    RBZ as allowed extension
    72 Posts 11 Posters 6.5k Views 11 Watching
      driven
      @Jeff
      I wrote a bash script that auto converts a copy of the rbz to zip 'with folders' for investigating, if it full of dross I can repackage and rezip as rbz, replacing the original. It needs some more work, but could run on multiple files at once.
      To be honest individually, it's easier manually, once I set up Archive Utility... I should have tried that first, but when Jim mentioned shell scripts...
      Removing from Plugins Folder from inside SU with automator/applescript or shell isn't hard, but any 'loaded' ruby won't go away until you restart SU.
      I think I've got a snippet if your interested...
      • jeff hammondJ Offline
        yeah, i wasn't really talking about uninstalling and unloading from an active sketchup at the same time. (though that's what should be able to happen)
        i'm basically thinking there should be a way to install a .rbz (say it has file1.rb, file2.pdf, file2.txt, and folder4) then all those file names are stored/associated with that particular plugin so if we choose to uninstall, we can easily trash everything that came in with the original .rbz.
        i'm sure there are some 3rd party apps to do this but the option should be within sketchup itself.. i'm not sure how much of the 'install extensions' is exposed via the api but it seems like a ruby could be made for this purpose.. basically, two icons β€” install and uninstall.. clicking the install icon is basically the same as the 'install extensions' via su preferences except it takes note of what files actually went to the plugins folder.. clicking 'uninstall' brings up a list of what you've already installed and you can choose which plug ins to remove β€” and it deletes all files that came in with it during the install procedure... at the same time, unloading it from the current sketchup..
        or is that impossible?
        πŸ˜„
          driven
          Actually, have you ever looked at a .DS_Store file, they open in TextEdit.
          When new Items are added to it, they could also be 'listed in sets' in a 'WebDialog' by writing that list to html.
          Linking that html list to applescript folder actions would let you move stuff around..
          Pre-existing rubies and folders could be manually grouped in the wd, and could show as enabled or disabled depending on where you 'park' or append, the main ruby.
          Anything added by 'Extension Manager' could be re-organised after the instal. i.e. dump the .dbthumbs etc... although that could be an auto folder action to remove those things.
          that way your load button is just a shortcut to 'Extension Manager' and SU does it's stuff, but the remove button opens the 'webdialog' and lets you edit/disable/remove whatever you want by manipulating a single [per set] control item...
          food for thoughthttp://www.tuaw.com/2009/03/26/applescript-exploring-the-power-of-folder-actions-part-iii/
            yeah,see .. that sounds sweet..
            the problem, for me at least, is that while i do understand the basics of what you're outlining and i think it makes sense β€” i don't know how to make it happen..
            all of my 'programing' is done via automator πŸ˜„
              driven
              I'll have a crack at it... making use of DS_Store looks intriguing. if I have any joy I'll start a new post, call for testers/contributors. john
                Aerilius
                Ruby itself has methods to create/move/copy/delete files (also a reason only to install trusted scripts). Since SketchUp's new API method can only install an rbz by just extracting whatever files were in the archive, the challenge is to keep track what files belong together.
                Have you discovered what is coming soon? http://forums.sketchucation.com/viewtopic.php?f=344&t=38197
                  hmm.. nope πŸ˜„
                  You are not authorised to read this forum.
                    driven
                    can Ruby keep track of files/folders, i.e. is there a watch folder ruby that adds no overhead to SU, DS_Store is there already and can trigger external events only on Change. that's just my thought. no additional observers...
                    Adding load date to a remote list would keep track of what's being added or subtracted.
                    I haven't had a huge amount of joy with this, even though it's written on a mac. It need to take on the new API changes next, then maybe...
                      driven
                      Understandable... you need a tux to be invited... john
                        πŸ˜’
                          ha.. i guess i gotta put my tux on then.. just checked my inbox and i do have an invite πŸ˜„
                          i was on a job when that was sent.. i have this bad habit of pretty much ignoring everything when i'm in the middle of a project πŸ˜’
                          [edit] oh word.. i'm a top sketchucator as well.. πŸ˜„
                          is that what the green names are all about?
                          [edit2] uh. nvm.. i guess it does say 'top sketchucator' under the green names..
                            driven
                            Pacifist.app also opens rbz if you cmd alt drag them on to the dock icon.
                            It's a very useful mac install tool, shareware. john
                            • JuantxoJ Offline
                              Juantxo
                              Hello,
                              I have a problem with rbz file. In my web I have a rbz file to download but
                              windows 7 changes automatically the extension and users download zip file, not the real rbz.
                              You can see the problem in skelion.net. If you put mouse over download you can see the name of the file to download,
                              "skelion_v503.rbz" but afer download you have "skelion_v503.zip" not "skelion_v503.rbz".
                              Someone knows something about this problem?
                                @juantxo said:
                                Hello,
                                for what it's worth, i just downloaded the file at skelion.net and it came in as .rbz.. not .zip..
                                (OS X.7 / Safari)
                                have you tried a different browser? or do you think it's the actual OS doing the changing?
                                • JuantxoJ Offline
                                  Juantxo
                                  I think is windows 7 but not sure. With chrome and with explorer in windows 7 extension is changed automatically.
                                  In XP not. But I don't have windows 7, so I never saw this transformation. Some users with problems tell me about this.
                                    I suppose I'm the wrong person to discuss this as I know next to nothing about windows but maybe there's a right click option to download the file as it is on your site?
                                    right click-> 'download linked file as...'
                                    or something?
                                      Does it happen some anywhere else but that site? It could be an issue with how the file is served from that server. I had problems with .gadget files being downloaded as .zip in Internet Explorer - but that was due to some HTTP headers not being right.
                                      • JuantxoJ Offline
                                        Juantxo
                                        I'm not sure, I don't have windows 7, but its very weird this automatic extension change from ".rbz" to ".zip". It could be a security issue maybe.
                                        • JuantxoJ Offline
                                          Juantxo
                                          Finally I couldn't solve the problem. Windows 7 changes extension of rbz to zip when user download from web page.
                                          So I'm going to use zip file extension. I'm agree with Dan. I think is not necessary have two names for same extension.
                                            Question is, does it happen just on skelion.net? I've never gotten a .rbz as .zip - but I didn't get around to test from skelion.net.
                                            What happen if you download a .rbz from SCF? Try my attached file.
                                            Test File
                                            • 3 / 4
