    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
    • fredo6F
      @samlion said:
      ...except the fact that when i click the default parameter option (Tools/Fredo6 collection/Fredoscale/Default parameters...), nothing happen.
      I just receive a message in the status bar "Load all ruby files for plugin FredoScale --> 40 ms"
      Richard,
      Can you open the Ruby console and see if a message is displayed.
      Also which version of FredoScale and LibFredo6 do you run (go to their About... menu).
        samlion
        Hi Fredo, thanks for your answer.
        The version for LiFredo6 is v3.7c and the version for FredoScale is v2.2a.
        When I open the ruby console, there is nothing; its look like a white square where we can enter some commands.
        Thanks in advance for your help.
        Richard G.
        also, the directory DEFPARAM_Dir is empty; there is no file fredoscale.def.
        • fredo6F
          Just in case, did you open the ruby console, and THEN, try to call the FredoScale Default Parameters dialog box, to see if a message is displayed in the console?
            samlion
            Hi Fredo,
            I have tried what you mentionned (opening ruby console and then call for default parameters option) and nothing appear in the ruby console.
            Thanks in advance.
            Richard G.
            • dereiD
              derei
              In this post http://forums.sketchucation.com/viewtopic.php?f=323&t=17948&start=615#p349363 the target point for scaling was outside active model, so I was thinking that is the problem.
              Now, in this model, the target is inside active BUT, the axis are not aligned with default. You will see the edges colored by Axis, because I oriented them in accordance with the model, but are not aligned with "Word UCS"(don't know if this is the correct naming; it's a reminiscence from AutoCAD 💚)
              Could this help you to try fixing it?
              DESIGNER AND ARTIST DEREI.UK
                rjjvirusx
                • fredo6F
                  Thank you.[attachment=0:9hv2aqq3]<!-- ia0 -->fredoscale target error.jpg<!-- ia0 -->[/attachment:9hv2aqq3]
                  Could you post your model, so that I have a look.
                  Just in case, FredoScale allows to orientate the box according to the axis of the component (Arrow Right) or the axis of the model (Arrow up)
                  • P
                    patriarch
                    FredoScale hangs Sketchup, when used together groups and components, as well as nested groups and components.
                    For example, one component contains a group 1 and components 1 and 2. Component 2 contains a group 2 and component 3 and 4.
                    This bug was in the first version of the plugin and it's still not fixed.
                    • dereiD
                      derei
                      inferencing problem (detailed)
                      Sorry for not posting a youtube movie, I just uploaded it here, because I don't have a youtube account.
                      fredoscale.wmv
                      • fredo6F
                        I know I need to rework all this more accurately. I'll try to do it whenever I have time
                        • fredo6F
                          Could you post a model and tell me more about which tool you use, when it hangs (at selection, while generating the geometry, ...?)
                          • P
                            patriarch
                            Ok. Please, see attachments..
                            fredoscale-test-01.skp
                            fredoscale-test-03.swf
                            • bagateloB
                              bagatelo
                              The problem seems to be that we can not have a large and deep hierarchy of objects in outliner.
                              Try the shared model and see how the model is organized in outliner.
                              • fredo6F
                                Yes, it's definitely a problem when the Outliner is openand the transformation is interactive and operates on components that exist in several instances (like Stretch).
                                I think this was already signaled and I don't know too much what can be done about it.
                                  Jim Foltz / CPhillips [I think 😕 ] made a PC tool to roll-up the Outliner if it's open so that the crashing stops - there's also a send_action PC code... See this http://forums.sketchucation.com/viewtopic.php?f=180&t=15782&p=123147&hilit=rollup#p123147
                                  • bagateloB
                                    bagatelo
                                    This can be a problem. But not exactly in this situation.
                                    • F
                                      fumaru
                                      This is GODLY!!!!!!!!!
                                      One of the most power plugins i have ever seen !!!! a must have for any 3Ds max users that is using sketchUp!!! 😍
                                        shade69
                                        you are awesome!
                                        • N
                                          numnung
                                          thanK good.
                                          • F
                                            fzamr
                                            hey everyone...i need help n quick!!..i keep having a bug error when i try to bend using this plugin ..the same bug thing happens when i tried using shape bender plugin.. whatever i do..i am unable to bend shapes...i m following the instructions but every time when i m just about to bend the shape .. sketch up closes and i get a bug notification..same thing is happening with shape bender plugin.. can somebody help me plz???...i have an assignment due soon.....HELP!!!
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 58
                                            • 59
                                            • 33 / 59
