's still geometrically imperfect but the error must be in the .0000004 (seven decimals) or less range because sketchup keeps reporting it as absolutely perfect (.000000") (in a similar fashion as using math with ruby or a DC can get things perfect within sketchup's maximum precision of six decimalsโ€ฆ)
                    i'll draw up a step by step later tonight so you guys can scrutinize it (and ultimately find the flaw ๐Ÿ˜† )
                    • andybotA
                      andybot
                      How is this different from gilles? (and I posted a similar one a ways back once I saw gilles method - by drawing a perpendicular to the diagonal). This still has an issue of not aligning precisely to the tangents. You can double-check it easily with TIG's true tangent ruby.
                      • jeff hammondJ
                        it's slightly different with what happens with the angles. maybe enough of a difference to bring things within perfect (well, sketchup perfect) .. I'm getting on the train soon.. I'll post something afterwards.
                          mac1
                          Here is the another closed form solution hcos( theta)-ssin(theta) = d
                          This can reudce to the form of sin(a-theta) = d/m
                          a= arctan(h/s)
                          m= is the polar mag of for your orginal post of s=65;h=96
                          d= lumber width ( 3.5) and if you implement my orginal post suggestion the modeled angle is 54.205( with more accurate guide point interpolation)
                          The actual angle is 54.178 the other intersect points are d/cos(theta), for the plum cuts) so can be laid out very quickly..IMHO you really don't need SU. Would be very easy to make cut schedule for various s,h and d
                            mac1
                            mac1
                            I was hoping it's already been established in the thread that the challenge isnt about accuracy from a real world construction standpoint. I mean, depending on the time of day (temperature) and humidity, a board will expand/contract far more than the results being given in the thread.
                            We even use to calibrate our theodolites using a long Invar tape before making measurements so I am well aware of temps, ground movement, truck rumble etc etc.
                            Sorry did not read that I was working off your original post and I thought it implied a actual project working around walls etc.My last post gives the exact answer if you care about that.
                            • utilerU
                              utiler
                              Jason,
                              You're right.
                              The native Rotate tool seems to find inference in alignment of edges with others. You have to play around with it, but it seems to find it in the end.
                              [attachment=0:24w854cr]<!-- ia0 -->Jeff Challenge3.gif<!-- ia0 -->[/attachment:24w854cr]
                              I've been mucking around with this too; Fredo I can't replicate your 'parallel to edge'... which edge is it looking for?
                              Just Curious...
                              • jeff hammondJ
                                ok.. so it's not different.. it's just faster to draw it using a modified version of Moujiik's..
                                but.. here's something i figured out is different (and it's the reason you were able to get a perfect .000000" measurement in your file (which i missed until now)).. we (you and i at least) are doing something different than others in the thread.. we're working in inches..
                                .000001" is a lot more of a tolerance than .000001mm
                                so doing gilles' method in inches -- as long as your board doesn't get too wide, will in fact give perfect sketchup results (meaning smthg like 10.000000") even though it's still not perfect where as working in mm will still show the error..
                                so this is sort of interesting to say the least.. maybe because i never took the time to realize this:
                                **.000001 millimeters = .00000003 inches (that's 8 decimals)**
                                so that means, anyone getting this within .000020mm has surpassed the accuracy which is possible with inches in sketchup..
                                • andybotA
                                  andybot
                                  Actually, the only reason I was using inches is because it's the native unit for SU. I was thinking I would avoid any possible "rounding to metric" errors. But of course, it all depends on scale, and mm will be a smaller scale giving a higher precision. In the end, checking against true tangent will show the error in any of the cases. (Except now I'm paranoid, maybe true tangent has some built-in approximation as well ๐Ÿ˜ฒ ๐Ÿ˜• )
                                  • jeff hammondJ
                                    you're right โ€ฆ
                                    [flash=853,480:3ax8n44e]http://www.youtube.com/v/ww17dNJt_LQ?version=3&amp;hl=en_US&amp;rel=0[/flash:3ax8n44e]
                                    โ€ฆ but where's the fun in doing it that way? ๐Ÿ˜„
                                    [actually, the second method in the video shows something that might make a good ruby.. 2pt orient with 1D scaling]
                                    • jeff hammondJ
                                      yeah.. i'm sure true tangents would eventually show an error.. it just depends on how many zeros you can put after the decimal point..
                                      which is basically what i'm getting at here.. if the people working in mm were limited to 4 decimal places, most of their results (the people using a gilles hybrid) would be showing a perfect measurement across the boardwidth even though we can tell, geometrically, there should be an error..
                                      i think this thread is driving into some weird territory.. we're straddling sketchup's tolerances at amounts so small, it's hard to even imagine.. if this thread keeps going, we'll probably end up pinpointing the exact place where sketchup decides "this is ok.. and this is not ok"
                                      [edit.. or actually, i guess that point is somewhere around 3 one-hundred-millionths of an inch ๐Ÿ˜†]
                                      • gillesG
                                        gilles
                                        I think I've found a very easy way.
                                        Show you later, no time yet.
                                        • jeff hammondJ
                                          sweet!
                                            Would be interesting to hear what the SketchUp team thinks of this challenge. ..too bad they are rather busy atm...
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
