    [Plugin] Super Drape
    192 Posts 54 Posters 383.7k Views 54 Watching
      nahnahnahnahnahnaaah - SuperDraaaaape!
        Bug splats for me. I tried it with the surface from that 231 model I posted yesterday and a simple circle drawn above it. I'll post a model as soon as I can.
        • W Offline
          wyatt
          This is how the Sandbox tool should have worked from the very beginning. Awesome work! ๐Ÿ‘
          The Tigtools folder in the zip file is empty. Is it supposed to contain the toolbar icons, or do they still need to be designed?
          • kenK Offline
            ken
            Whoa! Am I the only one without a icon image.
            Ken
              Nope
              • TIGT Online
                I'm having a bad day - that bottle of Chianti has a lot to answer for ๐Ÿ˜ฎ
                I have updated the missing PNG files so if the 20 or so of you would like to reinstall from the updated zip file it should work... ๐Ÿ˜ณ
                http://forums.sketchucation.com/viewtopic.php?p=358314#p358314
                • TIGT Online
                  What size is it? - it might be a scaling problem?? ๐Ÿ˜•
                    I don't think it should be a scaling issue. I've recreated it and post it here. I only tried to drape the circle onto the surface below.
                    231.skp
                    • TIGT Online
                      I too get the Bugsplat - weird - there seems nothing untoward at all - I'm investigating...
                        Thank you.
                        • TIGT Online
                          Something weird about your mesh - how was it made ?
                          There are two missing diagonals to the side - when I added those it seemed better ?
                          I also used cut/paste_in_place on the mesh, which seemed to jolt it into submission.
                          It then SuperDraped OK but the material cloning was poor so I scaled up x10 with no improvement in the materials.
                          The 231 SuperDrapes readily onto a flat surface so I still have some investigating to uncover the issues...
                          I trialed it during today with various forms of draper/drapee groups without incident or loss of materials - thrust you to break it [thanks ๐Ÿ˜‰ ]Capture.PNG ๐Ÿ˜•
                            Curious. I drew the curves by putting arcs on the sides of a large box. Then I used Fredo's "Skinning of Shapes" tool to create the skin. I saw there were a few diagonals that weren't drawn in but I figured since the surface skinned over alright, they weren't needed.
                            Fix it and I'll break it again. ๐Ÿ˜„
                            • utilerU Offline
                              utiler
                              Awesome, TIG!!!!!!!!
                              Just Curious...
                              • bazB Offline
                                baz
                                Brilliant, thanks Tig.
                                • Bob JamesB Offline
                                  Bob James
                                  Thanks, TIG: Works great. On an object the text or texture is copied on the top and on the bottom (almost)!
                                  • TIGT Online
                                    I'm looking at trapping faces that are looking away from the draped group...
                                    Meanwhile some careful erasing should fix it ?
                                    • srxS Offline
                                      srx
                                      Thanks TIG.
                                      www.saurus.rs
                                        blajnov
                                        Thanks TIG.
                                        In kirill2008, there is a similar plug-in on your, "Lss_Tool_Bar"
                                          Ben Ritter
                                          TIG, thank you very much.
                                            seven.sides
                                            Thanks TIG, this will be very usefull.
                                            • 1 / 10
