    [Plugin] QuadFaceTools
    680 Posts 116 Posters 772.0k Views 116 Watching
      Thomthom's plugin is a lot more useful than projection. Have you a file to map you can share?
        @lapx said:
        I want to simply map the logo on the entire Curved surface.
        Then you want to use the UV Mapping feature. There's a YouTube video that demonstrates it. Have you seen it?
        • T
          Tonyblack
          Hi Thom,
          why after putting QuadFaceTools 0.6.0 in the plugin folder of SketchUp Pro 8 this message appears?
          Thanks and regards,
          Tony
            The error says you need another script to supplement this one.
            The script you need is Thomthoms Lib v2. If you read the download link in this thread you'll notice it mentions it under requirements
            404 β€” Bitbucket
            (bitbucket.org)
            You can get Libv2 here...
            http://forums.sketchucation.com/viewtopic.php?f=323&t=30503
              [floatr:3lvkx0s1]
              https://bitbucket.org/thomthom/quadface-tools/wiki/Images/Toolbar_v0_7_0.png
              [/floatr:3lvkx0s1]
              Version 0.7.0
              New Features
              • Highlight Poles
              • Build Corners
              • Build Ends
              • Convert Wireframe to Quads
              • Loop to Region
              Fixed
              • Selection Tool now also selects entities that isn't quads.
              • Selection Tool allow triple-click to select all connected.
              • Cleaned up UI strings.
              • Cleaned up icons.
              • Connect Edges' HUD is now movable.
                Build Corners looks immense πŸ‘
                  πŸ‘ Thanks, yet again...
                  • N
                    nfmdias
                    Hello!
                    I need your help. I'm doing a bridge and I have a problem in texture.
                    I wanted the texture is accompanied by the span of the bridge.
                    Thanks,
                    nfmdias
                      You must create quads for the span of the bridge - then you can use the UV tool to map it.
                      • N
                        nfmdias
                        @nfmdias said:
                        Hello!
                        Thanks,
                        nfmdias
                        well here is the work done ... not bad. I had to do more triangulations.
                        Thanks for the tip.
                        nfmdias
                        bottom view of the bridge
                        • N
                          nfmdias
                          after some time and several attempts ... here is the work ... not bad. I had to do more "triangles".
                          thanks for the tip
                          nfmdias
                            πŸ˜„ πŸ‘ πŸ‘
                              mingjae
                              hello,
                              i want to ask something if u mind,
                              does quadface works with curviloft-ed models?
                              http://img37.imageshack.us/img37/7431/73239079.jpg
                              coz i can't click any U or V axis to fix the map on a flag model 😞
                              I have post it here,:
                              http://forums.sketchucation.com/viewtopic.php?f=79&t=44024&p=393040#p393040
                              can somebody maybe, make a tutorial from my model?
                              sry, im a new start in SU..
                              ty
                                You must tell CurviLoft to generate Quads.
                                  mingjae
                                  Curviloft can do that thing to? great!
                                  but on my PC (SU7), there's no button like yours curviloft,
                                  this is what i have:
                                  http://img684.imageshack.us/img684/7990/64175044.jpg
                                  how to show the button? thx πŸŽ‰
                                  • gillesG
                                    gilles
                                    Check if you have the last version.
                                      redlerred7
                                      may I give a suggestion?
                                      a way to convert version 5 (4?) pseudo quads into version 6 (newest).
                                      It's easier for me to use the eraser tool and hide the lines than selecting the lines I want and then changing the properties to make them a quad face
                                        404 β€” Bitbucket
                                        (bitbucket.org)
                                        In version 0.4.0 the definition of a QuadFace changed. In order to use meshes from older QuadFace versions, as well as meshes generated by Sandbox Tools, you have to convert the mesh via this utility first.
                                        Not the most obvious - but I figured the early version where not adopted so widely that there would be that many needing it.
                                          @redlerred7 said:
                                          version 6 (newest).
                                          Version 0.7 is the latest.
                                            redlerred7
                                            I forgot the "or" in "version 6(newest), and I didn't know that the sandbox2quad feature worked for version 5(4?) quads. Anyway, thanks for telling me that. I would never have found out otherwise
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 33
                                            • 34
                                            • 13 / 34
