    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
    • fredo6F
      Yes, it's definitely a problem when the Outliner is openand the transformation is interactive and operates on components that exist in several instances (like Stretch).
      I think this was already signaled and I don't know too much what can be done about it.
        Jim Foltz / CPhillips [I think ๐Ÿ˜• ] made a PC tool to roll-up the Outliner if it's open so that the crashing stops - there's also a send_action PC code... See this http://forums.sketchucation.com/viewtopic.php?f=180&t=15782&p=123147&hilit=rollup#p123147
        • bagateloB
          bagatelo
          This can be a problem. But not exactly in this situation.
          The problem seems to be that we can not have a large and deep hierarchy of objects in outliner.
          Try the shared model and see how the model is organized in outliner.
          • F
            fumaru
            This is GODLY!!!!!!!!!
            One of the most power plugins i have ever seen !!!! a must have for any 3Ds max users that is using sketchUp!!! ๐Ÿ˜
              shade69
              you are awesome!
              • N
                numnung
                thanK good.
                • F
                  fzamr
                  hey everyone...i need help n quick!!..i keep having a bug error when i try to bend using this plugin ..the same bug thing happens when i tried using shape bender plugin.. whatever i do..i am unable to bend shapes...i m following the instructions but every time when i m just about to bend the shape .. sketch up closes and i get a bug notification..same thing is happening with shape bender plugin.. can somebody help me plz???...i have an assignment due soon.....HELP!!!
                    When you get an error message, always report it back. Otherwise it's not likley that the developer can track down what the error is.
                      It would help if you could post the model that is causing you trouble, too. Since both plugins work fine for the vast majority of users, it's likely that there's something wrong with the install or with the model.
                      If you need help quickly, you need to give enough information to let us help you.
                      • F
                        fzamr
                        i finally figured out the problem ..my podium plugin was the culprit..for some odd reasons it was not letting the other plugins work...podium was also not working...but when i deleted it..everything is working fyne now...wat a relief!!
                        • GaieusG
                          This is still one of the greatest and most complex and feature rich plugins. Thanks Fredo very-very much!
                          (And considering you could easily be selling this for $ 20-30, even more ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ !)
                            davelee100
                            Hello everyone
                            I have just registered after purchasing Sketchup Pro 8.
                            I do have experience with sketchup having played with the free versions in the past but now I am ready to get serious with this software.
                            I have seen the video clips on Fredoscale and this is definitely something I need in my work but because I am a complete newbie with installing sketchup tools I wonder if some kind person would post up an idiots guide to downloading and installing Fredoscale for the first time.
                            I really need a blow by blow breakdown on all the steps and if there is any other software I need to make it simpler.
                            Thank you for your patience
                            David
                            • GaieusG
                              Hi David and welcome.
                              First of all, this is the place you need to install your plugins on Mac:
                              Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp
                              Then here is a forum post about how to install more complex plugins (which are generally consist of several files therefore zipped):
                              http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
                              Also note that in order for FredoScale to work, you need an additional plugin library LibFredo (linked from his first post)
                              • pbacotP
                                David,
                                I see you are using Mac OS. One thing I find useful is to put the (alias of) the Plugins folder into my sidebar. Then I can drag from the downloads folder to the plugins folder any time. Makes the whole process pretty painless. If the files are zipped, I usually unzip it in the downloads folder and take the files I need from there. Note that when you unzip in Mac it creates a folder, when there are multiple files. You want what is in that folder--not that folder itself.
                                This is a great plugin. Takes some learning. But save before you use, especially on complex objects.
                                Peter
                                  davelee100
                                  Thanks guys... good information.... i will try this in the morning
                                  • dereiD
                                    derei
                                    I used FredoScale - stretching with orientation of scaling box on this model and caused bugsplat. Is it possible to fix the plugin? It's a group that has inside some components. I applied FredoScale on a copy of that group.
                                    EDIT: if I enter the group, it becomes unique and it can be stretched. My suggestion: FredoScale to make it unique group prior editing. Maybe SU tries to update Group's definition and that is why it ends in bugsplat.
                                    bugsplat.skp
                                    DESIGNER AND ARTIST DEREI.UK
                                    • B
                                      bricofranck59
                                      Hello
                                      Merci beaucoup, ce plugin est vraiment formidable
                                      Francis
                                      • G
                                        griffeur
                                        Hi!
                                        Do you know how can I do something like the "scaling by reference" in autocad? The scaling target mode doesn't seem to work in the same way. Thanks!
                                        • fredo6F
                                          @griffeur said:
                                          Hi!
                                          This is an interesting function which is not supported by FredoScale exactly in the same way. The Scale to Target requires that you scale in the same direction than the target points (even if they can be taken from anywhere in the model).
                                          The idea behind is to perform the scaling (or other) transformation which brings the origin to the target.
                                          Maybe I'll add the feature in a next release.
                                          • G
                                            griffeur
                                            Thanks! This kind of Scaling is realy important for me in architecture modeling(plan scaling, etc...)
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 58
                                            • 59
                                            • 33 / 59
