    RBZ as allowed extension
    72 Posts 11 Posters 9.5k Views 11 Watching
      driven
      @dan rathbun said:
      "RBZ" is not a format.. ZIP is a format.
      which means there is no need to host both.
      @dan rathbun said:
      Anyway.. it's just as easy to rename the file from rbz to zip, as it is from zip to rbz.
      On Windows, renaming is not even necessary.. you can just right-click a file and say "Open with..." (or if you use 7zip, or similar, it has a context submenu, with an "open archive" choice.)
      .zip and .rbz both open the easily on a mac, right click >> open with, and you can even have them both 'auto' open after download, if you want to set it up.
      so, personally I think SCF and/or the ruby'ists should just change all current .zip extension to .rbz with grep find and replace, and do the same for all the download advice, then any one requiring manual or alternate installs, simply unzips the *.rbz and carries on as usual.
      The current volume of *.rb & *.rbs currently around, all need to be wrapped in a .zip carrying their current name and the .rbz moniker.
      I think it makes sense that if you want a SketchUp ruby it comes in an identifiable package, I can do a search for .rbz and find the entire set of 'unzipped' SU Plugins and reinstall the one I accidentally binned etc...
      A script could clean the entire archive and add or remove the 'mac' file structure at the same time if desired.
      I'm not volunteering to write the script, [maybe GSU team will do it for us]
      I'm just thinking about moving on as it's done... we now have .rbz for SU plugins.
      • jeff hammondJ
        using what? i couldn't open a .rbz with Archive Utility.app (plus is buried a bit too deep for easy access though if it worked, i guess i could associate it with .rbz.. (MacHD/ System/ Library/ Core Services)
        but if i try to unzip a .rbz with it, it actually archives(?) it into a .cpgz file..
        point is, i don't think there's anything that comes with OS X to open them..
        i was going to try to open one with stuffit expander which i suppose would do it but i forgot i never reinstalled that after installing lion.. i just never really liked stuffit so i went looking for something else and i found a real gem of an app..
        it's called better zip..
        http://macitbetter.com/
        that's gotta be the best archive utility available for mac users.. seriously, download and try some things out with it..
        a couple of interesting things to note: you can drag/drop a .rbz (or whatever type of archive) onto it's window and see it's contents.. pull individual items out of it.. add new files to it.. all without unzipping the thing to begin with.. pretty sweet.
        but the thing i'm most hyped on is it allowed me to make my own plugin installer very easily (not really an installer per se but i'll call it that.).. it's a service that will show up in my context menu.. i.e.- Right click on an rbz then 'extract with BetterZip' which i have the following set as the behavior for the context menu:
        it works very well and is much better than either manually installing or going through SUprefs->ext->install
        i might make a separate post about this app in the future.. (i guess i'll use the 30 day trial and if i actually end up buying this thing, i'll make a post πŸ˜„ )
          @gaieus said:
          @dan rathbun said:
          Q: Can ONE file on the server, be downloaded via TWO links, one saves locally with a ".zip" extension, the other with a ".rbz" ?? ... and the user chooses which one they want.
          I dunno. I cannot do it for sure.
          It's possible using .htaccess - though, not sure how SCF would be able to integrate it into the forum - least not for plugins only...
          But it's something I will be doing for Vertex Tools and Bezier Surface which I serve from my own server. Two links which both points to the same binary - just the browser being served different filename.
            driven
            using what?
            Archive Utility as seen in System Preferences
            the very first time before you open one, you need to use 'More Info' >> 'open with' >>../ path to Archive Utility
            first time...
            [/quote]
            If you do this once double clicking will open .rbz by default [unless you override it]
            I also use the free 'The Unarchiver' it's on the App Store [but I get it direct] great for all those odd 'formats'.
            http://itunes.apple.com/gb/app/the-unarchiver/id425424353?mt=12
            I suppose I see the benefits in them not being 'too easy' to open, most mac users would never want to.
            Download 'this_is_great.rbz' >> open SU >> Click rbzBUTTON... that's what's needed.
            This is what we should be requesting, a rbzBUTTON,
            the agument that it will over complicate the interface for non ruby users is a non stater.
            You don't get the 'Plugins' Menu or 'Ruby Console' unless you want rubies, so, as part of that package, a rbzBUTTON could also be configured to 'load' a *.rbz or *.zip into earlier SU versions, running them in current session and also move the files at the same time for future use.
            This is what I think we and the GSUT should be looking into...
            my 2.4 pence worth
            • jeff hammondJ
              right.. tried all that.. tried all the different pref settings in archiveutility etc.. it won't open them.. it archives them into .cpgz files [and when i open the .cpgz file.. i get the original .rbz back].. this is on lion so i'm assuming apple has done something different with it.. archive utility simply won't unzip a .rbz on either of my computers. ❓
              thing is, we should want to because the devs are putting stuff in the zips that we shouldn't be putting in our plugins folders.. using projections.rb that i posted earlier itt as an example.. if i just 'install extensions' that as an rbz, i'll end up with the pdf and a read_me.txt in my plugins folder.. then i'll do it with another plugin which also has a readme in there and i'll now have a read_me 2 .txt... then 3.. and on and on.. the plugins folder is going to end up a mess..
              then there are those plugins with win32 etc files in there that i don't want.. tig's mirror plugin for instance..
              well, i already messed around with building a service in automator (which is in turn available through the sketchup menu so it can also be assigned as a shortcut key.. ) [but on lion, i had to add a step in the service which changed rbz to zip in order to open it]
              it works ok but to me, it's kinda pointless because it still fails to give the option that we should have.. that is an uninstall option.. if i knew apple script, i could probably make it happen but i don't..
                driven
                @Jeff
                I wrote a bash script that auto converts a copy of the rbz to zip 'with folders' for investigating, if it full of dross I can repackage and rezip as rbz, replacing the original. It needs some more work, but could run on multiple files at once.
                To be honest individually, it's easier manually, once I set up Archive Utility... I should have tried that first, but when Jim mentioned shell scripts...
                Removing from Plugins Folder from inside SU with automator/applescript or shell isn't hard, but any 'loaded' ruby won't go away until you restart SU.
                I think I've got a snippet if your interested...
                • jeff hammondJ
                  yeah, i wasn't really talking about uninstalling and unloading from an active sketchup at the same time. (though that's what should be able to happen)
                  i'm basically thinking there should be a way to install a .rbz (say it has file1.rb, file2.pdf, file2.txt, and folder4) then all those file names are stored/associated with that particular plugin so if we choose to uninstall, we can easily trash everything that came in with the original .rbz.
                  i'm sure there are some 3rd party apps to do this but the option should be within sketchup itself.. i'm not sure how much of the 'install extensions' is exposed via the api but it seems like a ruby could be made for this purpose.. basically, two icons β€” install and uninstall.. clicking the install icon is basically the same as the 'install extensions' via su preferences except it takes note of what files actually went to the plugins folder.. clicking 'uninstall' brings up a list of what you've already installed and you can choose which plug ins to remove β€” and it deletes all files that came in with it during the install procedure... at the same time, unloading it from the current sketchup..
                  or is that impossible?
                  πŸ˜„
                    driven
                    Actually, have you ever looked at a .DS_Store file, they open in TextEdit.
                    When new Items are added to it, they could also be 'listed in sets' in a 'WebDialog' by writing that list to html.
                    Linking that html list to applescript folder actions would let you move stuff around..
                    Pre-existing rubies and folders could be manually grouped in the wd, and could show as enabled or disabled depending on where you 'park' or append, the main ruby.
                    Anything added by 'Extension Manager' could be re-organised after the instal. i.e. dump the .dbthumbs etc... although that could be an auto folder action to remove those things.
                    that way your load button is just a shortcut to 'Extension Manager' and SU does it's stuff, but the remove button opens the 'webdialog' and lets you edit/disable/remove whatever you want by manipulating a single [per set] control item...
                    food for thoughthttp://www.tuaw.com/2009/03/26/applescript-exploring-the-power-of-folder-actions-part-iii/
                    • jeff hammondJ
                      yeah,see .. that sounds sweet..
                      the problem, for me at least, is that while i do understand the basics of what you're outlining and i think it makes sense β€” i don't know how to make it happen..
                      all of my 'programing' is done via automator πŸ˜„
                        driven
                        I'll have a crack at it... making use of DS_Store looks intriguing. if I have any joy I'll start a new post, call for testers/contributors. john
                          Aerilius
                          Ruby itself has methods to create/move/copy/delete files (also a reason only to install trusted scripts). Since SketchUp's new API method can only install an rbz by just extracting whatever files were in the archive, the challenge is to keep track what files belong together.
                          Have you discovered what is coming soon? http://forums.sketchucation.com/viewtopic.php?f=344&t=38197
                          • jeff hammondJ
                            hmm.. nope πŸ˜„
                            You are not authorised to read this forum.
                              driven
                              can Ruby keep track of files/folders, i.e. is there a watch folder ruby that adds no overhead to SU, DS_Store is there already and can trigger external events only on Change. that's just my thought. no additional observers...
                              Adding load date to a remote list would keep track of what's being added or subtracted.
                              I haven't had a huge amount of joy with this, even though it's written on a mac. It need to take on the new API changes next, then maybe...
                                driven
                                Understandable... you need a tux to be invited... john
                                  πŸ˜’
                                  • jeff hammondJ
                                    ha.. i guess i gotta put my tux on then.. just checked my inbox and i do have an invite πŸ˜„
                                    i was on a job when that was sent.. i have this bad habit of pretty much ignoring everything when i'm in the middle of a project πŸ˜’
                                    [edit] oh word.. i'm a top sketchucator as well.. πŸ˜„
                                    is that what the green names are all about?
                                    [edit2] uh. nvm.. i guess it does say 'top sketchucator' under the green names..
                                      driven
                                      Pacifist.app also opens rbz if you cmd alt drag them on to the dock icon.
                                      It's a very useful mac install tool, shareware. john
                                      • JuantxoJ
                                        Juantxo
                                        Hello,
                                        I have a problem with rbz file. In my web I have a rbz file to download but
                                        windows 7 changes automatically the extension and users download zip file, not the real rbz.
                                        You can see the problem in skelion.net. If you put mouse over download you can see the name of the file to download,
                                        "skelion_v503.rbz" but afer download you have "skelion_v503.zip" not "skelion_v503.rbz".
                                        Someone knows something about this problem?
                                        • jeff hammondJ
                                          @juantxo said:
                                          Hello,
                                          for what it's worth, i just downloaded the file at skelion.net and it came in as .rbz.. not .zip..
                                          (OS X.7 / Safari)
                                          have you tried a different browser? or do you think it's the actual OS doing the changing?
                                          • JuantxoJ
                                            Juantxo
                                            I think is windows 7 but not sure. With chrome and with explorer in windows 7 extension is changed automatically.
                                            In XP not. But I don't have windows 7, so I never saw this transformation. Some users with problems tell me about this.
                                            • 3 / 4
