    [Plugin] QuadFaceTools
    680 Posts 116 Posters 772.0k Views 116 Watching
      Do you open the group? You cannot apply mapping to the outside of a group or component.
      Also - why do you want to use copy/paste? In this case it won't map the texture over the whole surface, just fill one of the quads.
      If you want to map the whole surface you should use the UV mapping tool.
      • L
        lapx
        I guess i dont understand how your plugin works:(
        I thought it makes possible mapping texture on curved surfaces without distortions.
        How is this plugin differ from su texture projection method?
        Your right copy paste only worked on one quad. I want to simply map the logo on the entire
        Curved surface. I certain this works w su's projection, i just trying to umderstand the true avantage of your plugin and its optimum use.
          Thomthom's plugin is a lot more useful than projection. Have you a file to map you can share?
            @lapx said:
            I want to simply map the logo on the entire Curved surface.
            Then you want to use the UV Mapping feature. There's a YouTube video that demonstrates it. Have you seen it?
            • T
              Tonyblack
              Hi Thom,
              why after putting QuadFaceTools 0.6.0 in the plugin folder of SketchUp Pro 8 this message appears?
              Thanks and regards,
              Tony
                The error says you need another script to supplement this one.
                The script you need is Thomthoms Lib v2. If you read the download link in this thread you'll notice it mentions it under requirements
                404 β€” Bitbucket
                (bitbucket.org)
                You can get Libv2 here...
                http://forums.sketchucation.com/viewtopic.php?f=323&t=30503
                  [floatr:3lvkx0s1]
                  https://bitbucket.org/thomthom/quadface-tools/wiki/Images/Toolbar_v0_7_0.png
                  [/floatr:3lvkx0s1]
                  Version 0.7.0
                  New Features
                  • Highlight Poles
                  • Build Corners
                  • Build Ends
                  • Convert Wireframe to Quads
                  • Loop to Region
                  Fixed
                  • Selection Tool now also selects entities that isn't quads.
                  • Selection Tool allow triple-click to select all connected.
                  • Cleaned up UI strings.
                  • Cleaned up icons.
                  • Connect Edges' HUD is now movable.
                    Build Corners looks immense πŸ‘
                      πŸ‘ Thanks, yet again...
                      • N
                        nfmdias
                        Hello!
                        I need your help. I'm doing a bridge and I have a problem in texture.
                        I wanted the texture is accompanied by the span of the bridge.
                        Thanks,
                        nfmdias
                          You must create quads for the span of the bridge - then you can use the UV tool to map it.
                          • N
                            nfmdias
                            @nfmdias said:
                            Hello!
                            Thanks,
                            nfmdias
                            well here is the work done ... not bad. I had to do more triangulations.
                            Thanks for the tip.
                            nfmdias
                            bottom view of the bridge
                            • N
                              nfmdias
                              after some time and several attempts ... here is the work ... not bad. I had to do more "triangles".
                              thanks for the tip
                              nfmdias
                                πŸ˜„ πŸ‘ πŸ‘
                                  mingjae
                                  hello,
                                  i want to ask something if u mind,
                                  does quadface works with curviloft-ed models?
                                  http://img37.imageshack.us/img37/7431/73239079.jpg
                                  coz i can't click any U or V axis to fix the map on a flag model 😞
                                  I have post it here,:
                                  http://forums.sketchucation.com/viewtopic.php?f=79&t=44024&p=393040#p393040
                                  can somebody maybe, make a tutorial from my model?
                                  sry, im a new start in SU..
                                  ty
                                    You must tell CurviLoft to generate Quads.
                                      mingjae
                                      Curviloft can do that thing to? great!
                                      but on my PC (SU7), there's no button like yours curviloft,
                                      this is what i have:
                                      http://img684.imageshack.us/img684/7990/64175044.jpg
                                      how to show the button? thx πŸŽ‰
                                      • gillesG
                                        gilles
                                        Check if you have the last version.
                                          redlerred7
                                          may I give a suggestion?
                                          a way to convert version 5 (4?) pseudo quads into version 6 (newest).
                                          It's easier for me to use the eraser tool and hide the lines than selecting the lines I want and then changing the properties to make them a quad face
                                            404 β€” Bitbucket
                                            (bitbucket.org)
                                            In version 0.4.0 the definition of a QuadFace changed. In order to use meshes from older QuadFace versions, as well as meshes generated by Sandbox Tools, you have to convert the mesh via this utility first.
                                            Not the most obvious - but I figured the early version where not adopted so widely that there would be that many needing it.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 33
                                            • 34
                                            • 13 / 34
