    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
    • dereiD
      derei
      In this post http://forums.sketchucation.com/viewtopic.php?f=323&t=17948&start=615#p349363 the target point for scaling was outside active model, so I was thinking that is the problem.
      Now, in this model, the target is inside active BUT, the axis are not aligned with default. You will see the edges colored by Axis, because I oriented them in accordance with the model, but are not aligned with "Word UCS"(don't know if this is the correct naming; it's a reminiscence from AutoCAD 💚)
      Could this help you to try fixing it?
      DESIGNER AND ARTIST DEREI.UK
        rjjvirusx
        • fredo6F
          Thank you.[attachment=0:9hv2aqq3]<!-- ia0 -->fredoscale target error.jpg<!-- ia0 -->[/attachment:9hv2aqq3]
          Could you post your model, so that I have a look.
          Just in case, FredoScale allows to orientate the box according to the axis of the component (Arrow Right) or the axis of the model (Arrow up)
          • P
            patriarch
            FredoScale hangs Sketchup, when used together groups and components, as well as nested groups and components.
            For example, one component contains a group 1 and components 1 and 2. Component 2 contains a group 2 and component 3 and 4.
            This bug was in the first version of the plugin and it's still not fixed.
            • dereiD
              derei
              inferencing problem (detailed)
              Sorry for not posting a youtube movie, I just uploaded it here, because I don't have a youtube account.
              fredoscale.wmv
              • fredo6F
                I know I need to rework all this more accurately. I'll try to do it whenever I have time
                • fredo6F
                  Could you post a model and tell me more about which tool you use, when it hangs (at selection, while generating the geometry, ...?)
                  • P
                    patriarch
                    Ok. Please, see attachments..
                    fredoscale-test-01.skp
                    fredoscale-test-03.swf
                    • bagateloB
                      bagatelo
                      The problem seems to be that we can not have a large and deep hierarchy of objects in outliner.
                      Try the shared model and see how the model is organized in outliner.
                      • fredo6F
                        Yes, it's definitely a problem when the Outliner is openand the transformation is interactive and operates on components that exist in several instances (like Stretch).
                        I think this was already signaled and I don't know too much what can be done about it.
                          Jim Foltz / CPhillips [I think 😕 ] made a PC tool to roll-up the Outliner if it's open so that the crashing stops - there's also a send_action PC code... See this http://forums.sketchucation.com/viewtopic.php?f=180&t=15782&p=123147&hilit=rollup#p123147
                          • bagateloB
                            bagatelo
                            This can be a problem. But not exactly in this situation.
                            • F
                              fumaru
                              This is GODLY!!!!!!!!!
                              One of the most power plugins i have ever seen !!!! a must have for any 3Ds max users that is using sketchUp!!! 😍
                                shade69
                                you are awesome!
                                • N
                                  numnung
                                  thanK good.
                                  • F
                                    fzamr
                                    hey everyone...i need help n quick!!..i keep having a bug error when i try to bend using this plugin ..the same bug thing happens when i tried using shape bender plugin.. whatever i do..i am unable to bend shapes...i m following the instructions but every time when i m just about to bend the shape .. sketch up closes and i get a bug notification..same thing is happening with shape bender plugin.. can somebody help me plz???...i have an assignment due soon.....HELP!!!
                                      When you get an error message, always report it back. Otherwise it's not likley that the developer can track down what the error is.
                                        It would help if you could post the model that is causing you trouble, too. Since both plugins work fine for the vast majority of users, it's likely that there's something wrong with the install or with the model.
                                        If you need help quickly, you need to give enough information to let us help you.
                                        • F
                                          fzamr
                                          i finally figured out the problem ..my podium plugin was the culprit..for some odd reasons it was not letting the other plugins work...podium was also not working...but when i deleted it..everything is working fyne now...wat a relief!!
                                          • GaieusG
                                            This is still one of the greatest and most complex and feature rich plugins. Thanks Fredo very-very much!
                                            (And considering you could easily be selling this for $ 20-30, even more 👍 👍 👍 !)
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 58
                                            • 59
                                            • 33 / 59
