    [Plugin] Super Drape
    192 Posts 54 Posters 383.7k Views 54 Watching
      Top tool ๐Ÿ‘
      Thanks TIG
        nahnahnahnahnahnaaah - SuperDraaaaape!
          Bug splats for me. I tried it with the surface from that 231 model I posted yesterday and a simple circle drawn above it. I'll post a model as soon as I can.
          • W Offline
            wyatt
            This is how the Sandbox tool should have worked from the very beginning. Awesome work! ๐Ÿ‘
            The Tigtools folder in the zip file is empty. Is it supposed to contain the toolbar icons, or do they still need to be designed?
            • kenK Offline
              ken
              Whoa! Am I the only one without a icon image.
              Ken
                Nope
                • TIGT Online
                  I'm having a bad day - that bottle of Chianti has a lot to answer for ๐Ÿ˜ฎ
                  I have updated the missing PNG files so if the 20 or so of you would like to reinstall from the updated zip file it should work... ๐Ÿ˜ณ
                  http://forums.sketchucation.com/viewtopic.php?p=358314#p358314
                  • TIGT Online
                    What size is it? - it might be a scaling problem?? ๐Ÿ˜•
                      I don't think it should be a scaling issue. I've recreated it and post it here. I only tried to drape the circle onto the surface below.
                      231.skp
                      • TIGT Online
                        I too get the Bugsplat - weird - there seems nothing untoward at all - I'm investigating...
                          Thank you.
                          • TIGT Online
                            Something weird about your mesh - how was it made ?
                            There are two missing diagonals to the side - when I added those it seemed better ?
                            I also used cut/paste_in_place on the mesh, which seemed to jolt it into submission.
                            It then SuperDraped OK but the material cloning was poor so I scaled up x10 with no improvement in the materials.
                            The 231 SuperDrapes readily onto a flat surface so I still have some investigating to uncover the issues...
                            I trialed it during today with various forms of draper/drapee groups without incident or loss of materials - thrust you to break it [thanks ๐Ÿ˜‰ ]Capture.PNG ๐Ÿ˜•
                              Curious. I drew the curves by putting arcs on the sides of a large box. Then I used Fredo's "Skinning of Shapes" tool to create the skin. I saw there were a few diagonals that weren't drawn in but I figured since the surface skinned over alright, they weren't needed.
                              Fix it and I'll break it again. ๐Ÿ˜„
                              • utilerU Offline
                                utiler
                                Awesome, TIG!!!!!!!!
                                Just Curious...
                                • bazB Offline
                                  baz
                                  Brilliant, thanks Tig.
                                  • Bob JamesB Offline
                                    Bob James
                                    Thanks, TIG: Works great. On an object the text or texture is copied on the top and on the bottom (almost)!
                                    • TIGT Online
                                      I'm looking at trapping faces that are looking away from the draped group...
                                      Meanwhile some careful erasing should fix it ?
                                      • srxS Offline
                                        srx
                                        Thanks TIG.
                                        www.saurus.rs
                                          blajnov
                                          Thanks TIG.
                                          In kirill2008, there is a similar plug-in on your, "Lss_Tool_Bar"
                                            Ben Ritter
                                            TIG, thank you very much.
                                            • 1 / 10
