    [Plugin] QuadFaceTools
    680 Posts 116 Posters 745.0k Views 116 Watching
      The error says you need another script to supplement this one.
      The script you need is Thomthoms Lib v2. If you read the download link in this thread you'll notice it mentions it under requirements
      404 β€” Bitbucket
      (bitbucket.org)
      You can get Libv2 here...
      http://forums.sketchucation.com/viewtopic.php?f=323&t=30503
        [floatr:3lvkx0s1]
        https://bitbucket.org/thomthom/quadface-tools/wiki/Images/Toolbar_v0_7_0.png
        [/floatr:3lvkx0s1]
        Version 0.7.0
        New Features
        • Highlight Poles
        • Build Corners
        • Build Ends
        • Convert Wireframe to Quads
        • Loop to Region
        Fixed
        • Selection Tool now also selects entities that isn't quads.
        • Selection Tool allow triple-click to select all connected.
        • Cleaned up UI strings.
        • Cleaned up icons.
        • Connect Edges' HUD is now movable.
          Build Corners looks immense πŸ‘
            πŸ‘ Thanks, yet again...
            • N
              nfmdias
              Hello!
              I need your help. I'm doing a bridge and I have a problem in texture.
              I wanted the texture is accompanied by the span of the bridge.
              Thanks,
              nfmdias
                You must create quads for the span of the bridge - then you can use the UV tool to map it.
                • N
                  nfmdias
                  @nfmdias said:
                  Hello!
                  Thanks,
                  nfmdias
                  well here is the work done ... not bad. I had to do more triangulations.
                  Thanks for the tip.
                  nfmdias
                  bottom view of the bridge
                  • N
                    nfmdias
                    after some time and several attempts ... here is the work ... not bad. I had to do more "triangles".
                    thanks for the tip
                    nfmdias
                      πŸ˜„ πŸ‘ πŸ‘
                        mingjae
                        hello,
                        i want to ask something if u mind,
                        does quadface works with curviloft-ed models?
                        http://img37.imageshack.us/img37/7431/73239079.jpg
                        coz i can't click any U or V axis to fix the map on a flag model 😞
                        I have post it here,:
                        http://forums.sketchucation.com/viewtopic.php?f=79&t=44024&p=393040#p393040
                        can somebody maybe, make a tutorial from my model?
                        sry, im a new start in SU..
                        ty
                          You must tell CurviLoft to generate Quads.
                            mingjae
                            Curviloft can do that thing to? great!
                            but on my PC (SU7), there's no button like yours curviloft,
                            this is what i have:
                            http://img684.imageshack.us/img684/7990/64175044.jpg
                            how to show the button? thx πŸŽ‰
                            • gillesG
                              gilles
                              Check if you have the last version.
                                redlerred7
                                may I give a suggestion?
                                a way to convert version 5 (4?) pseudo quads into version 6 (newest).
                                It's easier for me to use the eraser tool and hide the lines than selecting the lines I want and then changing the properties to make them a quad face
                                  404 β€” Bitbucket
                                  (bitbucket.org)
                                  In version 0.4.0 the definition of a QuadFace changed. In order to use meshes from older QuadFace versions, as well as meshes generated by Sandbox Tools, you have to convert the mesh via this utility first.
                                  Not the most obvious - but I figured the early version where not adopted so widely that there would be that many needing it.
                                    @redlerred7 said:
                                    version 6 (newest).
                                    Version 0.7 is the latest.
                                      redlerred7
                                      I forgot the "or" in "version 6(newest), and I didn't know that the sandbox2quad feature worked for version 5(4?) quads. Anyway, thanks for telling me that. I would never have found out otherwise
                                        I've been meaning to improve the documentations. Will probably do so when I release the next update.
                                        I merged the "Upgrade old QuadFace mesh" function with "Convert from Sandbox" because I wanted to reduce the number of buttons and menu items.
                                        • T
                                          tyinykilller5
                                          When i try to install manually it gives me this error:
                                          "Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_QuadFaceTools/core.rb
                                          no such file to load -- TT_Lib2/core.rbError Loading File tt_quadface.rb
                                          no such file to load -- TT_Lib2/core.rb"
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 33
                                            • 34
                                            • 13 / 34
