    Mini-challenge
    328 Posts 26 Posters 99.4k Views 26 Watching
    • jason_marantoJ
      jason_maranto
      Yeah I was trying for stupid simplicity, and just ended up with stupid 😉
      BTW I'm playing with the protractor a bit more and it seems to be snapping to something, I can't tell what -- and it's not giving me any feedback, but the result is the missing correct 90 degree reference... maybe they (SketchUp Devs) already solved this problem and we just never found it.
      It's strange though because you have to kind-of slide the protractor along a guideline until it just decides to snap for some reason. 😕
      Best,
      Jason.
      • jeff hammondJ
        Jason,
        You're right.
        The native Rotate tool seems to find inference in alignment of edges with others. You have to play around with it, but it seems to find it in the end.
        [attachment=0:1qducgxr]<!-- ia0 -->Jeff Challenge3.gif<!-- ia0 -->[/attachment:1qducgxr]
        what the heck ??
        at first i though 'this guy is nuts' but then after fiddling around for a minute or so, it eventually snapped exactly into place ???
        so i guess the quest now is figuring out what it's doing and how to gain better control over it..
        • jeff hammondJ
          haha.. this is crazy..
          what's going on here? i don't understand..
          (i mean, the reference click of the rotate tool doesn't even happen on the edge of the board that needs aligned.. like in fredo's latest video.. i'll click on the bottom of the board then the top of it snaps perfectly into place.. and i've been able to repeat it a few times now..)
          • jason_marantoJ
            jason_maranto
            That's crazy -- I'm sure the Dev Team was really laughing at us for the last 13 pages, with us flopping around trying to solve something they already took care of 😆 😆 😆
            Edit -- it seems to still be limited by the angle precision settings... much like my previous try using the guide-point. I think I'll still with your plugin solution.
            Best,
            Jason.
            • gillesG
              gilles
              Fredo is a devil, be afraid!
              Bravo!!!
                I was doing this earlier today and trying to zoom in to find the error. Never thought it was actually aligned as I was 100% certain it wasn't possible.
                Not to mention spending 2 hrs with TOS plugin hoping to find the golden egg.
                • jeff hammondJ
                  right.. it's weird. there's no feedback when it happens so it's hard to tell if you're just at a .001 angle or actually snapped into place. but so far, ive been able to get it perfectly into place in many situations (some situations (variations on height/length/boardwidth) I haven't been able to do it)
                  • ely862meE
                    ely862me
                    Can't do it !! And I'm trying for about 10 minutes now ! lol
                    Elisei (sketchupper)
                    Come and See EliseiDesign
                    • jeff hammondJ
                      haha. right. that's why I thought fredo was nuts at first but then the voodoo kicked in and it snapped perfectly into place
                      • ely862meE
                        ely862me
                        I won't quit though ! I'll try again tomorrow ! So, we're still newbie regarding Sketchup 😆 !
                        Have a great one !
                        • jeff hammondJ
                          @moujiik said:
                          May be like this?
                          Moujiik
                          hmm.. this looks like it's working (as in your results look correct).. i haven't been able to repeat it with my own set of dimensions ❓ (i think i'm missing something that you're doing) but it seems very closely related to what gilles was suggesting.. i'll have more time a little later to give it a proper examination 😉
                          • Wo3DanW
                            Wo3Dan
                            @tig said:
                            ....You are of course right, in that the width of my 300mm rail when adjusted using my methods is in fact 299.982273mm [the ends are still slightly skewed to the long sides!], but since that 0.0177mm is much thinner than a human hair and only about 1/3rd of the thickness of a Rizla cigarette paper [approaching the limit of human visual acuity!]... and we aren't [usually] designing nanobots or sending someone to Mars - all of these simplified approaches are usually adequate. For how often might we expect to find a piece of wood exactly 300mm wide - even when measured with some uncommonly accurate gauge ?......
                            Does Rizla still exist? 😮
                            You are right in that trying to get that extra 0.0001mm (or less) is absolutely ridiculous.
                            Although it may often look like (when posting here) I am a micron_ or even a nano_freek, I'm most certainly not.
                            And in daily life I stop at 1mm. I'm even having a hard time distinguishing between these mm_lines when reading measures.
                            It's just that, like Jeff, I do like SU to get geometry right. To avoid modeling problems later on. So I try to understand what is allowed in the program. And preferably with the most basic toolset. Inferencing is usually doing an excellent job. But it is that construction circle that is just missing in the basic toolset.
                            With this challenge I tried again to come up with a solution, just in case I missed it the thousand times before. No luck other than what others have posted. I can get close, to the point where you cannot even measure the differences. In a few steps. But still, my method doesn't fit into SketchUps accurate inferencing results. It's by manual input.
                            With one scene to see the rotation point and another (very!) close up scene of the target location. The rough rotation is done by construction, more or less as also shown here by others, the final "accurate" adjustment is done by inputting an angle and retyping a better angle (input goes behond 0.001 degrees). It doesn't take long to get within 0.000001mm, not measurable.
                            At this point SU could be improved with a constuction circle which would not make the program that much heavier. Unlike with true circles.
                            • jeff hammondJ
                              I really can't think of much reason as to why the devs wouldn't include this in sketchup.. I guess there would be circumstance when new users might not understand why their points placed along a construction circle may not correspond with their circles but I think that confusion happens anyway when learning to deal with segmented circles to begin with.
                              but other than this possible confusion, can anyone think of a reason as to why the devs haven't included such a feature?
                              • Wo3DanW
                                Wo3Dan
                                @moujiik said:
                                May be like this?
                                Moujiik
                                Let me know if/when you find the correct workflow, please.
                                Moujiik's presented model does still show some incorrect locations if you zoom in close enough.
                                • Wo3DanW
                                  Wo3Dan
                                  I'm not against true circles. It may just make the program heavier. Not my concern. But how would SU handle surfaces with true circles and true arcs. There would be much more information to deal with than with "just" a few flat faces. True circles would be awesome though.
                                  You may see this happening in the near future, now that the developing team has their hand free. I think that eventually it's a must for a grown up modeling program.
                                  • jeff hammondJ
                                    oh, right.. i'm not thinking they should just make true circles for everything.. (basically turning sketchup into a nurbs app).. a lot of people ask for this but by doing so, some unintended behaviors will come into play.. polygon modelers do have some advantages which will be lost in a nurbs based app..
                                    i think i'm wishing for the same thing you are.. just some construction circles so we can snap to any point along an arc when need be..
                                    but at the same time, there may be a reason why the devs have chosen not to include this feature.. i'm sure they've discussed it plenty of times before.. just curious as to what the reasoning may be..
                                    • gillesG
                                      gilles
                                      I think Tig's Tangent tools should be a native tool in SU, it's the basis of geometry as I learned it.
                                        What about a gizmo?
                                        • fredo6F
                                          IMPORTANT:
                                          My initial version of LibProtractor.rb for the Target trick was full of bugs. I still need some rework to handle all cases properly and anyway I should revisit this protractor tool.
                                          In the meantime, please consider the attached version
                                          to drop into the LIBFREDO6_Dir_44 folder
                                            Hi fredo
                                            About your previus try with the normal Rotation tool, have you made a very big zoom on the result ?
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
