    [Plugin] Super Drape
    192 Posts 54 Posters 391.4k Views 54 Watching
      Bug splats for me. I tried it with the surface from that 231 model I posted yesterday and a simple circle drawn above it. I'll post a model as soon as I can.
      • W
        wyatt
        This is how the Sandbox tool should have worked from the very beginning. Awesome work! ๐Ÿ‘
        The Tigtools folder in the zip file is empty. Is it supposed to contain the toolbar icons, or do they still need to be designed?
        • kenK
          ken
          Whoa! Am I the only one without a icon image.
          Ken
            Nope
              I'm having a bad day - that bottle of Chianti has a lot to answer for ๐Ÿ˜ฎ
              I have updated the missing PNG files so if the 20 or so of you would like to reinstall from the updated zip file it should work... ๐Ÿ˜ณ
              http://forums.sketchucation.com/viewtopic.php?p=358314#p358314
                What size is it? - it might be a scaling problem?? ๐Ÿ˜•
                  I don't think it should be a scaling issue. I've recreated it and post it here. I only tried to drape the circle onto the surface below.
                  231.skp
                    I too get the Bugsplat - weird - there seems nothing untoward at all - I'm investigating...
                      Thank you.
                        Something weird about your mesh - how was it made ?
                        There are two missing diagonals to the side - when I added those it seemed better ?
                        I also used cut/paste_in_place on the mesh, which seemed to jolt it into submission.
                        It then SuperDraped OK but the material cloning was poor so I scaled up x10 with no improvement in the materials.
                        The 231 SuperDrapes readily onto a flat surface so I still have some investigating to uncover the issues...
                        I trialed it during today with various forms of draper/drapee groups without incident or loss of materials - thrust you to break it [thanks ๐Ÿ˜‰ ]Capture.PNG ๐Ÿ˜•
                          Curious. I drew the curves by putting arcs on the sides of a large box. Then I used Fredo's "Skinning of Shapes" tool to create the skin. I saw there were a few diagonals that weren't drawn in but I figured since the surface skinned over alright, they weren't needed.
                          Fix it and I'll break it again. ๐Ÿ˜„
                          • utilerU
                            utiler
                            Awesome, TIG!!!!!!!!
                            Just Curious...
                            • bazB
                              baz
                              Brilliant, thanks Tig.
                              • Bob JamesB
                                Bob James
                                Thanks, TIG: Works great. On an object the text or texture is copied on the top and on the bottom (almost)!
                                  I'm looking at trapping faces that are looking away from the draped group...
                                  Meanwhile some careful erasing should fix it ?
                                  • srxS
                                    srx
                                    Thanks TIG.
                                    www.saurus.rs
                                    • B
                                      blajnov
                                      Thanks TIG.
                                      In kirill2008, there is a similar plug-in on your, "Lss_Tool_Bar"
                                      • B
                                        Ben Ritter
                                        TIG, thank you very much.
                                          seven.sides
                                          Thanks TIG, this will be very usefull.
                                            Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=358314#p358314 โ˜€
                                            Face 'pairing' of materials between the groups is now more robust, consistent and very unlikely to fail.
                                            Only topmost faces now usually gets draped onto - if you have overlapping faces in the groups the drape should not now 'punch through' onto lower faces, unless the faces are with ~5mm of each other vertically - still it's best to have single-skin meshes to super-drape...
                                            The splat/error reported by Dave_R is now avoided by recoding... BUT it doesn't fix his mesh itself, which had two quad-faces that appeared coplanar but caused splats because when the mesh was intersecting with other entities they made the result unstable - after erasing those two faces they would no reface with 'find_faces', but adding a diagonal fixes the issue as they two triangles are just on the cusp of the difference between a viable quad and two triangular faces that are not coplanar. I await for Dave to re-break this version ๐Ÿ˜•
                                            • 1 / 10
