    [Plugin] Super Drape
    192 Posts 54 Posters 383.7k Views 54 Watching
    • TIGT Online
      @dave r said:
      Bug splats for me. I tried it with the surface from that 231 model I posted yesterday and a simple circle drawn above it. I'll post a model as soon as I can.
      What size is it? - it might be a scaling problem?? 😕
        I don't think it should be a scaling issue. I've recreated it and post it here. I only tried to drape the circle onto the surface below.
        231.skp
        • TIGT Online
          I too get the Bugsplat - weird - there seems nothing untoward at all - I'm investigating...
            Thank you.
            • TIGT Online
              Something weird about your mesh - how was it made ?
              There are two missing diagonals to the side - when I added those it seemed better ?
              I also used cut/paste_in_place on the mesh, which seemed to jolt it into submission.
              It then SuperDraped OK but the material cloning was poor so I scaled up x10 with no improvement in the materials.
              The 231 SuperDrapes readily onto a flat surface so I still have some investigating to uncover the issues...
              I trialed it during today with various forms of draper/drapee groups without incident or loss of materials - thrust you to break it [thanks 😉 ]Capture.PNG 😕
                Curious. I drew the curves by putting arcs on the sides of a large box. Then I used Fredo's "Skinning of Shapes" tool to create the skin. I saw there were a few diagonals that weren't drawn in but I figured since the surface skinned over alright, they weren't needed.
                Fix it and I'll break it again. 😄
                • utilerU Offline
                  utiler
                  Awesome, TIG!!!!!!!!
                  Just Curious...
                  • bazB Offline
                    baz
                    Brilliant, thanks Tig.
                    • Bob JamesB Offline
                      Bob James
                      Thanks, TIG: Works great. On an object the text or texture is copied on the top and on the bottom (almost)!
                      • TIGT Online
                        I'm looking at trapping faces that are looking away from the draped group...
                        Meanwhile some careful erasing should fix it ?
                        • srxS Offline
                          srx
                          Thanks TIG.
                          www.saurus.rs
                            blajnov
                            Thanks TIG.
                            In kirill2008, there is a similar plug-in on your, "Lss_Tool_Bar"
                              Ben Ritter
                              TIG, thank you very much.
                                seven.sides
                                Thanks TIG, this will be very usefull.
                                • TIGT Online
                                  Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=358314#p358314 ☀
                                  Face 'pairing' of materials between the groups is now more robust, consistent and very unlikely to fail.
                                  Only topmost faces now usually gets draped onto - if you have overlapping faces in the groups the drape should not now 'punch through' onto lower faces, unless the faces are with ~5mm of each other vertically - still it's best to have single-skin meshes to super-drape...
                                  The splat/error reported by Dave_R is now avoided by recoding... BUT it doesn't fix his mesh itself, which had two quad-faces that appeared coplanar but caused splats because when the mesh was intersecting with other entities they made the result unstable - after erasing those two faces they would no reface with 'find_faces', but adding a diagonal fixes the issue as they two triangles are just on the cusp of the difference between a viable quad and two triangular faces that are not coplanar. I await for Dave to re-break this version 😕
                                  • charly2008C Offline
                                    charly2008
                                    Hi TIG,
                                    I've tried it with no success. I do not know if that's my fault. See Picture below.
                                    Charly
                                    Untitled.skp
                                    • TIGT Online
                                      Charly 😒
                                      I can't get any error messages, BUT I don't get a good result either!
                                      BUT if I explode each group in turn and immediately regroup the highlighted entities... and then use SuperDrape with them it works just fine 😕
                                      I suspect that there's some duplicate/tiny faces or similar 'errors' is the group[s] that cause issues - but the explode+regroup fixes them...
                                      I'll see what I can come up with - in the meanwhile use the explode+regroup trick and it seems fine again...Capture.PNG
                                        charly2008
                                        Thanks for the tip. Your plugin has a great potential as always.
                                        • MALAISEM Offline
                                          MALAISE
                                          Simply, thanks 😄
                                          MALAISE
                                          • W Offline
                                            wolfy
                                            VERY COOL! Thanks TIG this will come in extremely handy. ☀
                                            • 1 / 10
