    [Plugin] QuadFaceTools
    680 Posts 116 Posters 624.8k Views 116 Watching
      [floatr:3lvkx0s1]
      https://bitbucket.org/thomthom/quadface-tools/wiki/Images/Toolbar_v0_7_0.png
      [/floatr:3lvkx0s1]
      Version 0.7.0
      New Features
      • Highlight Poles
      • Build Corners
      • Build Ends
      • Convert Wireframe to Quads
      • Loop to Region
      Fixed
      • Selection Tool now also selects entities that isn't quads.
      • Selection Tool allow triple-click to select all connected.
      • Cleaned up UI strings.
      • Cleaned up icons.
      • Connect Edges' HUD is now movable.
        Build Corners looks immense πŸ‘
          πŸ‘ Thanks, yet again...
          • N Offline
            nfmdias
            Hello!
            I need your help. I'm doing a bridge and I have a problem in texture.
            I wanted the texture is accompanied by the span of the bridge.
            Thanks,
            nfmdias
              You must create quads for the span of the bridge - then you can use the UV tool to map it.
              • N Offline
                nfmdias
                @nfmdias said:
                Hello!
                Thanks,
                nfmdias
                well here is the work done ... not bad. I had to do more triangulations.
                Thanks for the tip.
                nfmdias
                bottom view of the bridge
                • N Offline
                  nfmdias
                  after some time and several attempts ... here is the work ... not bad. I had to do more "triangles".
                  thanks for the tip
                  nfmdias
                    πŸ˜„ πŸ‘ πŸ‘
                      mingjae
                      hello,
                      i want to ask something if u mind,
                      does quadface works with curviloft-ed models?
                      http://img37.imageshack.us/img37/7431/73239079.jpg
                      coz i can't click any U or V axis to fix the map on a flag model 😞
                      I have post it here,:
                      http://forums.sketchucation.com/viewtopic.php?f=79&t=44024&p=393040#p393040
                      can somebody maybe, make a tutorial from my model?
                      sry, im a new start in SU..
                      ty
                        You must tell CurviLoft to generate Quads.
                          mingjae
                          Curviloft can do that thing to? great!
                          but on my PC (SU7), there's no button like yours curviloft,
                          this is what i have:
                          http://img684.imageshack.us/img684/7990/64175044.jpg
                          how to show the button? thx πŸŽ‰
                          • gillesG Offline
                            gilles
                            Check if you have the last version.
                              redlerred7
                              may I give a suggestion?
                              a way to convert version 5 (4?) pseudo quads into version 6 (newest).
                              It's easier for me to use the eraser tool and hide the lines than selecting the lines I want and then changing the properties to make them a quad face
                                404 β€” Bitbucket
                                (bitbucket.org)
                                In version 0.4.0 the definition of a QuadFace changed. In order to use meshes from older QuadFace versions, as well as meshes generated by Sandbox Tools, you have to convert the mesh via this utility first.
                                Not the most obvious - but I figured the early version where not adopted so widely that there would be that many needing it.
                                  @redlerred7 said:
                                  version 6 (newest).
                                  Version 0.7 is the latest.
                                    redlerred7
                                    I forgot the "or" in "version 6(newest), and I didn't know that the sandbox2quad feature worked for version 5(4?) quads. Anyway, thanks for telling me that. I would never have found out otherwise
                                      I've been meaning to improve the documentations. Will probably do so when I release the next update.
                                      I merged the "Upgrade old QuadFace mesh" function with "Convert from Sandbox" because I wanted to reduce the number of buttons and menu items.
                                        tyinykilller5
                                        When i try to install manually it gives me this error:
                                        "Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_QuadFaceTools/core.rb
                                        no such file to load -- TT_Lib2/core.rbError Loading File tt_quadface.rb
                                        no such file to load -- TT_Lib2/core.rb"
                                          • I Offline
                                            ivreich
                                            UV Mapping onto Back Faces?
                                            Hi thomthom
                                            Is there a way to get the UV mapping tool within QuadFaceTools to map textures onto back faces as well? I tried using thrupaint from Fredo but the UI is a lot more complex than the UV tool native to quadfacetools. Also it seems to deal with tranformations differently so it's really hard to get the back faces to match the front faces.
                                            I'm thinking this will be useful for mapping textures with alpha channel, e.g. fencing, where you can actually see through to the back faces beyond. Have attached an image as an example.
                                            cheers
                                            joel
                                            Fencing texture applied to Quadface mesh...how to get the same texture mapped onto the back faces?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 33
                                            • 34
                                            • 13 / 34
